Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 08-05-2010, 08:48 AM   #1
2007 28' Safari SE
Westlake , OH
What's the Damage?
Just saw this. Ouch. A blemish on our otherwise perfect shell. What to do now?
Dent - A dent. Photo Gallery
TowAir is offline   Reply With Quote
Old 08-05-2010, 09:41 AM   #2
2019 28' International
Leonardtown , Maryland
One could go to Jackson Center, pay a small fortune and get it repaired or one could go camping.
_________________
Rebee - WBCCI #1325
2002 Classic Ltd 30'
2007 Dodge 2500, 6.7 Cummins
Rebee is offline   Reply With Quote
Old 08-05-2010, 09:44 AM   #3
That's why you have insurance (hopefully).
Jackson Center, is your best bet, for replacement.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-05-2010, 10:05 AM   #4
2007 28' Safari SE
Westlake , OH
the clearcoat is not damaged, there is no metal damage, just a bend. Not a hard crease. Should I try to ding it back from behind with a rubber mallet?
Old 08-05-2010, 10:07 AM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
$1200 per segment at JC, or live with it. DO check the seam VERY carefully for leaks and re-seal for general purposes anyway.
IMHO you MIGHT repeat MIGHT get most of it out by rolling from the inside with something soft like an under-inflated basketball or a rubber wheel (adapted from a wide bed roller, etc). You'll have to take down the inside wall to get to it, but IF you have an overhead cabinet in the rear of your unit, it might be accessable from the inside of the cabinet via cutting an access hole and patching it after you finish. Suction cups will work from the outside if there isn't a crease, but you've got a light crease. You could still reduce it's appearance with either suction or a roller.... but the crease will still be somewhat visible.
Old 08-05-2010, 10:10 AM   #6
It is creased, and cannot be made to go away.
Replacement is the only answer, "IF" you want to trailer to look nice, "again".
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-05-2010, 10:20 AM   #7
Master of Universe
Gene's Avatar
2008 25' Safari FB SE
Grand Junction , Colorado
It's amazing how after a few months that crease won't be as noticeable when you forget about it for a while. I've got a 6" crease I stopped looking at and it doesn't bother me anymore. Give it some time and then make a decision.
Gene
Old 08-05-2010, 10:22 AM   #8
rubber mallet is likely to leave impressions ... or expressions if that's what you'd call an outward ding. Roll with a rubber ball, etc from within.
If there's not a solid line, parking it in the hot sun might make it pop out on it's own
Old 08-05-2010, 10:34 AM   #9
Wabbiteer's Avatar
Jupiter , Florida
Isn't that where the spoiler goes to force slipstream downwash over the back window and keep it clean?
The aluminum appears to have 'stretched' and needs to be left alone for 5 or 7 years so it can try and self-heal.
The days are short and the night is long and the stars go tumbling by.. . ~Airstream~
Old 08-05-2010, 06:33 PM   #10
1972 Travelux Princess 25
Cobourg , Ontario
It would be possible to push the dent out from inside but you would need to remove the inner panel for access.
I would ask around the local garages and body shops for "paintless dent removal" experts. Ask who is the best guy around, there are some real artists out there.
These guys push dents out of cars without touching the outside or damaging the paint.
Your dent would be a piece of cake for someone who is used to working on car sheet metal.
I am not saying they can make it like new, but they should be able to get 80% to 90% of it out and make it practically unnoticable. For a very reasonable cost.
Living in the trailer park of sense, looking out the window at a tornado of stupidity.
Ganaraska is offline   Reply With Quote
Old 08-05-2010, 06:55 PM   #11
Kevin245's Avatar
You might read this thread and check out posts 11 and 30 for examples of what can be done be experienced dent removal techs.
http://www.airforums.com/forums/f381...hit-59265.html
Good luck,
Kevin
William C. Swinney
Old 08-05-2010, 07:30 PM   #12
2007 28' Safari SE
Westlake , OH
Thanks for all your input, folks. I'm glad that I have a $250 collision/comprehensive deductible with Progressive. I got a quote for 2 panel replacement, and I think I might as well go ahead and use my insurance. After all, that's what we pay for, right?
And I will NEVER back up that trailer again without someone else outside, in view, with hand signals!
Old 08-05-2010, 09:53 PM   #13
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
I know a lot of folks will tell you it's not that bad and that you can learn to live with it. I couldn't, I'm sorry. I'm just not built that way. It would be all I see ... so I'm glad you are going to get it fixed. You'll be glad you did. Otherwise, why have insurance??
When backing up it's always good to have a helper ... but even then I have 2 rules: (1) If I can't see my back-up helper I don't move. It's not worth guessing. (2) Have agree-upon hand signals in place so your helper knows how to signal you what to do. Flailing of arms doesn't tell me anything. If I can't understand what's needed, again, I don't move.
Wait till your helper starts trying to swat mosquitoes or flies away at the same time. "WTH does THAT mean??"
TB & Greg and Abbey Schnauzer
AirForums #21900
PastPrez, 4CU/WBCCI
Old 08-07-2010, 10:59 AM   #14
Master of Universe
Gene's Avatar
You can use walkie-talkies. We have them and never use them of course.
Gene
Old 08-07-2010, 11:11 AM   #15
Gene
Gene.
The problem with audible directions, is that which way is "this way" or "the other way"?
Visual is superior, no question.
Ask any aircraft carrier pilot.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-07-2010, 11:16 AM   #16
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
OMGosh.....Barley noticeable. Chalk it up as a battle wound, a campfire story, or :JUST FORGETTA BOUT IT"
Shane
https://i52.photobucket.com/albums/g...h_postcard.jpg
Tow Vehicle" 2023 F250 Azure Gray!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 08-07-2010, 11:25 AM   #17
_
as good as the jc service center is at shell repairs...
and as annoying as that crease is currently,
there is simply NO WAY i would replace end caps for that.
IF you are that picky the repair WILL be obvious.
unless willing to pay EXTRA for bucked rivets.
yes the repair will remove the crease...
but so will TIME and travel.
add a rear awning and some stylish vinyl graphics...
then go camping.
cheers
2air'
Flood Damage / Please Help! andyfuson General Repair Forum 29 09-23-2009 09:26 AM
Furnace damage pjzuk Classic Motorhomes 2 07-25-2007 07:16 PM
How much damage is too much? kaulike Ribs, Skins & Rivets 8 01-20-2007 01:10 AM
Is this too much damage to fix? chickin Ribs, Skins & Rivets 23 06-04-2006 09:00 PM
door damage dikku@mac.com Doors & Locks 2 04-03-2005 02:25 PM
