Old 01-25-2015, 11:38 AM   #1
jimvn
1972 27' Overlander
Colorado Springs , Colorado
Window rivets
I have a 72 Airstream. Want to replace plastic brackets that hold push bar that keeps windows open. Have the brackets. What brand/style/size rivets should I purchase? Have seen this replacement done with screws. Any comments on that?
jimvn is offline   Reply With Quote
Old 01-25-2015, 12:02 PM   #2
Tom Nugler's Avatar
1972 25' Tradewind
McHenry County , Illinois
I used aluminum pop rivets about a 1/2 inch long.
On mine I found the predrilled holes on the replacement supports did not line up exactly with the originals in the window frame. Check the fit on one before you start
Tom
AirForums # 2806
WBCCI / VAC # 6411
Not All Who Wander Are Lost.
Avid supporter of trailing edge technology.
Tom Nugler is offline   Reply With Quote
RIVETS, Rivets, and rivets Over59 Ribs, Skins & Rivets 31 10-06-2015 01:53 PM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 09:33 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 02:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 11:00 PM
