Old 03-09-2012, 06:18 PM   #1
Olivebranch's Avatar
1964 22' Safari
Omaha , Nebraska
What will it take to fix this?
How do I repair a gash like this, or how much should I expect to pay?
Olivebranch is offline   Reply With Quote
Old 03-09-2012, 06:21 PM   #2
Aviator's Avatar
1997 34' Limited
1970 27' Overlander
South of Atlanta , Georgia
I don't know about cost, but you will need a least one new section.
Craig and Carol
1997 34' Excella 1000
1970 27' Overlander, International
2009 Ford F150 5.4L
ProPride hitch with 1400# bars
AIR 41028
TAC GA-8
WBCCI 10199
Past President Southeastern Camping Unit (12)
Aviator is offline   Reply With Quote
Old 03-09-2012, 06:24 PM   #3
Baltimore , Maryland
... probably three. Do you have any photos from further back?
Old 03-09-2012, 08:12 PM   #4
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I'd bet on three panels on the outside. You may also need one on the inside. If you take it to Jackson Center I'd guess about $1400 per panel. $5600 total.
If you're insured they may total the unit for that much damage depending on the year of the Airstream.
You MIGHT, repeat might find another wrecked unit with the front segments intact - but mating them together isn't all that easy. Rivet holes are drilled by hand and won't match up between one unit and another. If this were even possible, you'd have to replace the whole front end (at least all 5 curved segments) or even include the bottom segments as well. I'd guess you'd need to replace the rib where the sections join, then spend a lot of time carefully sealing the seam while joining the whole shebang together.
Sorry about your damage. Paula
Old 03-09-2012, 08:14 PM   #5
1964 22' Safari
Omaha , Nebraska
I hope I don't need three!
Old 03-09-2012, 08:19 PM   #6
Originally Posted by Olivebranch View Post
Attachment 152933
Ball park cost is about $1200.00.
Those old segments were all sold to us many years ago, by Airstream.
Old 03-09-2012, 09:00 PM   #7
4RXLA's Avatar
1977 31' Excella 500
West Sacramento , California
Images: 33
I'm afraid it will be 3.
4RXLA is offline   Reply With Quote
Old 03-09-2012, 10:57 PM   #8
TouringDan's Avatar
1966 24' Tradewind
1995 34' Excella
Lynchburg , Virginia
This older lady (trailer) is 48 years old. I would say that if the panel with the gash in it were replaced that it would be good enough even though the adjacent panels are not perfect.
Dan
Old 03-10-2012, 06:48 AM   #9
1964 22' Safari
Omaha , Nebraska
Dan
Agreed, I am not looking for perfection right now I just want to get it sealed up. Is it at all possible to pull the dent out, re rivet the panels, and patch the gash for now with an overlay? I understand this won't look good, possibly hideous. Is it doable?
Also, does anyone know a good repair shop in Omaha, NE?
Old 03-10-2012, 09:39 AM   #10
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I would first see if I drilled some holes in the area that is pushed in, then screw some sheet metal screws into the holes with the heads above the surface. Get hold of the heads of the screws and pull as much of the damaged area out as possible. You may even be able to re install some of the rivets along the seam on the piece to the left. Put sealant along that seam before riveting. If you are successful at pulling most of the dent out you may be able to make a patch to prevent moisture from entering.
Once you get the area somewhat pulled out remove the screws and make a patch to cover the area where the holes are along with covering the tear in the skin.
I don't think you could do any further damage by trying it.
Old 03-10-2012, 09:54 AM   #11
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Is the interior endcap still in place? Is the window frame pushed in and distorted also? It is my experience on aircraft that you remove the obvious damage first and relieve the internal stresses in the adjoining structure before you determine how much you really need to repair or replace. As I see it the single panel replacement is a given, the others to be determined later.
Old 03-10-2012, 09:58 AM   #12
1988 25' Excella
Trumbull , Connecticut
Front Panels
Hello all. I had two of the front panels replaced, at P&S in Ohio, last year and they were $1,200 each installed.
Happy camping nm1oqrz
nm1oqrz is offline   Reply With Quote
Old 03-10-2012, 12:09 PM   #13
1964 22' Safari
Omaha , Nebraska
The interior shell is still in place and in good shape. The window and panels around the two damaged ones seem to be in good shape. Did the $1200 include materials? Did they have to remove the interior shell or did you do that?
I am in Omaha, does anyone know a good shop close or should I go to the dealer in DesMoines which is about 2.5 hours away.
Thanks for all the input. I think I will need to see what inland marine has for parts. Keep the thoughts coming!
Old 03-10-2012, 10:25 PM   #14
Sorry - I disagree with this - you'll just add more damage and holes. This technique will work on a car with steel panels. On aluminum, you'll just distort it in the other direction. If there's a cabinet inside you could remove it and push the segments out from inside. A soft basketball has been used with success by some.
The two panels on the side of the one that looks like it took a 2 x 6 through it - First look at the rivet holes. If a lot of them are pulled into ovals or split to the edge, then you'll never stop the leaking unless you use giant rivets or replace the panels. For a temporary fix you could mush the panels into roughly the right shape and overlay a patch where the hole is. (for a very temporary patch, get some aluminum tape (next to the cloth duct tape in the big box hardware stores and just tape it over. That could get you to Jackson Center for a prettier repair. THECATSANDI made an epic trip there after being hit by a state trooper!
Paula
How to store Acryl-R & Pump rbs Leaks - Weatherstrips, Gaskets, Caulks & Sealants 18 08-02-2017 09:36 AM
Is it best to purchase a new AS locally? Travel Bird 2011 - 2015 International 51 03-17-2013 03:52 PM
Is it worth it? RSantiago 1972 Overlander 51 07-11-2012 09:49 PM
Giant rock towed to Lakewood ROBERTSUNRUS Off Topic Forum 61 06-25-2012 08:58 PM
Well -- It's been a while! gypsychris Interior Restoration Forum 53 03-10-2012 10:25 PM
