Old 10-02-2003, 08:05 PM   #1
Tin Hut's Avatar
2005 28' International CCD
Pagosa Springs , Colorado
what size rivet?
I've got some of the 5/32 rivets that I've used for the outside skin but don't know what the size of the small rivets that are on the bottom "channel" molding of my '67 Tradewind. What size should I order? Some of the are rusting and must not be aluminum and I want to replace. Thank you.
Tin Hut is offline   Reply With Quote
Old 10-02-2003, 08:27 PM   #2
Images: 59
Rivets
If you're asking about the row of rivets between the body and the belly pan, I think they are 5/32" also. If they look smaller they may be modified Brazier head rivets. Mine are all the same size top to bottom. The mod. Brazier has a head diameter of .312. Also possible that a PO used 1/8th rivets in a bungled repair job.
Old 10-03-2003, 07:08 AM   #3
Tin Hut's Avatar
size
The holes are actually smaller. Couldn't get a 5/16 rivet thru. This is on a trim piece that has three grooves on it and runs around the base of the trailer.
Old 10-03-2003, 07:20 AM   #4
LOST , Hawaii
If they have a hole in the center they are probably 1/8" pop rivets.
John
74Argosy24MH is offline   Reply With Quote
rivet tools maznblu Ribs, Skins & Rivets 12 05-31-2006 05:51 PM
Ebay rivet shaver TomW Ribs, Skins & Rivets 4 02-26-2004 01:54 PM
Rivet Removal pap Ribs, Skins & Rivets 11 02-06-2004 10:04 PM
Rivet holes and Door Latches JimC Doors & Locks 1 10-17-2003 10:12 AM
