Old 10-18-2015, 09:36 AM   #29
blkmagikca's Avatar
1987 32' Excella
Nepean , Ontario
Wind Turbine Generators
Since the main reason not to use the furnace for heating the AS at night is that the batteries will be depleted, one could consider the use of a wind turbine generator. See https://www.emarineinc.com/categorie...-Wind-Turbines - There was a boondocker at Quartzsite using one of these. I had explored the idea of mounting the mast to support a small wind turbine generator (about 500 watts) using the flag pole holder which is clamped to the tongue jack. For people camping in New Mexico where the winds blow all day and all night, this would be an excellent way of topping up your batteries. The downside (and isn't there always a downside) is that you would have to dissemble the kit and pack it up when you want to travel.
Food for thought . . .
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
blkmagikca is offline   Reply With Quote
Old 10-18-2015, 09:58 AM   #30
Ray Eklund's Avatar
2014 25' International
Boulder City , Nevada
Goodland, Kansas: The gateway to Western Blizzards!
Solution to a "short term" cold spell while on the road in the West.
I had bought a 24 foot Uhaul load of geological books in Ardmore, Oklahoma in late February. This was after being at the Tucson Rock Show in Arizona for the first half of February and then east to Ardmore, OK to pick up tons of books.
Weather in Ardmore was warm and pleasant, with a drizzling rain the day we loaded. Of course. We leased and filled the Uhaul truck in Ardmore, we headed north to Salina, KS, caught I-70 and headed west to Denver, CO. We were pulling our 23 foot Airstream and driving the Uhaul home. We drained the Fresh, Black and Grey water tanks at the first truck stop. Drained the water lines by opening the valves under the trailer and let them drain. Opened the cabinet door to the water pump, as there is always water in it, unless air flushed. We carry a five gallon jug for us and dogs inside the trailer.
February snow is to the High Country, as rain is to southwestern Alaska... expected, but if you time it right in the Rockies... it could be pleasant, and dry. Not so on this trip.
A Winter "clipper" closed I-70 down in both directions from the Colorado border and west to Denver. We found a familiar spot... Walmart at Goodland, KS. Snow arrived with the Kansas wind... blowing from the south across the parking lot. I topped off the gas tank in the Tundra and parked on the north side of the large parking lot. A few 18 wheelers paused to head further East, and we bought some doughnuts to wait out this blizzard until the highways were reopened, dry and clear.
That evening we had the furnace set at 45F to 50F, at least comfortable for the evening and all of the sleeping bags and blankets being used. Each Blue Heeler had their pillow and a light blanket on top of them. Power... the Tundra idling. We felt the trailer rock a bit with wind gusts and cracked open the top vents when frost at the bottom of the bedroom windows began to frost up.
By morning it was clear, sunny and by 10AM the roads were DRY. We used 1/4 tank or so of gasoline with the Tundra idling through the night. The furnace, as any Airstream owner knows in this situation... shuts off and a minute later starts up again. Over and over. You get use to it and ignore it after a few hours. I forget the low temperature that evening, but most likely under 20F. Wind chill... wow! You get frost on your mustache wind chill.
Sometimes you cannot plan for the worst. It just shows up. You hope for the best... but PLAN FOR THE WORST. Our propane tanks were full. We found a "safe zone" to park overnight. Gasoline was easily available. Walmart had unlimited food, snacks and ice scrapers if needed. We survived this with no ill effects.
To add... I found a $1 bill blown into the grass by the wind and hung up in the tall grass. Ding, ding, ding. Amount of snow... maybe two inches and blown into drifts off of the paved surfaces into a foot or more. In Wyoming... it snows an inch and drifts a foot... as another example.
YOU can make it through a temporary cold and snow event. We were wise diving into the first "safe zone" and remained patient. No hurry even if you are running late. It is best to be smart than a victim of weather.
Was it foolish of us to travel this time of the year? No. We were prepared. After a "BIG" storm in the Rockies... the blue sky, bright sun warm you up the next morning! Not like Buffalo, NY where it goes on, and on... and on.
Travel during the winter is not an issue, but you have to rethink how to prepare yourselves and trailer for the... just in the event of. We do. The doughnuts were only so... so. Our coffee... worth preparing and wearing a jacket and gloves inside the trailer, perfect.
Human Bean
Ray Eklund is offline   Reply With Quote
Airstream Speed Limits? silversled On The Road... 109 01-04-2018 10:01 AM
Any problems with age of Airstream in campgrounds with RV age limits? JustSomeGuy On The Road... 27 01-16-2016 11:43 AM
Axle weights limits vs. combined weight - What am I missing? Section8 Towing, Tow Vehicles & Hitches 25 02-15-2011 07:46 PM
Size Limits in Olympic NP? jglabrown On The Road... 0 07-04-2009 07:31 AM
'98 30' Excella 1000 Weight Limits - Walt & Lyn Driver1 Member Introductions 25 09-10-2006 05:32 PM
