Old 03-09-2005, 03:48 PM   #1
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Angry Which rivets?
I wrote to Airstream to ask what size rivets I would need to re-attach the vinyl rubrail strip to my Argosy. They emailed me saying I needed the 1/8 inch with a #30 drill bit. There are about 5 different 1/8 inch rivets listed on their site. Which one do I need? What is the #30 drill bit for. Judy
juel is offline   Reply With Quote
Old 03-09-2005, 04:07 PM   #2
Judy.
A #30 drill bit is used for 1/8 inch pop rivets.
On the exterior of your Argosy, you can use #48 pop rivets. The 4 is the diameter in 32nds, and the 8 is the grip range in sixteenths of an inch.
Make sure you use all aluminum rivets.
Old 03-09-2005, 04:25 PM   #3
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Thank you for your answer. Now can you tell me which rivets I should order from Airstream. They don't come in that kind of numbers. They all have letters behind them like ABS, etc.. If you sell these rivets I'll be happy to call Inland. I have the number memorized!!!! I'm going to be using these rivets to put the rubrail vinyl insert back on. The rivet has to go thru an aluminum strip, a vinyl strip and then into the skin. Will the #48 be long enough? Judy
Old 03-09-2005, 04:37 PM   #4
atvmcg's Avatar
1979 23' Safari
Send a message via Yahoo to atvmcg
try byler rivet company and get a catalog..you'll need an assortment of rivets as time goes by
atvmcg is offline   Reply With Quote
Old 03-09-2005, 04:52 PM   #5
Judy.
You cannot buy any parts from Airstream, unless your in Jackson Center.
You must use an Airstream dealer.
By written agreement, Airstream will not sell parts to compete with their dealers, since they require dealers to stock parts.
However, in the case of an extreme emergency, that agreement can be overlooked by Airstream.
Old 03-09-2005, 05:06 PM   #6
Janet H's Avatar
1964 26' Overlander
1964 19' Globetrotter
Eastern , Washington
Images: 90
Originally Posted by juel
..... The rivet has to go thru an aluminum strip, a vinyl strip and then into the skin. Will the #48 be long enough? Judy
You are putting rivets ONLY in the clips at each end of the vinyl insert - right?
Name:	insert clip web.jpg
AirForums Custom Search
Janet H is offline   Reply With Quote
Old 03-09-2005, 06:08 PM   #7
juel's Avatar
1976 31' Sovereign
Chandler , Oklahoma
Images: 24
Yes that just what I want to do. Judy
B190 Coach power problem Luckydog Sprinter and B-van Forum 21 11-12-2002 12:59 PM
Olympic rivets JPAIRSTREAM Ribs, Skins & Rivets 2 09-30-2002 07:21 PM
Rivets and Karma Joan D'Andrea Our Community 4 09-19-2002 07:43 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
Drilling out rivets... Andy R Ribs, Skins & Rivets 2 04-13-2002 03:02 PM
