Old 09-29-2014, 02:23 PM   #1
Vintage Kin
slowmover's Avatar
Fort Worth , Texas
Battery BCI Grp Size: Q for Lewster
Lewster, I've been thinking of increasing my battery box size to accommodate a pair of L-16 (also BCI Grp 903) sized batteries. Not time yet to make other mods for increased battery capacity.
Tongue box mod will be done by a local fabricator / certified welder. This is on a full-frame "vintage kin" SilverStreak. Tow vehicle not a concern with tongue weight increase, and modified box will be beefed up (currently a pair of T-105's).
I'm working from an extant 1989 factory installation (still works; 2-panel "Solar Electric System" brand) and need to make changes to the existing for better performance prior to some day erecting a full scale big solar system.
First things first. I need a welder for some other work and am seeking your opinion about the worthiness of increasing battery size.
A lot of work for minimal benefit, or . . ? The batteries need replacing anyway.
Also, in what order -- and what componentry / parts -- should I look to replacing in what order for the future? Any books or online guides you'd recommend? I'm intrigued by the idea of a "hybrid" sytem you mentioned elsewere.
I see that Earth Roamer installs 1.3KW systems on their offroad wonders, so am using that number for initial minimum calculations. This TT is 35' long and I plan to upgrade it to what a family of five or two couples would want. Washer/dryer, dishwasher . . the usual 5'er/moho amenities short of an onboard generator. While I don't expect to run those sort of items via batteries I hope it helps with a picture. Two TV's, surround sound, Wi-Fi, eventually twin A/C and 50A service. Folks today want their eee-lektericity.
So, where to start is One. Two, what references to use to start towards a "big" system. I'd like to not have to do things twice, but prefer a working system as I go along (not a strict requirement as I am in RV parks for the foreseeable future).
Thanks for your consideration of these questions.
Ross
P.S. If anyone has links to a recent "big" solar install thread done DIY or otherwise I'd be appreciative. I've seen the ones around here, and am hoping to look upon something state-of-the-current-art in one of the bigger TT's, 5'er or conventional, moho or sailboat, or what-have-you.
Thx
Replace Grp 24 Batt with Grp 27 2007? 2dabeach Electrical - Systems, Generators, Batteries & Solar 24 10-15-2014 09:24 AM
Question for "LEWSTER" & others about furnace board catson4 Furnaces, Heaters, Fireplaces & Air Conditioning 1 01-05-2009 07:22 AM
