Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 09-04-2006, 10:08 AM   #1
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
What tools & parts do I need?
I'll be getting my new '77 home this week and know I need to remove the door frame, belly pan and one skin panel by the door.
I was thinking
A center punch
Drill bits (what size)
Rivets what sizes length and dia
(I suppose the sealing alum pop type.)
Rivet gun, I have a compressor if it would help.
What di I need to cut off the stubs and do I need something to grind them down smooth?
What would your tool box have, and where would you buy them?
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 09-04-2006, 11:31 AM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
I was thinking
A center punch
The three drill bit sizes that you will need are #30, 21 and 11.
We have a drill bit assortment kit available.
Olympic rivets are used on the exterior, unless you have a portion of the interior off. You then could use "buck" rivets.
The underbelly uses 3/16" pop rivets.
Drilling out the original buck rivets takes a # 30 drill bit. The holes are then opened up with a # 21 drill bit for the olympic rivets. "DO NOT" drill out the od original rivets with a # 21. The idea is that you can and will have oval holes with the #30 drill bit, since you cannot absolutely center the drill bit. Those holes are trued back to round with the second drilling, using a #21. If you attempt to drill out the old rivets with a #21, again you will have oval holes. The problem then is that you would have to true the hole with a #11and the use an oversize 3/16 rivet. Olympics are not available in 3/16, and if they were, the rivet head would be much larger than the buck rivet heads.
Also you will need a "shaver" if your going to do a bunch of rivets. If not, then you can dress then down with a Dremel tool, but they will all have a different appearance from each other.
You should use "vulkem" sealer when replacing rivets and/or sheet metal.
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
Old 09-08-2006, 06:29 PM   #3
malconium
Profile:  1973 31' Sovereign
Portland , Oregon
I bought a pnuematic pop-rivit gun from Harbor Freight and have been very happy that I did. I already had an air compressor too. The following website shows the model that I bought. I think it was on sale for somewhat less when I got mine but I would still happily pay this much for one. Obviously it does depend on how may rivets you need to set but it does make the job a lot easier. The olympics are also harder to pull than the interior 1/8" standard pop-rivits.
http://www.harborfreight.com/cpi/cta...emnumber=93458
I also bought an inexpensive tool for shaving rivits that seems to do a pretty decent job. Check out the following site. You need one of the "microcounterstops" and one of the "rivet shavers". I found that it worked better in a tool that ran faster than an electric drill. I used an air powered cutoff tool that also happens to have a 1/4" collet.
http://www.airpartsinc.com/catalog_gif/page13.htm
If you are carefull you can drill out the rivets without a special tool. I did buy another tool that seems to work well on the Olympic rivets though. The price seems to have gone up a lot since I bought mine and I am not sure I would pay the new amount that it sells for now but in case you are interested check out the following website. The tool self aligns with a rivet head and keeps the drill bit on center. It comes with the right assortment of drill bits and guides.
http://www.aircraftspruce.com/catalo...vetremoval.php
I bought my Olympic rivets from Andy who just posted above.
Malcolm
malconium is offline   Reply With Quote
Old 09-09-2006, 04:33 PM   #4
tgregory13
Gold Rivet Member
tgregory13's Avatar
Profile:  1963 26' Overlander
Fuquay , North Carolina
Rivet Removal Tool
after reading the above post i went looking for a riviet removal tool... found this one it was on sale for 39.95 (reg $70.95), i ordered one.... here is the link:
\http://www.usatco.com/drilling_aids_02.asp
have a good 1
Todd
tgregory13 is offline   Reply With Quote
Old 09-10-2006, 07:11 PM   #5
LI Pets
Silver Mist
LI Pets's Avatar
I just bought one also!
WBCCI
Old 09-27-2006, 05:56 AM   #6
LI Pets
Silver Mist
LI Pets's Avatar
have a good 1
Todd
This is one great tool HIGH recomend
WBCCI
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Parts is Parts!!! TRAPEZE Airstream Motorhome Forums 13 09-03-2002 11:48 AM
Source of "Vintage" Dometic refer parts? 74Tradewind Refrigerators 3 08-16-2002 08:42 AM
Recent Model Parts Books in PDF format thenewkid64 Link Archive 1 08-05-2002 01:29 PM
66 Safari - step and window guard parts? Gordon 1966 - 1968 Safari 1 04-20-2002 11:16 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
