Old 05-28-2015, 03:11 PM   #1
urnmor's Avatar
2012 25' Flying Cloud
Berlin , Maryland
Best levelers to level your trailer.
Now that you all have convince me to level our trailer I will need to purchase some levelers. So I am wondering what would work best with my Rotochok wheel chocks and would be easy to use.
John
urnmor is offline   Reply With Quote
Old 05-28-2015, 03:25 PM   #2
Mrjkq's Avatar
2016 25' Flying Cloud
Venice , Florida
In my former TT, a large 36 footer I used plastic ramp type levelers that you pull the TT up on. They worked good however, once on the ramp the trailer had a tendency to roll back once unhooked, so wheel chocks had to be tapped in pretty good. This time I'm going to use the Lego type that come in a bag. In fact, I just bought them yesterday at Walmart. They give you the ability to adjust as you go along.
Mrjkq is offline   Reply With Quote
Old 05-28-2015, 07:10 PM   #3
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
Not that many options
1) Lego type blocks - but with tandem axel it's hard to use these
2) a couple of those plastic ramps mentioned - rotochocks with them may work and you can get a pair of those on camping world for 40 bucks as I recall and you can pull only up as high as need level much like the Anderson levelers
3) Anderson levelers x 2 = 80 bucks and that system chocks off
4) wood - versatile - cheap
Probably more but those come to mind
If I already had the rotochocks I may consider the ramps from CW - they work and also you can use them to ride onto higher stack of Lego blocks if needed then use rotochocks
I bought the Anderson's to avoid buying rotochocks or similar device
PharmGeek is offline   Reply With Quote
Old 05-28-2015, 07:42 PM   #4
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
PharmGeek summed it up pretty well.
I personally like the Lynx Levelers and have been using them for 15 years. I can use them to level the trailer or place them under the stabilizers to keep them from sinking in soft ground when deployed. You can also use them under your tongue jack or use them to level out a picnic table that's not on flat ground.
I also use them to change a tire, or use them under both wheels of the same axle to raise both wheels of the other axle when repacking bearings or working on brakes.
So... much more versatility for my purposes.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 05-28-2015, 08:25 PM   #5
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
I keep Lynx ones as well for all those purposes as well
It's just impossible to level more than just on or two blocks high with them on a tandem axel
The ramps from CW can fix that issue and rotochocks can work?
I like the idea of those hydronic leveling systems - but $$$$$ and some maintenance problems with them per reviews
Old 05-28-2015, 09:36 PM   #6
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I used the blocks until I discovered the Andersen Levelers. Don't fear progress or change, embrace it.
MICHAEL
Old 05-28-2015, 10:32 PM   #7
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Whatever you use, PLEASE secure the wheels BEFORE you unhitch.... I use the 'X chocks'... put between tires and crank tight.
For leveling, wood works well as it 'slides' less easily. Just cut a 1/2" or 3/4" board into 1x1 foot square chunks.. stack as needed. Also works good for 'spreading' the load when using bottle jack or other method to minimize 'sinking' into the surface.
I also carry some 'screw tripod' jacks which I place under the frame fore and aft of the axles to 'fine tune' the level AND minimize / eliminate 'trailer bounce' as you walk around over the axle area inside trailer.
Peace and Blessings..
Channing
WBCCI# 30676
Old 05-28-2015, 11:13 PM   #8
1974 Argosy 20
Kooskia , Idaho
The plastic blocks work well for me, but I have discovered that the solid ones are vastly superior to the open ones. How to tell them apart otherwise? The open ones have hex parts and are generally orange. The solid ones are more like lego blocks and are generally yellow. I have broken both kinds, but far fewer of the solid ones than the open ones.
Old 05-29-2015, 07:27 AM   #9
extiger's Avatar
2011 30' Classic
Kingwood , Texas
I have Rotochoks and use them with the Andersen levelers and am very happy with the combination. I also carry Lynx blocks and sometimes use them with the stabilizers. The Andersen levelers are great, simplifying the set up process.
2011 30' Classic
2015 Ford F250 4X4 Platinum
ProPride Hitch
extiger is offline   Reply With Quote
Old 05-29-2015, 08:16 AM   #10
Plasma800's Avatar
houston , Texas
I bought these
'15 27fb Signature
'12 Chevy 2500HD Gasser
Plasma800 is offline   Reply With Quote
Old 05-29-2015, 08:31 AM   #11
switz's Avatar
2014 31' Classic
2015 23' International
2013 25' FB International
Apache Junction , Arizona
Images: 8
The lego style blocks placed with the bumps up sank into the sandy soil over night and the trailer was no longer level in the morning.....
We have four 12"x12"x1" and four 8"x8"x1" rubber mats and four 18"x18"x1/2" orange plastic mats. The 12" ands 18" mats can work as simple levelers for minor adjustments.
The Anderson arches are better for more height.
We can place a 8" mat on top of a pair of 4"x6"x16" treated wood blocks for the stabilizer feet when we need to get better support for the leveler due to undulations of the ground under the trailer.
Old 05-29-2015, 09:13 AM   #12
urnmor's Avatar
Berlin , Maryland
Extiger how do the rotochoks work with the Andersens. do you both pieces or just one with the Rotochok?
Old 05-29-2015, 09:26 AM   #13
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
Have two bags of legos but prefer these. It came a gully washer last night and the night before and we're still level. I carry two 2x12s and 1x6s. Only needed one 2x12 this time.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 05-29-2015, 10:50 AM   #14
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
Ditto.
Brian
SuEllyn & Brian McCabe
How do you level your trailer? tallen5 Hitches, Couplers & Balls 46 08-15-2013 07:26 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
Austin, TX: Help me level my trailer w/ your truck this weekend? seventythree Jacks, Stabilizers, Lifting and Leveling 0 12-15-2009 02:40 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
Airbags and self-levelers fangthorpe Mechanics Corner - Engines, Transmission & More... 7 08-12-2003 10:16 AM
