Old 03-04-2009, 07:43 AM   #1
CLOUDSPLITTER "Tahawus"
ROBERT CROSS's Avatar
Zanadude Nebula , Milky Way
Why aluminum ?
What with all the concern the last few years about the exterior breakdown of the Alcoa product now being used, could anyone with more expertise than I in the manufacturing process and other alternatives available explain why
Alcoa is still being used.
Is it Heritage, cost, or the fact that silver is just cool.
How about a "plastic" Airstream with one of the new high tech coatings colored silver. Lighter, stronger, less potential for leaks.
Do you think stainless is an option?
What do think Wally would do, considering all the manufacturing options available today?
PFC
"Tahawus"
but Iím the Husband, so we went to Cleveland. 😂
RLC
Step aside Starbucks, this is a job for alcohol.
Old 03-04-2009, 07:53 AM   #2
SteveH's Avatar
Common Sense , Texas
I believe it is, and always has been weight and strength.
Plastic would not be as strong. Think about what a rivit would do in plastic when stress was put on it....the hole would wollow (sp?) out and then the stressed skin strength would be gone. Also, to get plastic as ridgid as aluminum, it would have to be much thicker, and then also much heavier.
Old 03-04-2009, 08:25 AM   #3
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Alcoa is an aluminum manufacturer, It produces all variety of different aluminum alloys. Who's at fault with the corrosion issues is for the lawyers to decide. Why don't we use newer plastics or composites? Most likely production costs and durability. Composite curved panels produced in a controlled environment or autoclave would drive production costs through the roof and repair cost would be astronomical. Plastic and composite materials are incredibly strong but you do give up alot of the durability that is achived using aluminum. Aliminum will bend but you still maintain the security and integrety of the trailer for continued use but with cosmetic issues. Plastic and composite will just shatter and delaminate and structural integrety is lost along with moisture intrusion. Look at the life span of all of the SOB's out there made with composite flat panel construction, its not going to be nearly as long as a Airstream. IMHO Airstream needs to scrape the current plastic coated alloy that they are currently using and return to the 2024-T3 of times past. I guess that would be very close to an adminision that they had a problem to begain with.
Old 03-04-2009, 08:51 AM   #4
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
Stainless would be WAY too heavy and defeat one of the 'pluses' of AS - economical towing. You'd need a BEAST of a TV to pull a stainless trailer!
A 12" by 12" by .10" thickness of stainless steel is about 4 lbs, aluminum is about 1.4 lbs.
It IS fascinating though how many people out there think that AS is a stainless trailer. We must tell 10-15 people every year in various campgrounds that they are aluminum and not stainless.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 03-04-2009, 09:12 PM   #5
unpolished
Cadillac's Avatar
1975 29' Ambassador
Des Moines , Iowa
Silver is just cool.
Cadillac is offline   Reply With Quote
Old 03-04-2009, 09:50 PM   #6
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Why, Oh Why!!!
Can you say.... "Have you ever seen a 60 year old fiberglas TT?" I knew you could! But! Have you ever seen one that was brought back to life? I bet very few if any. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-04-2009, 10:13 PM   #7
pauly g's Avatar
1960 22' Safari
Oceanside , California
Titanium would make a great shell if we had budgets like the space program.
pauly g is offline   Reply With Quote
Old 03-05-2009, 05:17 AM   #8
Points well taken.
But is there a better aluminum alloy that could be used?
Iv'e been told that Alcoa has a product that is more durable, would not add the extra weight and is much more corrosion resistant.
PFC
"Tahawus"
RLC
Old 03-05-2009, 05:39 AM   #9
SteveH's Avatar
Originally Posted by ROBERT CROSS View Post
Points well taken.
Don't know, but I'd bet it has to do with cost????
Old 03-05-2009, 06:32 AM   #10
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
True
While it was not 60 years old...
The very first plastic trailer (from the 60's?) was just mention on this forum??
Somewhere on the West Coast??
The wealthy owner had it completely restored recently..
Why aluminum indeed..
Titanium rules~
Oh, forget that.. you could not have a mirror finish..
WBCCI 5292 AIR 807
NEU #64
New England Unit
53flyingcloud is offline   Reply With Quote
Old 03-05-2009, 06:57 AM   #11
Aerowood's Avatar
Arvada , Colorado
Originally Posted by robert cross View Post
points well taken.
Iv'e been told that alcoa has a product that is more durable, would not add the extra weight and is much more corrosion resistant.
2024-t3, 6061-t6
Old 03-05-2009, 07:07 AM   #12
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
2024-T3 is what vintage trailers are made with...if you go that route you could then polish!
Then you can really be "Lost in the Sixties" ~
Shari
Old 03-05-2009, 07:07 AM   #13
1984 29' Sovereign
Savannah , Missouri
The way I see it..You have several options..One of which is.
If everyone that owns a "problem trailer" towed it back to J C and, left it there, with a polite demand that, it be fixed..
The sheer numbers alone would be overwhelming and, I suspect..
would soon get National attention..Least of all, CNN?
WBCCI 5292 AIR 807
NEU #64
New England Unit
Old 03-05-2009, 07:23 AM   #14
Originally Posted by InsideOut;673534
Then you can [I
really[/I] be "Lost in the Sixties" ~
Shari
Kind'a like this I suppose....If I knew then what I know now.
Name:	Copy of Goodbye old friend.jpg
PFC
"Tahawus"
RLC
If you are into aluminum you must see this! RichardT Off Topic Forum 22 11-06-2015 07:55 PM
Is Aluminum Aluminum Ganglin Ribs, Skins & Rivets 6 06-26-2007 09:47 AM
Too much aluminum wayne.yl Ribs, Skins & Rivets 13 03-28-2007 05:11 PM
old aluminum and new aluminum hill4th@gvtc Ribs, Skins & Rivets 6 08-03-2006 07:00 PM
How much Aluminum is in my AS trogers713 Our Community 6 04-30-2004 01:08 PM
