Old 06-21-2010, 07:09 PM   #1
1956 22' Caravanner
Malcolm , Nebraska
What's the best way to remove rivets?
I am in the process of fixing the floor in my 1956 26 footer. I have repaired the floor on both sides, and in front of, the door without having to remove any rivets but am not so lucky around the front. My plan is to remove the belly pan and slide a 3 foot section of 3/4 inch plywood in from the outside.
I know I'll have to drill out the old rivets but would like to know how to best prevent from enlargeing the holes.
Thanks, Husker Dave
Husker Dave is offline   Reply With Quote
Old 06-21-2010, 07:34 PM   #2
arcamedies's Avatar
1993 30' Excella
Lakeland , Florida
Images: 69
I have used a dremel and it's easy to grind off the heads and push through, therefore no hole damage, just don't get carried away with the dremel.
arcamedies is offline   Reply With Quote
Old 06-21-2010, 08:32 PM   #3
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
There are at least a couple of threads on this. One size down on the drill. If I remember right 3/32 for 1/8 rivets. I think that may be also a #22 drill. I'm sure some one out there has the sizes at their fingertips. Andy?
If you don't have the patience for a Dremel I have gingerly used an angle grinder, if such a thing is possible. It ain't purdy but gets er done.
Old 06-21-2010, 08:42 PM   #4
1968 20' Globetrotter
Kelowna , British Columbia
I've been studying up on this since I'm doing the same thing next week. Most threads say #20 but Andy corrected that the size to use is #21.
Canlib is offline   Reply With Quote
Old 06-21-2010, 08:50 PM   #5
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
To remove 1/8" bucked rivets, drill into the head "only" with an 1/8" bit just to the skin, then use a punch inserted in the hole (or use the drill bit) and with a quick flick the head should pop off. A #30 bit is larger than an 1/8" hole and a #20 is larger than a 5/32" hole.
truckasaurus is offline   Reply With Quote
Old 06-21-2010, 08:55 PM   #6
tkasten's Avatar
1965 22' Safari
Vassar , Michigan
rivet removal
You can get a rivet removal tool from the Aircraft Tool Company Aircraft Tool Supply Company. It works like a charm. I used it on way too many rivets renovating our 65 22' Safari.... Tim
Tim
TAC MI 14
Everyday is a Saturday
tkasten is offline   Reply With Quote
Old 06-21-2010, 09:09 PM   #7
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
If you drill them, take a center punch and lightly tap the center of the rivet head first. That will keep the drill from "walking" and possibly damaging the skin. Then drill the head off and use a punch. With a new sharp drill bit, it is easy.
Old 06-22-2010, 08:13 AM   #8
1956 22' Caravanner
Malcolm , Nebraska
Thanks to each of you for your responses. The dremel tool and the rivet removal tool sounds like something I might try. Since I'm removing the rivets behind the curved cover strip it will be good practice for later when I start repairing a couple of windows.
How do I remove rivets? Zstream General Interior Topics 6 04-21-2008 09:26 AM
Lousy Rivets!/Weak rivets sunk the Titantic? 1956Safari Off Topic Forum 14 04-18-2008 01:35 PM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
How Do I Remove Rivets melprice General Interior Topics 1 05-31-2002 06:07 PM
