10-05-2015, 03:54 PM
#21
Full Time Adventurer
2007 27' International CCD FB
Nomadic
, USA
Considering how much they over-charge for the pathetic solar they already install, no thank you. It was fairly cheap in comparison to prep my Airstream for boondocking. Some of you are just over thinking it.
Personally I would like to see improvements made in the R value of the trailers. That's the big issue holding back camping in some climates in my opinion.
To each their own though.
Family of 5 exploring the USA with a Ram Power Wagon & Airstream in tow.
OUR BLOG | INSTAGRAM
10-05-2015, 06:52 PM
#22
1987 32' Excella
Nepean
, Ontario
Gee, that almost sounds like the way my 87 Excella is set up! Fresh water is 55 gal, gray 35 gal waste 30 gal. I have 365 watts solar feeding into 2 4D-sized AGM batteries with a Xantrex FS3012 charger/inverter as well as a blue-flame heater. The shower head is Oxygenics, which gives the feel of a *real* shower. The older (1980's) AS layouts provided less open spaces and more storage/useful spaces, such as a shower with a sit-down bench and a built-in laundry hamper.
I find the only limited factor to be the waste tank - when it's full I need to find a dump station. I carry a couple of 5-gallon water jugs, which I fill whenever I find a water spigot, and then I transfer it to the fresh water tank.
Most of my boondocking is during the winters in AZ & NV.
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
10-05-2015, 08:23 PM
#23
Superior
Does the hivemind think that sprayed-in insulation would improve the R-Value? Just curious.
Thank you to the OP for this valuable thread. I've bookmarked it so I can keep track of what not to forget on my Streamline rebuild. We boondock 75% of the time.
1972 33' Streamline Emperor Crown Imperial
1949 30' Spartan Royal Mansion
2012 Nissan Armada
Most of China
10-05-2015, 08:30 PM
#24
Nomadic
, USA
I don't think it's viable, especially if you boondock. All the spray in generally hardens, not all, but most. And then imagine it cracking after a few dirt roads.
10-05-2015, 08:42 PM
#25
1987 32' Excella
Nepean
, Ontario
The yellow fiberglass insulation used in the manufacture of stoves has a much higher R value than pink fiberglass. I had an acquaintance who manufactured pizza ovens and he used the denser yellow fiberglass.
I recall a contractor who made commercial equipment trailers for use in the far north (in the arctic where temperatures went as low as -50C), and they had a subcontractor who sprayed some kind of foam insulation which was shaved down to about4 or 5 inches thickness before the inner panels were installed. However, these trailers did not travel long distances over all kinds of roads like our AS trailers do.
VE3JDZ
AIR 12148
WBCCI 8080
10-05-2015, 08:50 PM
#26
2015 30' FB FC Bunk
Ayer
, Massachusetts
There are two types of spray foam insulation: open cell and closed cell. Open cell is soft and pliable, closed cell is hard and rigid.
So you can get around the issues with spray foam. The real issue is the magnificent conductive properties of aluminum - basically it is one of the worst possible choices for insulation. Sadly, a wood frame SOB would fare much better in a cold climate. Don't belive me, then tell me that time you all saw wood wires.
Let's face it, we love our Airstreams because they are so damn cool.
10-05-2015, 09:18 PM
#27
2012 25' Flying Cloud
Battle Lake
I would like to see the Eddie Bauer 25/27 concept reworked as a traveler/boondocker edition, many of the items mentioned without the decorator influence. Just the goods. Call it the Airstream Traveler, designed for travel capability and comfort, not showroom bling.
Doug and Cheryl
10-06-2015, 11:29 AM
#28
1973 Argosy 24
Kitchener
, Ontario
Originally Posted by barts
Regarding #9....
A little extra PEX and a small circulation pump would permit the hot water to be a circuit rather than a bunch of home runs; this is what hotels do so you don't wait forever for hot water.
The best way to extend range of both fresh and gray water tanks is to use less; a true low flow shower head makes a huge difference.
- Bart
Like the return line idea. a smaller diameter line would work too. As for using less water you have not met my DW.
10-06-2015, 02:36 PM
#29
1975 31' Sovereign
Palomar Mountain
We like to boondock a lot. Found that the limitation was the freshwater tank.
We can go about a week on black tank being careful and can usually dump the gray water tank most places (use garden hose).
But we were always cutting short our stay to get fresh water tank filled. Filling a 35 galleon tank using a 5 galleon jug isn't fun. So, I bought a aluminum gas tank from Northern, put it in the back of my truck - now we can last a week being careful with the water use.
Bought one that is only 9" high so doesn't take up much room, in fact is the same height as my Aux. fuel tank in the back so makes for easy storage in the bed (have camper shell).
10-07-2015, 10:57 AM
#30
Nomadic
, USA
Just thought of something, a urinal or funnel that carries #1 outside the Airstream. So while we've been boondocking for the past 14 days, I usually go out behind a bush. But it's starting to get cold, and I just had the thought that it would be nice if I could do so from within side the Airstream. Maybe an external hose that could feed away from the Airstream.
