Old 04-14-2009, 04:40 PM   #1
SilverHoot's Avatar
1967 24' Tradewind
Greenville , South Carolina
What kind of rivet is this?
For the most part my trailer(1963 SilverStreak) is assembled with this type of rivet. Can anybody recognize what type it is from the pic? Thanks
SilverHoot is offline   Reply With Quote
Old 04-14-2009, 04:59 PM   #2
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
MS20470ADX-X
first X is the diameter of the shank in 1/32" increments
second X is the length of the shank in 1/16" increments
Kip
Old 04-14-2009, 05:08 PM   #3
SilverHoot's Avatar
1967 24' Tradewind
Kip,
Thanks, is the part number universal or a particular vendor? Are these what I have seen referred to as 'buck' rivets. I had not noticed the dimple in previous pics. Thanks again, Michael
Old 04-14-2009, 05:44 PM   #4
Aerowood's Avatar
Arvada , Colorado
The part number is universal and these rivets need to be bucked. Measure the diameter of the head and I can get close to the rivet diameter. Then how many layers of skin and internal structure and I can get you close on the length.
Kip
Old 04-14-2009, 05:53 PM   #5
lynn's Avatar
Normally a dimple on the rivet head indicates it is a hard rivet. More strength when properly bucked.
lynn is offline   Reply With Quote
Old 04-14-2009, 05:54 PM   #6
SilverHoot's Avatar
1967 24' Tradewind
Here's the measurement
Head of rivet is .32 and material is 2 to 3 sheets. For reference how much longer than the thickness of the material being riveted should the rivet be?
Old 04-14-2009, 05:56 PM   #7
SilverHoot's Avatar
1967 24' Tradewind
Rivet hardness
Lynn thanks for the tip, no wonder they are so hard to drill out!
Old 04-14-2009, 06:44 PM   #8
Images: 59
The recipe for the length is CL + 1.5D, where CL is the clinch length (thickness of material) and D is the diameter of the stem.
For 5/32", 1.5D is .234". Add three thickness of .032 metal, and you have .33", or 5 length.
Old 04-14-2009, 07:07 PM   #9
Aerowood's Avatar
Arvada , Colorado
What type of drill bit are you using? A cobalt 135 degree split tip bit at approx 3000 rpm works well. if you a using a cordless drill and a cheap 82 degree twist drill, then they can be a problem.
Old 04-14-2009, 07:11 PM   #10
SilverHoot's Avatar
1967 24' Tradewind
Drill I'm using
I am using cobalt but do not know what split tip and degree angle. Taking notes though! Thank you....AGAIN!
Old 04-14-2009, 07:43 PM   #11
SilverHoot's Avatar
1967 24' Tradewind
Using an electric drill but probably only about 2000 rpm. Are you using an air drill?
Old 04-14-2009, 08:41 PM   #12
Aerowood's Avatar
Arvada , Colorado
Well...........almost all of my power tools are phnumatic.
What Kind and Where shermantic Awnings 2 01-06-2009 01:36 PM
What kind of rivet is this? HamiBambi Ribs, Skins & Rivets 4 08-06-2006 01:16 PM
What kind of Reese is it? Towster Hitches, Couplers & Balls 25 01-11-2004 10:52 AM
Factory rivet vs. repair rivet yukionna Ribs, Skins & Rivets 32 09-08-2003 04:41 AM
