Old 03-31-2014, 09:38 AM   #1
Scotman's Avatar
1986 25' Sovereign
Lake Alfred , Florida
What size rivet for lower belt line.
I'm doing a repair on the bumper area of my 1986 Sovereign. I need to remove the belt line. What size rivets should I get to reinstall it? I'm pretty certain they're 1/8" but I need to know what grip range I should get.
Scotman is offline   Reply With Quote
Old 03-31-2014, 10:21 AM   #2
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
You can try using a gauge. Pretty much anything that fits in the current hole with a lip on the end to catch on the inner skin. mark the OS surface, retract then measure the wall thickness. If that makes little sense google cherry max gauge for an image.
truckasaurus is offline   Reply With Quote
Old 04-02-2014, 04:49 AM   #3
Scotman's Avatar
1986 25' Sovereign
Good advice! I drilled out a rivet last night and discovered they are not 1/8" as I supposed. Looks like 5/32 and I'll need about 5/8" grip range. Thanks!
Old 04-02-2014, 05:14 AM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
The rivets would be in the 50 series range. 52,54, 56, etc. larger numbers are longer.
Suitable belt and lower trim molding inserts dznf0g General Repair Forum 11 12-04-2017 12:32 AM
'99 Excella 1000 Lower Belt Trim Fix? Silver Otter Clearcoat, Exterior Paint & Trim 7 05-21-2013 10:37 AM
Lower Belt detaching on Safari 2007 Trailer Cgmonkman General Repair Forum 6 04-27-2013 06:45 AM
ebay - BLACK belt line 150' new old stock ViewRVs Airstream Motorhome Forums 0 06-20-2004 06:03 PM
ID'ing a Model by the Belt Line styling jaco Airstream Trailer Forums 5 02-25-2004 01:06 PM
