Old 05-02-2009, 05:04 PM   #1
1963 19' Globetrotter
Vancouver , Washington
what size rivet for U channel, skin and belly pan connection?
Hi all,
I'm putting a floor in my 63 GT and need to replace all the U-channel on the drivers side before proceeding. Looks like I'll be buying a used set of rivet/bucking tools, What I can't seem to nail down is What size, length and grade of rivet(s) I need to order?
Trying to get my orders in over the weekend so I can get after it next Friday and Saturday!
I'm sure I've missed this info somewhere, I just have ran out of time to do "internet research ".
Thanks for any help you can give,
-Ben
Also I'm in the Portland Or. area and would like to buy locally if possible, anyone know a good supplier out my way?
benWa is offline   Reply With Quote
Old 05-02-2009, 05:06 PM   #2
Originally Posted by benWa View Post
Hi all,
-Ben
The floor channel is held to the floor with 1/4 inch bolts.
Old 05-02-2009, 06:25 PM   #3
not the the floor bolts, the rivets...
The U channel is shredded and is getting replaced, I need to know the rivet size etc. for the connection between the exterior skin,U-channel and belly pan.
-Ben
Thanks for taking time on a Saturday to answer Questions!
Old 05-02-2009, 07:41 PM   #4
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Ms20470ad5-5
Old 05-02-2009, 07:56 PM   #5
-Ben
Airstream used 1/8 pop rivets.
You can use those or go to 3/16 pop rivets.
Length, in this case doesn't matter, just so they are long enough.
But, with pop rivets, you would have to install a molding to cover them.
Airstream used 1/8 inch buck rivets, typically 1/2 inch in length.
Old 09-22-2009, 08:49 PM   #6
1978 25' Tradewind
Santa Fe , New Mexico
Andy - it seems on the outside there are two types of rivets. There are the one's that are exposed to the sun, rain and snow (I would assume Olympic and shaved down) - and then there are the ones on the belly pan - which are like the interior pop rivets but larger. Are these the buck rivets? They have the center hole similar to the interior. What size are these? I drilled the out with a 5/32 bit - which was a tad small... also - what should I expect to spend on clecos (100).
hessehesse is offline   Reply With Quote
getting to the belly pan? pinkflamingoes Belly Pans & Banana Wraps 21 08-29-2010 04:56 PM
Belly pan off or on ? augier Belly Pans & Banana Wraps 6 08-08-2009 02:04 PM
belly pan hlink Belly Pans & Banana Wraps 10 09-16-2008 07:51 AM
Belly Pan /Skin Loose Old_Town Belly Pans & Banana Wraps 14 06-08-2008 08:54 PM
Belly pan / Side skin seam? Ifihadtime Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 04-29-2007 05:02 PM
