08-14-2014, 05:18 PM
Biloxi
, Mississippi
Yes, another Filaform thread
My new to me 2006 Safari has the dreaded filaform curse. Mainly it is on the the rear light housings. I have just spent the better part of an hour attempting to clean 1 sq inch. On the recommendation of the local Airstream dealership I used fine sandpaper, very fine steel wool and metal polish. Got most of the filaform off and somewhat polished. There has got to be a better way. There are literally thousands of post on this subject. Information overload. Does anyone have any helpful tricks to make this a bit easier job?
MICHAEL
08-14-2014, 06:32 PM
1960 33' Custom
Athens
, Georgia
I don't have any first hand experience with a tail light housing but I'd skip the steel wool. All you'll end up with is tiny bits of steel embedded in the housing which unsurprisingly will promote corrosion.
08-14-2014, 07:55 PM
Naples
Your tail light bezels need to be removed from the trailer, stripped and professionally polished on a wheel using bar based polishing compounds in ever finer grits. I did this to my then new '06 19CCD and they came out like chrome. Only needed a bit of polishing touch-up every now and then. Did the same to the rear bumper. The filliform showed up other places though, and remedial action was necessary there also, but you can't remove a skin panel to do what I did to the bezels.
lewster
08-14-2014, 08:07 PM
2002 30' Classic S/O
Fleming Island
In addition to corrosion, the imbedded pieces of steel wool will rust. As a minimum, go to a marine store and get some bronze wool. And +1 for what Lewster says. You will never get them really clean unless you can get to the edges and you risk scratching the trailer finish unless you pull them. You can get a polishing wheel for one side of a two wheel grinder and the red and white polish compound bars will do a nice job. I've not done aluminum, but I did the stainless spokes of a boat steering wheel and they turned out great.
Al
08-14-2014, 08:54 PM
Biloxi
, Mississippi
I misspoke I actually used bronze wool left over from my boating days.
Lewster, I was hoping I would be able get by without pulling the housing. Guess that is what I will have to do to do the job right.
MICHAEL
08-14-2014, 10:30 PM
Naples
Polishing aluminum is a lot like polishing silver. Having also been a custom goldsmith for the past 38 years, I have done a bit of wheel polishing.
My go to compounds after sanding to 2000 grit are brown tripoli followed by blue rouge. For aluminum, I use a middle buff of black rouge.
The sanding is done with 3M Trizact micro finish papers. Works wonders!
Lew Farber
AM Solar Certified Installation Center
Lifeline Batteries**Magnum Inverters
541-490-6357
lewster
08-14-2014, 10:36 PM
2002 19' Bambi
Lafayette
I am afraid I always have to chuckle about steel wool imbedding itself into aluminum. Maybe I have no idea what people do with the stuff, but I have used steel wool on every surface imaginable, including lots of aluminum, and never had the supposed "imbedding" problem. Of course you wipe the item down after using steel wool and if you are really nervous, use a magnet to get the last possible crumbs. Sealing with wax or something similar afterwards is also a good idea, not because of rust, but because the aluminum can quickly oxidize under the wrong conditions.
If you use steel wool for polishing, the best is 0000 of a high quality like that from Liberon.
Of course, Lewster is right that the best is solution is a buffing wheel with the right compound(s).
Tim
08-16-2014, 08:03 AM
Biloxi
, Mississippi
Did a little searching on the internet. I found several recipes for filaform removal. Most recommended vinegar and lemon juice. No lemons in the house so applied straight vinegar with a rag. It actually worked. Because the filaform is under the clear coat it lifts the clear coat and corrosion from the surface. It does not appear to effect non corroded sections. With a bit less effort it is easier to remove the corrosion. Next step is to begin polishing and touch up the clear coat. If it turns out bad I may still have to resort to removing the housings. Life is one big experiment. Some times we get it right and sometimes we have return to step one and try it again.
MICHAEL
08-16-2014, 01:50 PM
1999 34' Excella
Hillsboro
Get some Nyalic! That is a plastic spray "clear coat"
Peace and Blessings..
Channing
WBCCI# 30676
08-16-2014, 02:09 PM
2007 23' Safari SE
2016 23' International
Fernandina Beach
This whole discussion is pathetic. I'm sorry, but haven't we heard of documented cases where Thor replaced these items under warranty; They have de facto admitted fault for producing a defective product. Time we all put away the grinding wheels and polishers, toxic chemicals and join together to demand a fix for this crap. Sorry, but I'm sick and tired of those owners making excuses for a manufacturer's crappy product and proposing self fixes. Enough is enough. Would never recommend this product to ANYONE who wants to enjoy leisure travel. Its no fun "maintaining" a product that is self destructing.
