Old 11-08-2012, 08:29 AM   #1
2005 16' International CCD
Battery dies before sunrise
When boon docking, my battery always runs out of juice, setting off various alarms and clicking sounds. I have a generator and use it during the allowed hours (usually for 15 mins or so, to minimize disturbance to other campers). I usually only run the refrigerator (propane) at night. I have heard that linking two batteries may solve the problem - is that the best way?
BambiBirder is offline   Reply With Quote
Old 11-08-2012, 08:36 AM   #2
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Running a generator for 15 minutes is not going to put much of a charge back into the battery.
If the battery is fully charged you should be able to go all night unless you are running the furnace for an extended time. Either your battery is not fully charged or it has lost the ability to hold a charge.
Richard
Old 11-08-2012, 08:42 AM   #3
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I thought about adding a second battery too. Instead I bought the largest battery that would fit in my battery box. Then I changed about half my interior lighting to LED, at least one bulb in each two bulb fixture. I only turn on the second bulb in each fixture only when I need task lighting at that specific location. I've been like this for more than a year now and this works for me. I have not cold weather camped unless I had shore power, so I do not know if this will maintain enough charge to run the furnace all night.
15 minutes run time on your generator will not fully charge your battery. You need around 2 to 2 1/2 hours at least to maintain daily. If it's completely dead more time.
Alan
Old 11-08-2012, 08:49 AM   #4
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
You may need to charge the battery for more than 15 minutes if it's as depleted as you say.
Also, make sure the battery charger matches the type of battery. A charger meant for wet-cell starting batteries will not do so well for either wet-cell deep-cycle batteries or AGM batteries.
Connecting a second (identical) battery will double your amp-hours, but also double your charging time.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-08-2012, 08:59 AM   #5
1981 31' Excella II
New Market , Alabama
I don't think he is getting the battery fully charged as others have suspected. The battery voltage as measured at the terminals with no load should be around 12.5 V. Measure your voltage a few mins after turning off the generator and see what you get. I would try to measure at the battery terminals if possible.
Automotive battery - Wikipedia, the free encyclopedia
Perry
Old 11-08-2012, 09:01 AM   #6
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
It's all about amps in amps out. You must "put back" amps that you take out. This is a very simplistic way of thinking but it is what is going on. The output of your converter and the size of the battery will determine just how long you have to run the generator to bring the battery back up to full charge. There is a lot of really good info on maintaining 12V systems on many RV web sites. Look at the capacity of the battery (amp hours) and the capacity of your converter, do a little math and you can get the approx. time to run the generator. Bear in mind that there are losses so a little longer is better. This is assuming the battery is still in good condition. A good digital volt meter is very helpful.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-08-2012, 09:04 AM   #7
1981 31' Excella II
He is right. If you have a 70-100 AH battery it will take several hours at a 20A charge rate to recharge that battery.
Perry
Old 11-08-2012, 10:58 AM   #8
Mexray's Avatar
1978 28' Ambassador
Morada , California
I use the 150% rule when trying to estimate the recharge time...
If your gr-24, 80 amp hr battery was completely discharged, and you have an 40 amp rated converter/charger...
80 AH / by 40 amp chgr = 2 hours x 1.50 = 3 hours total to complete the charge...
This is only an approximate estimate, as actual conditions vary...
We have a 3-stage chgr & a volt minder so I know when to quit charging when the volt meter shows the charger has reduced voltage to the 'float' mode, about 13.6 volts...
Ray & Pat; Morada, CA
Old 11-08-2012, 11:06 AM   #9
WHEN to charge can make a difference, too. Try to charge your battery when you're using the most AC current anyway, so that you're running your AC appliances off the generator and not the inverter. The generator should put out enough juice to run both the appliances and the charger at the same time.
If you charge your battery around dinnertime, so that your lights, microwave, etc, are running off the generator and not the inverter, you also start the "quiet hours" with a fully-topped-off battery, and you will find that it lasts longer than if you charged it in the morning and it's already half-depeted by evening time.
WBCCI #1105
TAC LA-4
Old 11-08-2012, 11:42 AM   #10
retired USA/USAF
2001 30' Excella
Somerset , New Jersey
We have 2 group 27 batteries. We stayed 3 nights on battery this past summer with no problem. Of course the heater is a big drain and we weren't using it. But for refrig and lighting it was good. One fully charged battery should last more than one night without using the heavy consumers.
Roger in NJ
Winston Churchill 1948
TAC - NJ 18
polarlyse is online now   Reply With Quote
Old 11-08-2012, 12:18 PM   #11
jdalrymple's Avatar
2009 27' FB Flying Cloud
1991 35' Airstream 350
Jay , Oklahoma
You know how your cell phone takes longer than 15 minutes to charge?
So do the batteries in your trailer.
As mentioned above, you need to run a generator 3-6 hours a day to get a complete recharge. More batteries mean more storage and longer run times, but will take longer to charge, too.
Regards,
JD
Jeff & Cindy
'09 27FB Flying Cloud
'91 350 LE MH
Old 11-08-2012, 01:02 PM   #12
1981 31' Excella II
Some generators have a 12V output at several amps that may charge the batteries faster than going through the converter. Just because your converter puts out 55A MAX does not mean that much is going to the battery. When the battery is dead you might get 55A but when it is half charged you may only be getting 10A.
Perry
Old 11-08-2012, 02:02 PM   #13
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
Are you running the furnace? I think one good battery fully charged out to be good for 3 or 4 days for lights, fan, refrig. You probably ought to buy one of the little $20 battery voltage meters and keep it plugged into your trailer. Pretty soon you will learn to tell how well the battery is charged and how far it discharges. Depleting the battery all the way and recharging is very hard on the battery. I suspect at this point you need a new battery and a longer run on the generator. Also not that driving the car and pulling the trailer will not fully charge the battery. It really needs to be charged on shore power to get it to full capacity.
We have some LED lights and a fantastic fan. We run the refrig all the time. We can go 4 days or longer on a half draw down on 2 batteries. But if it is cold and we run the furnace we have to charge almost every day.
Bill M. is online now   Reply With Quote
Old 11-08-2012, 02:58 PM   #14
DanielB's Avatar
1974 31' Excella 500
Charleston , South Carolina
You have a 2005.. do you have one of those buttons with a meter that you can push to see the status of your battery?
As I grow older, I pay less attention to what men say. I just watch what they do.
- Andrew Carnegie
DanielB is offline   Reply With Quote
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
2004 Land Yacht Chassis Battery? RAG Land Yacht/Legacy Motorhomes 11 02-01-2012 07:19 AM
Battery Issues aswbe Batteries, Univolts, Converters & Inverters 29 08-08-2011 07:27 PM
