Old 12-06-2018, 12:19 PM   #1
Airwave503's Avatar
1961 22' Spaceliner
Portland , Oregon
Battling condensation when snow camping
We're boondocking in the snow every weekend and condensation is really bad. I've insulated the windows with 2 layers of reflectix. It's too cold to have anything open. So I mainly just pack a lot of towels and keep up with it.
I bought some damp-rid. It's says it's for RV us but then in parenthisis
"(storage)" not sure what that means. Anybody had success with damp-rid or anything else?
'61 Safari
http://airwave503.blogspot.com/
Airwave503 is offline   Reply With Quote
Old 12-06-2018, 01:13 PM   #2
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Welcome Aboard!! 👍
When we had our 22' Safari the only way we could slow the formation...small fan & crack a window. 🥴
Mouse-fur on the Classic's walls help a LOT. 👍
Instead of going to ’Starbucks…I make my own Coffee at home, yell out my name rong, then light a five dollar bill on🔥
"The hardest thing about Airstreaming, clearing your head and accepting how others feel it’s supposed to be done"…..
Amanamus
"Tahawus"
Old 12-06-2018, 01:16 PM   #3
2017 28' International
Baileys Harbor , Wisconsin
Dehumidifier?
Daquenzer is offline   Reply With Quote
Old 12-06-2018, 01:43 PM   #4
Mattirs's Avatar
2016 25' Flying Cloud
Fairfield , California
What has worked for me was cracking the shower vent a little. Adjust according to how condensation there is. Don't run it. It takes care of all but cooking condensation.
Mattirs is offline   Reply With Quote
Old 12-06-2018, 02:15 PM   #5
Adventure.AS's Avatar
2017 25' International
Port Dover , ON Canada
When on shore power we love our EcoSeb Desiccant Dehumidifier. It is quiet and removes a lot of moisture from the air. Besides being quiet, another advantage of a desiccant type dehumidifier is that they work in low temperatures.
Name:	EcoSeb Desicant Dehumidifier.jpg
Ray B.
“One test is worth a thousand 'expert' opinions”
Sign at Boeing headquarters, posted by test pilot Alvin “Tex” Johnston, c1948
Adventure.AS is online now   Reply With Quote
Old 12-06-2018, 03:56 PM   #6
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
Where do you place that in a 25fb without tripping on it when using the trailer?
Old 12-06-2018, 03:59 PM   #7
TheGreatleys's Avatar
1974 27' Overlander
Baltimore , Maryland
What are you using for heat? We crack a roof vent and run our wood stove to keep us dry. Works great. I imagine you could do the same with any powerful dry heat source.
TheGreatleys is offline   Reply With Quote
Old 12-06-2018, 04:36 PM   #8
DKB_SATX's Avatar
1976 Argosy 28
Alamo Heights , Texas
As long as you're not using an open flame or maybe a catalytic heater, most any heat source would be "dry" no? The propane furnace exhausts all its combustion gases outside, so there's no chance of picking up moisture from the propane burning. Your wood stove is probably highly effective because it draws some (all?) of its combustion air from inside (you said you run it with a roof vent cracked...) so you're introducing drier outside air that wouldn't happen as much with the furnace or an electric space heater.
— David
Old 12-06-2018, 04:56 PM   #9
pjshier's Avatar
2017 27' International
Wasilla , Alaska
your issue is similar to the problem us cheapskates in Alaska discovered when we buttoned up our houses so tight (less heating fuel, right?) that the moisture of living couldn't go anywhere. Ended up living with towels on the window sills. Just breathing throws a LOT of moisture.
The Alaska house solution of choice is an air-air heat exchanger. Second solution is venting. Assuming breathing is a requirement, you will have to move the warm, moist air outside in moderation. As others have stated, open a vent up high. The heat you lose is likely easier to replace than having to deal with the moisture.
2017 Int'l Serenity 27FB
2017 F350 oil burner
pjshier is offline   Reply With Quote
Old 12-06-2018, 05:09 PM   #10
We have a 25RB Twin. During the day we leave it in the bedroom to make sure the bedding dries out and during the night we place it by the lounge. It can also go under the dinette table if you prefer, but I like to make sure it has good air circulation. After a shower or creating a lot of moisture the EcoSeb has a 'turbo' mode that will really wring the water out of the air.
Ray B.
Old 12-06-2018, 06:07 PM   #11
1973Argosy's Avatar
1973 Argosy 24
hartselle , Alabama
We run our roof top heat strips and furnace together when on hook ups. This saves on propane as well as producing less moisture (furnace runs about half as often). We always crack a top vent to keep the moisture at bay. It can become a balancing act of how much to crack the top versus keeping the interior warm.
1973Argosy is offline   Reply With Quote
Old 12-06-2018, 06:35 PM   #12
2002 19' Bambi
Lafayette , California
Since our trailer was new, we (two adults and a large dog) have spent Septembers in West Yellowstone, Montana where temperatures at night can easily be in the teens. As pjshier mentions, our main solution is ventilation. We crack a roof vent and one window and run our propane furnace. Since hot air rises, it goes out the roof vent and draws in air through the window. Yes, we surely use more propane that way, but the inside of the trailer stays dry. Occasionally, we add an electric heater to the mix.
As ROBERT CROSS points out, the mouse fur on our trailer's walls helps. I also have made most parts of the windows double pane.
Tim
Tim A. is online now   Reply With Quote
Old 12-06-2018, 10:17 PM   #13
waninae39's Avatar
2017 22' Sport
NCR , Ontario
in winter the RH outside is very low
ie in homes , that's why we have humidifiers on in the winter
if you have too high a RH inside the As, then you are generating too much humidity by breathing , cooking and propane heating
IMHO, the best way is too bring in fresh outside air (low RH) and
expelling the stale air (high RH)
crack open a window and exhaust the air through the roof fantastic fan.
yes it will use more gas, but you do need some means to exchange the air
we use an electric heater that does not add moisture unlike propane heat
waninae39 is online now   Reply With Quote
Old 12-07-2018, 07:09 AM   #14
1974 27' Overlander
Originally Posted by DKB_SATX View Post
As long as you're not using an open flame or maybe a catalytic heater, most any heat source would be "dry" no? The propane furnace exhausts all its combustion gases outside, so there's no chance of pickup up moisture from the propane burning. Your wood stove is probably highly effective because it draws some (all?) of its combustion air from inside (you said you run it with a roof vent cracked...) so you're introducing drier outside air that wouldn't happen as much with the furnace or an electric space heater.
Yes, exactly. We're only running it with a vent open when we need to get rid of humidity. I don't see any reason you couldn't do the same with a propane furnace to dry out your space in the Winter.
How much snow is too much snow? KSA63 Winterizing, Storage, Carports & Covers 43 02-19-2017 04:20 PM
Snow Camping...or not. Mrs.Mod Winter Living 50 11-19-2012 12:24 AM
Sick and tired of battling batteries!! Anniedog Batteries, Univolts, Converters & Inverters 62 03-11-2010 08:25 PM
Snow and SNOW.. 53flyingcloud Off Topic Forum 9 01-23-2005 02:32 PM