10-07-2015, 01:10 PM
#31
Battle Lake
Standard equipment on military fighter/attack aircraft. Could be stinky outside the camper after a while if staying in the same spot long.
Doug and Cheryl
10-07-2015, 01:15 PM
#32
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Bold I think those are the good ideas we think about but not write about.
;o) ;o)
Hittenstiehl
10-07-2015, 01:20 PM
#33
2007 22' International CCD
Corona
Meh. A transmission funnel from the auto parts store, vinyl flex tubing, and a strategic hole in the floor somewhere. Cue the theme from 'Top Gun' .....
Whatever works.. Beats going outside in cold weather. 😄
10-08-2015, 09:46 AM
#34
Nomadic
, USA
If you have a composting toilet, you still gotta go outside and dump that urine.
Speaking of a composting toilet. There is an idea. Maybe under the guise of the "green" movement, you could convince Airstream to do a "boondocking" Airstream.
Ok, this example is based on my 27 footer.
Self Sufficiency with a real solar setup, not that joke they install. 4x 100 watt panels. No, A/C provided. But 3 roof fans. 4x 6V batteries not on the tongue, with 400amphr. 1000 watt hybrid inverter.
Environmentally friendly waste management; offer a composting toilet, no black tank. In its place larger fresh water with a larger gray water tank.
Improve R value of the trailer, use a recycled based insulation.
Throw in some of the other things mentioned here, low flow/water saving faucets. Preferably ones with the option to disable the low flow. So you can switch back and forth.
Lift kit, 16 inch wheels come standard with 1 inch additional ground clearance. (not sure it's huge, I still manage, but there have been a few spots where I winched as I drove over a rock or dip)
I'm not sure about tongue weight, since it varies unit to unit. But could we consider returning to aluminum propane tanks, and larger tanks on smaller units. Like two 40lb aluminum tanks on my 27. Might work if the batteries aren't there, perhaps relocate spare tire.
Just random thinking today.
10-08-2015, 10:46 AM
#35
1974 Argosy 20
Kooskia
, Idaho
Thanks for getting back on track to the subject of the thread, what Airstream could do to make a better boondocking trailer.
While I would agree that a better thermal package (insulation) would be nice, there is not much that can really be done in the 2" space available. I don't think it is reasonable to expect Airstream would re build the shell with more space for insulation considering the market. Even a composting toilet would be quite a stretch for them, and most users. (me included). Things like larger aluminum tanks are very much in the realm of possibility, along with more and larger battery bank. Of course the solar system Airstream provides needs vast improvements, which are easily done, if only they would do it.
I can even imagine deeper and stronger frames as a possibility. I love the 5" deep frame on my current FC 20'. They could also hold larger water and holding tanks.
So, again, the purpose of the thread is to propose ideas which are things which Airstream could do fairly easily to make a "Boondock package", not blue sky things which would fill the needs of a very limited number of buyers, or would require major re design of the basic trailer unit.
Thanks for all the input.
10-08-2015, 11:00 AM
#36
2007 16' International CCD
Somewhere
I will repeat my support for idroba's (the OP) request that we stick to things which have a higher chance of getting implemented by Airstream. In my opinion the key factors in this are modest amounts of engineering and tooling, and enough market to make it worth their investments.
Having said that, while I get that more/better insulation is a tough solution to see, the general problem of low energy efficiency remains a big problem: a large amount of electricity and propane are used just trying to stay warmish.
I do not know the answer to this question: how much would double-pane windows add to cost, and how much would they help?
10-08-2015, 03:55 PM
#37
1987 32' Excella
Nepean
, Ontario
Airstream has, in the past, equipped trailers with double (thermopane???) windows on special order; I have seen one. The window mechanism is substantially beefed up to handle the heavier windows.
VE3JDZ
AIR 12148
WBCCI 8080
10-08-2015, 05:08 PM
#38
2016 30' Classic
Hinckley
, Ohio
Subscribed
My budget won't stop me from buying something online that I don't need, but the threat of getting promotional
emails every day for the rest of my life just might!
10-08-2015, 06:57 PM
#39
Nomadic
, USA
Actually the could do better with the 2 inches. What they use now is an utter joke. And I don't say that lightly. Here is a photo of the BS in my Airstream:
Not only is this hole absurd and clearly cut by someone who is incompetent the material is falling off the wall. It's not thick and it's not stuffed. You'd be lucky if your insulation is still attached to your walls.
We have a friend who was redoing a 2000 Safari and he removed the interior walls, lined them with reflectix and then (I want to say R20 but I'm probably wrong) thicker insulation material.
So I disagree, Airstream could do a better job here. A way better job. They're being cheap on purpose. Becuase you can't see it.
Airstream pretty much wouldn't address any of these, so you might as well entertain blue sky stuff.
10-08-2015, 08:35 PM
#40
Full time Airstreamer
2014 30' FB FC Bunk
Anywhere
, USA Living.Somewhere.Yonder
Even with better insulation, it seems that exterior aluminum to aluminum ribs to aluminum walls is not the most energy efficient construction technique. Insofar as I know, there is no thermal break installed. Perhaps a rubber insulator between the ribs and inner walls would also help?
@living.somewhere.yonder | Instagram
