Old 08-16-2014, 05:33 PM   #15
eubank's Avatar
1967 30' Sovereign
1999 31' Land Yacht
Bosque Farms , New Mexico
You know, given that these are very small areas, has anybody considered simply a small bottle of paint-on clear nail polish to recoat the small spots? It is effectively a lacquer paint, dissolved by acetone.
Lynn
WBCCI 21043
Old 08-16-2014, 05:37 PM   #16
interstateflyer's Avatar
2017 25' International
Los Osos , California
Originally Posted by cwf View Post
Get some Nyalic! That is a plastic spray "clear coat"
Nyalic....looks promising.
We live a few miles from the ocean and the tail light castings, porch light hood, grab handle and wheel well trim corroded very quickly....within a few months on my 2013.
I'll give this a try on my new trailer.
Nyalic«┬*Clear┬*Surface┬*Protectant
2017 Airstream International Serenity 25FB
2016 RAM 2500 Crew Cab Cummins 6.7 Diesel
interstateflyer is offline   Reply With Quote
Old 08-16-2014, 05:39 PM   #17
Lynn
Airstream.com sells an acrylic pen that is intended for use over a CorrosionX treated small filiform squiggle. Very easy to use.
Old 08-18-2014, 08:38 PM   #18
Howard L.'s Avatar
2012 30' Flying Cloud
San Antonio , Texas
Originally Posted by AWCHIEF View Post
My new to me 2006 Safari has the dreaded filaform curse. Mainly it is on the the rear light housings. I have just spent the better part of an hour attempting to clean 1 sq inch. On the recommendation of the local Airstream dealership I used fine sandpaper, very fine steel wool and metal polish. Got most of the filaform off and somewhat polished. There has got to be a better way. There are literally thousands of post on this subject. Information overload. Does anyone have any helpful tricks to make this a bit easier job?
AWchief, here are some repairs to the cast pieces that always cause problems early--tail lights, door hinges, boarding handle. It does not take much effort at all to sand the existing clear coat and filiform--that is on the AL surface directly under the clear--from these castings using 1000 grit wet/dry paper. If you need to go faster, use 600 and then go back over with 1000 or 2000. These pieces shown are re coated with Nyalic. You can brush or spray and because it is very thin, it flows very well and comes out nice. These tail light castings here were taped off and sprayed, the handle and hinges were brushed on with a small 1/2 inch artiest brush for oil paint. The tail lights would be easier if you removed them, but if not, just tape off the skin and plastic lenses real well so as to not sand the wrong thing and you should be OK. GOOGLE Nyalic and you can buy it direct. I suggest you just buy a spray can or two and if you want to brush paint, spray some into it's own lid and paint from there.
Nyalic is a polymer and will not break down like an acrylic, lacquer or plastic will. It is softer and will be effected by more solvents (alcohol is one and we use that to clean up after caulking with ParBond, etc), but it is bullet proof against UV and salts. If you really want the mirror shine and don't mind keeping them polished, follow the advice above and just clean them up, buff them to the shine you want and polish. But you will have to keep after them as you would a vintage Alclad trailer that is polished and not clear coated.
Dremel sells small buffing wheels that work great on small areas removing the clear coat and filiform. They leave the aluminum underneath polished and ready to re-clear coat. But for the whole tail light casting, you will probably have to, at least, finish the filiform removal with the sand paper just to insure a consistent looking surface. Good luck.
Howard
ID:	219340   Click image for larger version
ID:	219342   Click image for larger version
Howard L. is offline   Reply With Quote
Old 08-18-2014, 09:30 PM   #19
TinShack's Avatar
2005 28' Safari S/O
Paradise , California
x2. I used this on my grab handle and door hinges after cleaning and polishing with my Dremel, and have been happy with it so far after about 1-1/2 years.
Steve
"THE OLDER I GET, THE BETTER I WAS"
TinShack is offline   Reply With Quote
Old 08-18-2014, 10:25 PM   #20
mefly2's Avatar
2015 25' FB Eddie Bauer
Lynn
Yep; use it all the time - even as sealer / thread locker also. See my earlier posts for using nail polish "dots" as witness marks, too.
Paint.......yes another thread..... Flysoncloud Upholstery, Blinds, Walls & Interior Finishes 12 04-28-2011 08:22 AM
Yes, another service manual question - 1971 63Airstream 1970 - 1978 Globetrotter 2 01-16-2007 08:11 AM
Household chemicals Yes, yes or No, No? thecatsandi On The Road... 3 03-27-2006 07:01 PM
Mudflaps--yes or no ? Kistler Our Community 8 07-11-2003 06:07 AM
Sheet, yes! Don in E Texas Our Community 0 07-06-2003 05:07 AM
