Old 11-08-2012, 02:59 PM   #15
Central , Mississippi
Originally Posted by perryg114 View Post
Some generators have a 12V output at several amps that may charge the batteries faster than going through the converter. Just because your converter puts out 55A MAX does not mean that much is going to the battery. When the battery is dead you might get 55A but when it is half charged you may only be getting 10A.
Perry
On a Honda 2000, the DC Charging circuit is unregulated and only 8 amps max. It's much better to use the AC side to charge batteries.
I have noted that my setup, 3 group 27 batteries (+-240 AH) when discharged to 80% will only load a 65A 3 stage charger on it's Bulk Mode to 13-15 amps. In other words, the last 20% will take hours to approach a full chargel.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-08-2012, 03:10 PM   #16
Wise Elder
Jammer's Avatar
2010 30' Classic
Originally Posted by BambiBirder View Post
When boon docking, my battery always runs out of juice, setting off various alarms and clicking sounds. I have a generator and use it during the allowed hours (usually for 15 mins or so, to minimize disturbance to other campers). I usually only run the refrigerator (propane) at night. I have heard that linking two batteries may solve the problem - is that the best way?
Since you have a 2005, if you have the original battery, it's time to replace it. Even if it's not the original battery could still be beyond it's useful life (rule of thumb: four years).
If you have the original converter in your Airstream, it takes an overnight charge (or longer) to get the battery completely topped off. With a multi-stage converter it would still take at least four hours to recharge a completely discharged (or nearly so) battery.
Running the fantastic fan or furnace are the two quickest ways to run the battery down at night. Avoid those if your situation permits.
Old 11-08-2012, 03:46 PM   #17
1981 31' Excella II
New Market , Alabama
Well if you have a tow vehicle with a big alternator in it you could charge it off that in a shorter time if you use jumper cables to get maximum current.
Perry
Old 11-08-2012, 03:52 PM   #18
Figment of My Imagination
Protagonist's Avatar
2012 Interstate Coach
Perry
You could, but preferably if the trailer battery is a wet-cell starting battery (which is entirely the wrong type of a trailer, but you never know what the previous owner used), and not a deep-cycle battery. The voltage regulator on the engine alternator is optimized for recharging starting batteries.
WBCCI #1105
TAC LA-4
My Google-Fu is strong today.
Old 11-08-2012, 04:35 PM   #19
1981 31' Excella II
Voltage is voltage. Current is Current. Try it and if it does not work try something else. I don't know of another way to get that kind of current to recharge a battery fast. Charging a battery fast is not optimum no matter what type the battery is. Running a quiet generator for several hours is probably the best solution.
Perry
Old 11-08-2012, 04:46 PM   #20
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
When we dry camp I run my Honda 2000 an hour in the morning to recharge from to past evening...tv w/satellite or movie (dvd) and/or late night book reading etc. When we sleep NOTHING (electrical) is on. Heat if needed is portable propane...no fan but never when sleeping. Then I run the charger 1 hour again late afternoon if my volt meter says that the battery is a little low. Works for us.
Neil
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 11-12-2012, 06:43 PM   #21
Phoenix , Arizona
My Avion C-11 has a small deep cycle battery that kept the furnace going all night long. I have a second large battery box, but I never put a battery in it since I haven't needed it yet. I charge the battery with a generator during the day if I expect to use the furnace all night long.
One of the biggest things that I did was to go to 100% LED lights.
M2HB is offline   Reply With Quote
Old 11-13-2012, 07:43 AM   #22
2005 16' International CCD
Thanks for the help
Thanks everyone for your advice and suggestions. Sorry for the late response but we've been camping without email/internet service (we did, however, have an electrical hookup!). I plan to purchase a volt meter and change out the lights to LEDs. My generator (Yamaha 2400) has a 12 volt output that I haven't used to charge the battery directly. I plan the experiment with this option and other suggested options (using the volt meter) next time we boondock.
BambiBirder is offline   Reply With Quote
Old 11-22-2012, 08:37 AM   #23
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Use Less for Longer Battery Life at campsites
When hooked up to 110v at a campsite, you can light the place up like a Las Vegas Casino.
When not hooked up to 110v, use the lights and battery power as if you are sipping an expensive wine in short supply.
While camped off the grid, it is natural for some trailer owners to light the place up to create a city home lit atmosphere for comfort. Then the generator is started and runs all night and day. Take a look at your power use off the 110v grid and make the changes necessary to extent the battery life without a charger or hooking up later on the electrical grid to recharge.
Use less when off the grid and you will be fine.
Ray Eklund is offline   Reply With Quote
Old 11-22-2012, 10:44 AM   #24
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
If you run your battery down to 0 volts, it will not last long and probably is ready to be replaced anyway if it is the original one. Since you don't charge it long enough, you probably are lucky to get anything out of it. Since you don't use anything but the fridge and maybe a few lights, you're almost getting away with it.
You shouldn't run the battery down below 50% of capacity. Doing that more than a few times shortens battery life substantially.
LED's will save a lot of power, but be sure to get good quality ones. Cheaper ones have a reputation of not lasting long and end up costing you more than good ones.
Gene
Old 11-22-2012, 11:52 AM   #25
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
Gene
A battery is considered completely discharged when the voltage drops down to around 10v not 0 volts. If you have repeatedly run your battery down you have damaged it. I agree it has lived its life.
You can also have a load test done on the battery, and check for dead cells.
Old 11-22-2012, 01:37 PM   #26
Master of Universe
Gene's Avatar
Correct. Another brain dead morning.
Gene
Old 11-25-2012, 06:41 AM   #27
arden_dean's Avatar
1986 34.5' Airstream 345
topeka , Kansas
Images: 26
I go to some remote places when I deer hunt and run the heater nonstop. The coldest morning I can remember was -12 most of the time the low is 15-20. I run 2 large deep cycle batteries and start the generator in the morning as soon as possible. However, when I get a deer I get back late around 10:00, at that point everything is dead. The batteries last about 3 years with that kind of abuse.
“The world is a book and those who do not travel read only one page.” – St. Augustine
arden_dean is offline   Reply With Quote
Storage Solutions: battery box and new made-to-open twin beds whitefawn All Argosy Trailers 5 12-19-2014 02:33 PM
2004 Land Yacht Chassis Battery? RAG Land Yacht/Legacy Motorhomes 11 02-01-2012 07:19 AM
Battery Issues aswbe Batteries, Univolts, Converters & Inverters 29 08-08-2011 07:27 PM
