Go Back   Airstream Forums > Airstream Community Forums > Boondocking
Old 05-29-2015, 01:31 PM   #21
moosetags's Avatar
2015 25' FB Flying Cloud
2012 23' FB Flying Cloud
Santa Rosa Beach , Florida
You are more fortunate than me. I have set Lucy up at hundreds of campsites all over the country, and 90% of the time she needs side-to-side leveling.
Brian
SuEllyn & Brian McCabe
2015 FC 25' FB (Lucy) with ProPride
2020 Silverado 2500 (Vivian)
2023 Rivian R1T (Opal)
Old 05-29-2015, 01:37 PM   #22
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
Brian
Agree, in 4 years I have only been to 4 or 5 spots where I did not have to level at least some. But then again I go to many different camp grounds and unimproved boondocking sites.
MICHAEL
Old 05-29-2015, 02:12 PM   #23
Wayne&Sam's Avatar
2014 25' Flying Cloud
Cuddebackville , New York
Images: 21
Wow- I don't remember any sites where I didn't need to level side to side. There probably were some, but overwhelmingly I need to level.
That being said, Andersen's didn't work for my 25' with 16" wheels. There wasn't enough room between the axels to fit the Andersen. They also sank into the soft ground.
I wish they did work for me because I like the idea of them.
2019 Ford Expedition Platinum
Old 05-29-2015, 03:18 PM   #24
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
Originally Posted by KJRitchie View Post
How many Lynx blocks do you have to use to raise one of the axles off the ground enough to remove a tire? Never tried it with mine.
Kelvin
About 3 or 4 for mine depending on the ground surface and whether there is any slope.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 05-29-2015, 03:59 PM   #25
AWCHIEF's Avatar
Images: 33
I have not seen it direct from Andersen but some have posted here that Andersen says that you can safely cut a coupe of inches off each chock if there are clearance issues. I carry a couple of 4 ft 1X12s to put under the wheels for soft or sandy ground.
MICHAEL
Old 05-29-2015, 04:24 PM   #26
DoublTrouble's Avatar
2017 25' International
Carlsbad , California
Andersens. So for no problems but have not experienced soft ground with AS yet. Instructions actually mentioned trimming the levels.
DoublTrouble is offline   Reply With Quote
Old 05-29-2015, 04:29 PM   #27
moosetags's Avatar
I have used my Lynx Levelers (leggos) to change 4 flat tires over the years. We also used them to mount Lucy's new 16" wheels and tires.
As you can see in the picture, it took a ramp 4 leggos high to change a wheel.
Brian
Old 05-29-2015, 05:41 PM   #28
PharmGeek's Avatar
2014 30' FB FC Bunk
Hoover , Alabama
The problem of soft ground with Lynx levelers for example is real as well
Boondocking last year I had to sorta sacrifice the height of 1.5 levels of the Legos before it settled
You can trim about 4 inches from the Anderson's I believe - see Amazon questions they address that clearly there as I recall
I have 16's on my 30' AS - I have not yet used the Anderson's - I will report back
PharmGeek is offline   Reply With Quote
Old 05-29-2015, 08:05 PM   #29
Tonganoxie , Kansas
I would think at the price of a new Airstream, they would include as standard equipment, electric jack stands.
TWA640316 is offline   Reply With Quote
Old 05-29-2015, 08:54 PM   #30
jayseejay's Avatar
2015 27' FB Eddie Bauer
2011 25' FB Flying Cloud
Fernandina Beach , Florida
I used Andersons with 16" Michelins in medium hard sand at Long Key SP this weekend. No trimming and no sinking. Worked well. Joe
jayseejay is offline   Reply With Quote
Old 05-29-2015, 09:20 PM   #31
AWCHIEF's Avatar
Images: 33
Direct from the Andersen web site,
http://www.andersenhitches.com/uploa...%20details.pdf
MICHAEL
Old 05-30-2015, 01:38 AM   #32
2000 30' Excella
2014 30' Classic
Princeton , Iowa
I started out with 2X6's, but went to Lego's because of the weight. They have worked fine. Chocking the wheels is so important. I have not had problems with sinking into the ground. I won't park on real sloping sites.
larryglarson is offline   Reply With Quote
Old 05-30-2015, 04:42 AM   #33
m.hony's Avatar
2013 30' Classic
Greenwood , Mississippi
If the Lynx levelers sink, I just crank down the stabilizers more. This is usually a one time adjustment after the first night.
2013 Classic 30 Limited
TAC #MS-10
Airforums #70955
Old 06-06-2015, 07:01 AM   #34
rodsterinfl's Avatar
2006 25' Safari
St. Augustine , Florida
OK, I must be missing something. The Andersen levelers caught my attention. As a solo camper easy is important. I do not see how this leveler saves time from my lynx-like blue squares. I watched the video and on the tandem trailer, twice they leveled a tandem trailer on a single wheel- got that part but note the guy with the leveler on the side telling the driver when to stop. My assumption for benefit is that IF you misjudge the height of blocks needed the Andersen wedge would avoid having to back off them but in the case of a solo I would still have to get out and measure level and readjust to an unknown point. So, am I not back to rolling back and forth? Usually I am close the first time but I have been off a block or so. No big deal. I only level one wheel (tandem) and only once had to create a lego ramp.
WBCCI 8653/AIR 60240
2022 Ford F150 PowerBoost Platinum w/7.2KW
Old 06-06-2015, 07:33 AM   #35
AWCHIEF's Avatar
Images: 33
As a solo streamer getting out and checking my progress is a normal part of doing business for backing into a spot or leveling my trailer. With the Andersen Levelers all I have to do is move up or back a small amount. No pulling off blocks and adding or removing to get it right. I level both wheels as I do not feel comfortable only doing one. Not sure having all the weight only on only one axle for extended period of time is the wisest thing to do.
MICHAEL
Old 06-06-2015, 07:52 AM   #36
Full Time Adventurer
BoldAdventure's Avatar
2007 27' International CCD FB
Nomadic , USA
Man, there is a product idea in here. Imagine if you had a wireless tool that told you when your trailer was level while backing up onto blocks. All you had to do was watch the meter.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
BoldAdventure is offline   Reply With Quote
Old 06-06-2015, 08:04 AM   #37
AWCHIEF's Avatar
Images: 33
Sort of is, they do not seem to have the best of reviews on either CW and Amazon.
Digital Level Lite, 2 Pack - Lippert Components Inc 282497 - Levels - Camping World
MICHAEL
Old 06-06-2015, 08:56 AM   #38
Nomadic , USA
I have this on our Airstream, and can see it out my rear-view, it's pretty hard to miss.
Old 06-06-2015, 10:03 AM   #39
That's why I never leave home without my best friend!
Old 06-06-2015, 10:06 AM   #40
I used to use that acculevel on my fifth wheel. It works fine but I dont plan to stick one on AS. Your idea is a good one, why not a device that you flop on the floor of the AS, that sends bubble level image to your mobile device? A remote app thing.
How do you level your trailer? tallen5 Hitches, Couplers & Balls 46 08-15-2013 07:26 AM
to level or not to level urnmor Jacks, Stabilizers, Lifting and Leveling 23 07-30-2012 11:21 AM
Austin, TX: Help me level my trailer w/ your truck this weekend? seventythree Jacks, Stabilizers, Lifting and Leveling 0 12-15-2009 02:40 PM
How level is level? RichardT 1961 - 1963 Bambi 7 03-12-2006 03:52 PM
Airbags and self-levelers fangthorpe Mechanics Corner - Engines, Transmission & More... 7 08-12-2003 10:16 AM
