Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 12-26-2007, 07:30 AM   #1
2001 19' Bambi
Concan , Texas
Where to buy rivets?
We just bought a 2001 Bambi and it is missing 1 exterior rivet. I have read through these forums and saw pop and Olympic rivets mentioned. Where do I buy them and do I also need to buy a tool to put it on?
cedboone is offline   Reply With Quote
Old 12-26-2007, 08:30 AM   #2
5 rivets, 1 loose screw
Rog0525's Avatar
1966 20' Globetrotter
Saginaw County , Michigan
Images: 11
Welcome aboard, cedboone. You need a 5/32 Olympic rivet. You should get extras to keep on hand. Vintage Trailer Supply is probably the least expensive place to buy them but they come in pkgs of 100. You should also get a tube of Vulkem and put a dab on the rivet when you install it. A standard pop rivet gun will do the job. You can shave the head with a Dremel tool if you have one.
I've used just an inexpensive mounted point in an electric drill to shave them, since I haven't had occasion to do very many. See pic below.
I'd be glad to mail you a few rivets if I had them, but I only have a couple left.
See step by step instructions on this thread.
Rog
May you camp where wind won’t hit you, where snakes won’t bite and bears won’t git you.
Rog0525 is offline   Reply With Quote
Old 12-26-2007, 08:34 AM   #3
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Welcome to the forums and the world of Airstreaming. You're sure to have a great time. If/when you buy Olympic rivets, its best to not get the ones with the rubber seal. Over time, this rots away and leaves a gap for moisture to get in. Do as Roger says and put a small dab of Vulkem around the rivet shaft before setting it in place.
FF
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 12-26-2007, 09:18 AM   #4
Inland's price is less than theirs.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-26-2007, 10:36 AM   #5
Rog0525's Avatar
Images: 11
Sorry, Andy, thus the word “probably”. It’s difficult to browse through your lengthy list of parts. One would have to know the shipping fees from both sources to determine the actual cost. Do you have Vulkem? The 5 oz aluminum sealer on your site doesn’t list a brand name or pic. I think I got a tube of Vulkem from you some time ago with the replacement water heater kit I ordered.
If I’m going to order Olympic rivets and Vulkem, I’d want to get both from the same place.
Rog
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
Rivets? gr63air Ribs, Skins & Rivets 1 07-07-2006 07:29 PM
Little Rivets.... Chuck Ribs, Skins & Rivets 4 06-07-2005 01:01 PM
To buy or not to buy, is that the question? ob1coby Our Community 1 06-24-2004 03:34 PM
