Old 04-27-2012, 02:18 PM   #1
Anchorage , Alaska
What should I look for in buying a nibbler?
Restoring a 1963 Bambi and need to replace the belly pan and one exterior skin. Googled sheet metal nibbler on eBay and got tools ranging from $25 to $3,000
I don't think i have to much cutting to do. I have a air compressor.
What are key spec's/capabilities. what should I look to spend ?
Aktundra is offline   Reply With Quote
Old 04-27-2012, 02:56 PM   #2
1958 26' Overlander
Lander , Wyoming
i would get an electric sheet metal shear rather than a nibbler unless you have some complex cuts to make. Mine is a Kett but others such as milwaukee etc make them. They are great for the long cuts when replacing panels. Also some hand shears for smaller cuts should do it. Ed
n2batr is offline   Reply With Quote
Old 04-27-2012, 03:43 PM   #3
Belegedhel's Avatar
1973 21' Globetrotter
Houston , Texas
I have a nibbler that I got from Harbor Freight for less than $20. I don't expect to use it too much, which is why I wasn't too concerned about buying a cheapy, but so far so good. I've used it on a couple of projects, and it works as advertised (at least on the thin stuff).
Old 04-27-2012, 03:57 PM   #4
danlehosky's Avatar
2012 25' FB Flying Cloud
Gig Harbor , Washington
Depends on what you intend to use it for. Nibblers work best in tight spots like for electrical boxes etc. Shears work much better for long cuts. Overall the shears are more useful.
TAC
Hope is not a plan.
danlehosky is offline   Reply With Quote
Old 10-08-2013, 09:56 PM   #5
AlbertaBound's Avatar
1975 Argosy 28
1975 Argosy 22
1978 Argosy Minuet 6.0 Metre
Camrose , Alberta
if it is mostly for aluminum a cheap one will be fine. if you start cutting steel I would get a more expensive one but plan on replacing the blades so make sure they are available. my $50 nibbler has outlasted my $400 shear for about 5 years now
AlbertaBound is offline   Reply With Quote
Old 10-14-2013, 11:48 AM   #6
1969 21' Globetrotter
Dexter , Michigan
Just got one from Eastwood. Eastwood - Auto Body Repair Tools | MIG Welder | TIG Welder | Plasma Cutter | Auto Body Supplies & Accessories
type901 is offline   Reply With Quote
