Old 08-05-2016, 08:06 PM   #57
2014 23' International
2015 30' FB FC Bunk
Palos Verdes , California
Hymmmm
We did not turn on the water heater......
Converter?
Fridge is on auto, so it could switch to electrical.....
I can try that, but I really thought 4000 units would /could handle one AC
BFamily is offline   Reply With Quote
Old 08-05-2016, 09:16 PM   #58
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
4,000 watts is really 3,200 watts. Each generator is rated at 1,600 watts continuous load.
You need to make sure the high wattage devices like the refer and water heater are not in the electric mode. You must manually set both to gas mode.
Old 08-06-2016, 06:38 AM   #59
2015 30' International
FREDERICK , Maryland
Originally Posted by BFamily View Post
HELP!!!!
Have 2 Honda Eu2009I generators set up in parallel and I cannot power 1 AC!!!!?????
I can get zone 2 in my 30ft bunk to start but only for 20sec or so.
At that point, the generators switch off into red light.....overload alarm.
Suggestions, guidance ,
And yes, triple checked the polarity black L red R 30 amp receiver in my companion unit. Eco throttle off.
Thank you!!!!!!!
Check your thermostat. Make sure one of the A/C is turned OFF.
Doc Foster is offline   Reply With Quote
Old 08-06-2016, 07:12 AM   #60
2006 25' Safari
Retired , Michigan
13500 watts or 15000 watts
here's the spec for 15000 at the bottom are gen req
Nominal capacity, BTU/hr.: 15000
Installation type: Non-ducted or Ducted
Electrical rating: 115V AC, 60 Hz, 1Ph
Compressor-rated load amps: 13.2
Fan motor-rated load amps: 2.7
SCFM, high-speed max./min.: 300/350
Heater amps/watts @ 120V AC: 13.7/1,530
Refrigerant 410A (oz.): 22
Minimum wire size: 12 AWG copper up to 24 feet. For distances over 24 feet consult the National Electrical Code
AC circuit protection: (User Supplied) 20 amp time delay fuse or 20 HCAR circuit breaker
DC circuit protection: (User Supplied) Installation must comply with national, state, provincial and/or local electrical codes
Installed weight, lbs.: 74
Minimum generator size - 1 unit: 3.5 KW
Minimum generator size - 2 units: 5.0 KW
Thermostat/Control options: ADB or Thermostat
LakeState is offline   Reply With Quote
Old 08-06-2016, 03:52 PM   #61
lewster's Avatar
Naples, FL , Hood River, OR
Don't forget that these ratings are at the industry standard of 90 deg. F. As the outside ambient temperature increases, so will the load requirements for running the compressor.
Lew Farber
Old 08-06-2016, 04:34 PM   #62
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Oak Creek , Arizona
Also turn the eco-throttle to full throttle on the Hondas to start AC.
This is the strangest life I've ever known - J. Morrison
The Nest Egg - 2015 Airstream International Serenity 27FB
Quicksilver - 2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 08-07-2016, 12:34 AM   #63
2015 30' FB FC Bunk
Thank you to those that replied!
We manually turned off the water heater and put the refrigerator on gas.
We made sure everything was off, but zone 2, and it turned on for 15 secs and then turned off with error code E7 :-(
I guess back to the dealer to check out the AC. We should be able to run one of the units with 2 of the Honda 2000i's in parallel .
Old 08-07-2016, 12:54 PM   #64
2015 28' Flying Cloud
Newtown , Pennsylvania
The 2 Hondas should run either of your air conditioners.
If there are no other loads in your trailer, then there must be a problem with the parallel setup. Are both Hondas showing a red overload light?
Bruce
50 amp, Awning package
2015 Ram 2500 6.7 TD, Blue Ox 1000 lb.
4 Lifeline AGM, Trimetric 2020
PD9160 converter, Prosine 1800 inverter
2x eu2000i Propane
AstroBruce is offline   Reply With Quote
Old 08-07-2016, 01:45 PM   #65
2006 25' Safari
Retired , Michigan
try again
turn off zone 2 and try zone one
Old 08-07-2016, 01:51 PM   #66
2006 25' Safari
Retired , Michigan
E 7 code
in another post with the same results E 7 code would not allow AC from shore power. Any way check the 120 breakers and the use or store switch should be in the use position. Lets know
Old 08-07-2016, 01:54 PM   #67
daveswenson's Avatar
2012 28' International
Issaquah , Washington
Originally Posted by McDave View Post
My apologies for digressing, but do you who use 2 2,000 w Honda generators to run your air conditioner run them in economy mode, so they speed up when under demand, or do you run them full speed all the time? I've noticed that one 2,000 w generator works well in economy mode for using the microwave, etc., but I'm not sure if that is true for two of them running the AC.
I run them in econ mode to power the AC.
Dave
2014 Ram 2500 CTD
Pro Pride
Centramatics
daveswenson is offline   Reply With Quote
Old 08-07-2016, 02:08 PM   #68
2006 25' Safari
Retired , Michigan
E7 code means the circuit board is not receiving 120V power
i hate to ask this question but here it goes. do you know if your thermostat is in sink to your ac units? If the ac units have been replaced and or your thermostat there is a mfg code to sink between the thermostat and the ac unit. just asking!
Old 08-07-2016, 02:19 PM   #69
Gainesville , Florida
I would think Econ mode would not be beneficial in trying to run an ac unit.
avionstream is online now   Reply With Quote
Old 08-07-2016, 10:32 PM   #70
lewster's Avatar
A Dometic 13,500 BTU A/C unit has a transient starting load of around 50 amps. Your 20 amp circuits and their breakers are designed to handle a transient starting load such as this, but your generators are not. ECO mode will not suit you well when operating a roof A/C
E-7, as stated above, means that you are not getting 120VAC power to your roof units. A CCC-II thermostat will not show E-7 unless it is not getting the proper signal from the upper control board where the 120VAC enters the upper unit There could be several reasons for this:
do you have 120VAC power anywhere else in the trailer when on shore power, like at the microwave?
*have you checked the breakers by first pushing them down 'click' to re-set and then up 'click' to the ON position?
in reference to the first point, do you have a 'generator inlet' at the front of the trailer? If so and you are not getting power to one of both A/C units, you might have a problem with your transfer switch
if you are not skilled with using a volt meter in an open breaker box.....DO NOT ATTEMPT THIS!!!! You can remove the breaker face plate and check both incoming legs of your 50 amp service at the main tandem breaker to be certain that you are getting power into the trailer. Then check again at the individual 20 amp A/C breakers. Then again at the K-5 relay that is located on your upper control board. This will allow you to follow the path of the 120VAC from the main breaker right into the control board. You can also use a non-contact inductive circuit tester (looks like a small, fat pen and is available at the big box stores) to see of you are getting voltage at the positions described above.
AGAIN, IF YOU ARE NOT FAMILIAR OR COMFORTABLE WITH WORKING AROUND LIVE CIRCUITS....DO NOT ATTEMPT ANY OF THIS AND CALL A REPUTABLE RV TECH
Comments on my first time boondocking, battery use, etc. blickcd Boondocking 36 09-07-2011 05:38 PM
Boondocking in Missouri j54mark On The Road... 15 07-20-2008 09:22 PM
My EU2000i & gas can & boondocking Raptorrider2001 Generators & Solar Power 5 04-03-2003 10:12 AM
Boondocking Drip Coffeemaker RoadKingMoe Our Community 12 02-22-2003 09:31 PM
To use or not to use: living in our Airstream TinRoof General Appliance Topics 2 08-09-2002 01:11 PM
