Old 01-20-2015, 05:20 AM   #29
CLOUDSPLITTER "Tahawas"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Thumbs up
I have found the handles are just as helpful when taking down the awning. Much easier releasing the locks. Silicone on the arms also makes up & down less stressful.
I always retract the center support first.
Old 01-20-2015, 08:07 AM   #30
AWCHIEF's Avatar
Biloxi , Mississippi
Images: 33
I just watched the video and discovered that I have been doing it all wrong. Went out to the trailer and opened and closed it the correct way. Amazing how much easier it is.
MICHAEL
Old 01-23-2015, 10:51 PM   #31
"Space A" S/O Registry 11
2006 34' Classic S/O
Fort Worth , Texas
I too, hated to fool with the big and long clumsy Zip Dee. It was a real PITA, especially during an approaching thunderstorm. So, I bit the bullet and had the Mothership install an automatic kit. They use your awning, tube, and rail with all new hardware. Nothing shows as the electronics are all hidden in the front end kitchen counter cabinet. When my wife is walking up to the trailer during set up, I just say "Abra Kadbra", press the remote switch in my pocket to extend, and were are ready to sit under the awning. The first time I convinced her the awning deployed automatically as she approached the trailer door. She is an awning freak, so now I can keep Mama happy. Otherwise, when Mama ain't happy, nobody is happy. The Automatic awning can be positioned at any amount of extension, tilted for water run off, front or rear, or be retracted with a standard electric power tool in an emergency. I am already used to the larger thickness arms that hold the electric drive motors. It uses vey little DC because of the high geared system. If the arms get out of sync, just extend the awning out fully and redo what you wanted. This has not been a problem. So far we are pleased with the set up.
Old 02-19-2015, 11:10 PM   #32
mefly2's Avatar
2015 25' FB Eddie Bauer
Originally Posted by KJRitchie View Post
Thanks. I'll look into getting a set. Should be standard equipment.
Kelvin
Absolutely! It can save you hand gashes on every use ... especially when tearing down.
Vintage style awnings (martys awnings) LUCKYDOGNOLA Airstream Classifieds 0 03-24-2014 11:04 PM
1972 AIRSTREAM Tradewind, 25 ft, 3 Awnings, Great Shape eBay Watch Airstreams on eBay 0 08-02-2009 05:40 PM
4CU in Deep Doo-Doo eubank WBCCI Forum 54 05-12-2009 03:59 PM
zip-dee doo dah day nettepdx Awnings 17 10-21-2004 05:51 PM