So happy I have opted for a nice Class-B with a modicum of quality on par with high end automotive products. I'd like to think my Safari will still provide years of enjoyment for the younger members of my family, but they shouldn't have to put up with this crap either. Sure there is some maintenance on my Roadtrek, but nothing like what Airstream owners are putting up with. Lets start a thread about joining together to sue or at least advertise the fact that thor makes a defective product. If nothing else, maybe future owners will benefit.
08-16-2014, 02:12 PM
2007 23' Safari SE
Fernandina Beach
Why the heck does thor not treat the edges with this product prior to shipping?!
08-16-2014, 04:36 PM
2017 25' International
Los Osos
Rumor has it that there may have been confidential settlements with strict non-disclosures designed to protect the brand.
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
08-16-2014, 05:11 PM
Biloxi
, Mississippi
I did not start this thread as a platform to bash Airstream or to discuss law suits. But to get practical answers to my problem. Please feel free to start another thread if you wish.
Thank you,
MICHAEL
08-16-2014, 05:12 PM
Biloxi
, Mississippi
Thank you, I will check into that.
MICHAEL
08-16-2014, 05:33 PM
Airstream - Other
Bosque Farms
, New Mexico
You know, given that these are very small areas, has anybody considered simply a small bottle of paint-on clear nail polish to recoat the small spots? It is effectively a lacquer paint, dissolved by acetone.
Lynn
ACI Big Red Number 21043
08-16-2014, 05:37 PM
Los Osos
Nyalic....looks promising.
We live a few miles from the ocean and the tail light castings, porch light hood, grab handle and wheel well trim corroded very quickly....within a few months on my 2013.
I'll give this a try on my new trailer.
Nyalic®Â*ClearÂ*SurfaceÂ*Protectant
08-16-2014, 05:39 PM
Los Osos
Lynn
Airstream.com sells an acrylic pen that is intended for use over a CorrosionX treated small filiform squiggle. Very easy to use.
08-18-2014, 08:38 PM
2012 30' Flying Cloud
San Antonio
AWchief, here are some repairs to the cast pieces that always cause problems early--tail lights, door hinges, boarding handle. It does not take much effort at all to sand the existing clear coat and filiform--that is on the AL surface directly under the clear--from these castings using 1000 grit wet/dry paper. If you need to go faster, use 600 and then go back over with 1000 or 2000. These pieces shown are re coated with Nyalic. You can brush or spray and because it is very thin, it flows very well and comes out nice. These tail light castings here were taped off and sprayed, the handle and hinges were brushed on with a small 1/2 inch artiest brush for oil paint. The tail lights would be easier if you removed them, but if not, just tape off the skin and plastic lenses real well so as to not sand the wrong thing and you should be OK. GOOGLE Nyalic and you can buy it direct. I suggest you just buy a spray can or two and if you want to brush paint, spray some into it's own lid and paint from there.
Nyalic is a polymer and will not break down like an acrylic, lacquer or plastic will. It is softer and will be effected by more solvents (alcohol is one and we use that to clean up after caulking with ParBond, etc), but it is bullet proof against UV and salts. If you really want the mirror shine and don't mind keeping them polished, follow the advice above and just clean them up, buff them to the shine you want and polish. But you will have to keep after them as you would a vintage Alclad trailer that is polished and not clear coated.
Dremel sells small buffing wheels that work great on small areas removing the clear coat and filiform. They leave the aluminum underneath polished and ready to re-clear coat. But for the whole tail light casting, you will probably have to, at least, finish the filiform removal with the sand paper just to insure a consistent looking surface. Good luck.
Howard
08-18-2014, 09:30 PM
2005 28' Safari S/O
Paradise
x2. I used this on my grab handle and door hinges after cleaning and polishing with my Dremel, and have been happy with it so far after about 1-1/2 years.
Steve
"THE OLDER I GET, THE BETTER I WAS"
08-18-2014, 10:25 PM
2015 25' FB Eddie Bauer
2013 25' FB Eddie Bauer
2012 20' Flying Cloud
Small Town
Lynn
Yep; use it all the time - even as sealer / thread locker also. See my earlier posts for using nail polish "dots" as witness marks, too.
