Old 06-19-2014, 08:09 PM   #1
Which Roof Edge to use?
Building a canned ham style with Airstream construction methods.
Question. Roof Edge. I'm torn between these two styles.
1. Standard
RV Teardrop Trailer Roof Edge Door Jamb Liner Molding | eBay
Would show off my pretty bucked rivets.
Trempro or Butyl Tape?
2. Vinyl insert
RV Teardrop Trailer Insert Type Roof Edge Molding | eBay
Would this be significantly better at preventing leaks?
Bucked or Pop rivets? I guess you would still use bucked?
Which one would be prettier? I think the standard...
I need guidance.
Thanks for any advice.
Name:	Screen Shot 2014-06-19 at 9.01.07 PM.png
ID:	214506   Click image for larger version
Name:	Screen Shot 2014-06-19 at 9.01.21 PM.png
bass-o-matic is offline   Reply With Quote
Old 06-19-2014, 08:10 PM   #2
1981 31' Excella II
New Market , Alabama
For what application?
Perry
Old 06-19-2014, 08:35 PM   #3
For the joint where the roof meets the sidewalls.
Do I have the right idea?
Old 06-20-2014, 10:55 AM   #4
1981 31' Excella II
Well typically the second type is used. The first type would have to be attached from the sides which might be better from a leak standpoint. The second one would have screws coming in from the top and then the plastic insert to cover the screw heads. I don't like this method of construction because of the extreme likelihood of a leak. The screws would be visible on the first one. If you used stainless pan head screws that may not be an issue though. If you used the first one and put some sort of rubber material around the corners it might help with leaks. I remember having square box trailers in Florida and you could watch them rot from all the leaks. An all aluminum frame inside the walls would prevent wood rot.
I would use Tempro for the sealant. I don't like tapes. They will gap and leak.
Perry
Univolt internals - which fuse is which? barts Batteries, Univolts, Converters & Inverters 9 08-13-2017 09:18 AM
Dump Valves Which is back and which is grey? clicker187 Waste Systems, Tanks & Totes 7 01-16-2013 08:15 PM
Anyone use liquid roof for fiberglass roof repair? 442 john Airstream Motorhome Forums 4 01-02-2013 01:23 PM
Which tank is which? dejahardy13 Fresh Water Systems 8 09-24-2010 09:23 PM
Which switch is which or what 74Sovereign Electrical - Systems, Generators, Batteries & Solar 6 09-10-2002 08:55 AM
