Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-15-2007, 06:51 PM   #1
48_liner's Avatar
Profile:  1948 22' Liner
Squaw Valley , California
Which Rivets?
We're replacing a lot of exterior panels and have received rivets from Aircraft Spruce which have a four digit number cast into the head. I've read elsewhere that this was the place to purchase them but I'd rather have the smooth heads like the originals. We've emailed them but have had no response. Anyone out there know where to get the correct ones?
48_liner is offline   Reply With Quote
Old 05-15-2007, 07:38 PM   #2
Profile:  , Minnesota
Images: 59
Airstream Registry
Never seen those. Wouldn't the numbers get smooshed when you set the rivet?
I got mine at Aircraft Tool Supply. Go into the catalog under rivets, somewhere around page 9
markdoane is online now   Reply With Quote
Old 05-15-2007, 09:17 PM   #3
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Airstream Registry
what are the numbers on the head? What shape if any is the marking in the center?
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 05-16-2007, 07:34 AM   #4
48_liner's Avatar
I'm checking in at work so I don't have access to the rivets. They have a four digit number / letter sequence cast into the head. It curves around the top of the head. We practiced with four of them as I thought maybe they would smash in when bucked but they didn't. I'll try to post a photo of one tonight. I would'nt advise anyone to purchase rivets from Aircraft Spruce. We haven't heard back from them yet.
Old 05-16-2007, 08:36 AM   #5
Always Airstreaming!
rickandsandi's Avatar
Profile:  2005 22' Safari
1960 24' Tradewind
Anytown , Connecticut
Send a message via AIM to rickandsandi
Greetings,
Many of us vintage owners have been using the Olympic rivits for the outside rivit repairs and replacments.
They are the closest to the original buck rivits used at JC. Once the old rivit is drilled out with a #20 wire size drill, these rivits fit perfectly into the #20 hole. Once rivit is in place it is then shaved and leaves a very nice rounded rivit head.
J. Rick Cipot
Sandi Gould
NEU New England Unit
Airstream Life Magazine
WBCCI #3411
AIR #17099
2009 Silverado 2500HD
2004 22' Safari
1960 24' Tradewind
rickandsandi is online now   Reply With Quote
Old 05-16-2007, 09:37 AM   #6
Missoula , Montana
Airstream Registry
Why not purchase from aircraft spruce?
Michelle
Sarah and Snowball
Old 05-16-2007, 10:51 AM   #7
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
Airstream Registry
What is the part number that you ordered? Are they solid shank rivets or blind rivets?
Old 05-16-2007, 09:04 PM   #8
48_liner's Avatar
We ordered the shank rivets that are used for bucking. No interior panels makes it easier to do it the original way. Here's a shot of the rivets after we bucked them in and polished the panel.
Name:	New Rivets Opt.jpg
Old 05-17-2007, 12:31 AM   #9
janetb's Avatar
Profile:  2007 25' Safari FB SE
Santa Cruz County , California
I'm just astounded that you are working on a 59 year old trailer. I think that's the oldest A/S I've seen posted on the forums since I joined.
What a phenomenal gift---and responsiblitly!
Best of luck,
Janet
janetb is offline   Reply With Quote
Old 05-17-2007, 07:09 AM   #10
Aerowood's Avatar
Arvada , Colorado
Airstream Registry
Those do look like MS20470AD5-X rivets but they shouldn't have lettering on the head. I would return them and try this place
Genuine Aircraft Hardware Co.
Old 05-17-2007, 11:52 AM   #11
48_liner's Avatar
Aerowood,
Thanks for the reply. My wife and I are going to keep the rivets and use them on other projects. Since we have the rivet gun and will end up with a lot of left over aluminum, she said we could make flower pots, bird houses etc.....
Prior to this past weekend we were going to have to replace all the exterior skin with the exception of the 13 panel end caps. Since the trailer was painted several times we spent the weekend stripping off the paint and found several areas where the corrosion from the inside had made it's way to the outside of the skin. Out of 26 panels, we're going to have to replace all the rear panels plus 3 on the front. If the rear goes well we might just do the entire front and have an entirely new exterior skin. The further we go, the worse it gets . At least it's going to be really easy to polish when it's done .
Old 05-17-2007, 03:48 PM   #12
Aerowood's Avatar
Arvada , Colorado
Airstream Registry
Your Liner is most likely made from Duraluminum 24s and todays equivalent is 2024, the new numbers went in effect in 1954.
Old 05-22-2007, 06:44 PM   #13
48_liner's Avatar
Here we go again. Just got my box of rivets from Aircraft Tool Supply and they are identical to the ones from Aircraft Spruce. Same color with the same digits cast into the heads . I did get a reply to my email from Aircraft Spruce. They pretty much said that what I got is what they have. Very bland and non personal. I emailed Aircraft Parts and hope to hear something better in a more timely manner.
With Memorial Day coming up I guess I can afford the wait.
At least the Midget Trailer will take us to Pismo Beach for the weekend.
Old 05-22-2007, 07:18 PM   #14
Images: 59
Airstream Registry
I've ordered rivets several times from Aircraft Tool Supply and they always came in a plastic bag. Usually they are gold or bronze colored because of the manufacturing process.
Never had any with numbers on them. Can you tell us the part numbers you ordered? Maybe they were top secret military spec stealth rivets.
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Olympic rivets JPAIRSTREAM Ribs, Skins & Rivets 2 09-30-2002 07:21 PM
Rivets and Karma Joan D'Andrea Our Community 4 09-19-2002 07:43 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
