Old 09-22-2015, 12:10 PM   #1
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
san francisco , California
What is best method for removing buck rivets?
I will be removing lots of buck rivets. I've heard about some kind of head trimmer, can't find it now in threads.
I've been using a spring loaded center punch and drilling with 1/8" bit.
Sometimes they walk a little bit and when I get to the more serious rivets where I'll be replacing side panels I'd like to be clean as possible.
I bought those cobalt bits and found that when new they would walk more than worn bits albeit slower to cut.
I imagine I need to take the NEW edge of cobalts or should I use standard high speed steel bits?
thx in advance.
Chip
twolanehwy is offline   Reply With Quote
Old 09-22-2015, 12:25 PM   #2
MarkR's Avatar
1951 21' Flying Cloud
1960 24' Tradewind
Folsom , California
Images: 12
I've drilled out hundreds, if not thousands of solid rivets w/ out anything but a drill bit. Having any other device or adding another step would have been cumbersome . . . I'm not saying there isn't a tool out there that would make it easy/fast, just saying it's not that tricky after the first 10 or so.
Aluminumbskull with Led Balloon in Drag
Birch Plywood and Aluminum go together like
Peanut Butter and Chocolate
MarkR is offline   Reply With Quote
Old 09-22-2015, 12:56 PM   #3
truckasaurus's Avatar
1960 33' Custom
Saskatoon , Saskatchewan
If it helps. Use an air drill, the slower the better, place the bit on the rivet head and pressing lightly use your hand to turn the chuck 1 turn, then slowly drill into the head. Stop drilling before the head falls off.
truckasaurus is offline   Reply With Quote
Old 09-22-2015, 01:05 PM   #4
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Ok, thanks guys. I just had read about enlarging the hole too much as some are off center when they start walking.
Also are the rivets 1/8' diameter for side body panel. it seems that 1/8" bit cuts loose the rivet clean. I just bought a 3x pneumatic (Deutsch) rivet gun on Ebay for $20. Then I need the proper driving heads, a (670) bucking bar and some celco's. starting to collect these things I don't have. I have an air chisel (snap on) which I heard is not the same as air rivet gun.
I do have an air drill, I'll give that a try. What about bits? any preference?
Old 09-22-2015, 01:15 PM   #5
cwf
cwf's Avatar
1999 34' Excella
Hillsboro , Texas
Are you doing a shell off restoration/repair?
I have found using a 'chisel point' drill bit will 'start' better than the large cutting face of a standard high speed bit. Another option, use a really small bit to 'start' the hole on all the rivets.. then use the 1/8" bit to drill off the HEAD of the rivet only...
Once the head is removed you use a small 'punch' to push the rest of the rivet through the hole in the C channel.
Try on a couple or three first.. then once comfortable this will work, prep the rest of the rivets.
Regarding a 'trim' tool... there is a head trimmer for 'pop' / Olympic rivets which will smooth out the head of the rivet and smoothing out the 'rivet stem' which sometimes remains.
Peace and Blessings..
Channing
WBCCI# 30676
Old 09-22-2015, 02:25 PM   #6
Images: 59
Definitely only use a split point drill bit. High Speed Steel is just as good as the fancy carbide on aluminum rivets.
I position the bit in the center of the rivet and give it a quarter turn by hand. Never used a center punch, but most of the rivets I drilled out were original hardened rivets with a little dimple in the center.
Then I would drill out to 5/32" and use modified brazier head rivets or 5/32 Universal rivets for replacement.
Don't even try the air chisel - no control.
Old 09-22-2015, 07:53 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
I can't saw straight or drill straight. Starting a drill on a spherical rivet head is a challenge for me.
So I purchased a drill guide from VTS. It locates on the OD of the rivet head and thus centers the drill perfectly. I find it very useful and I am sure it has saved me off center drilled holes and marked up skins.
Rivet Removal Tool
I know, I know... Real men don't need no drill guide.
David
Old 09-22-2015, 08:16 PM   #8
1979 23' Safari
Wayland , New York
Rivet Removal Tool
David
Used the same tool, has helped a lot especially when doing lots of rivets.
Old 09-22-2015, 11:21 PM   #9
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Yes, I'm doing a shell off. I have it all stripped out and lower rivet drilled out. I have another thread started a week or so ago "taking the plunge, shell of 1959 Globester"
I'm new to this so don't know how to insert thread.
Anyway I'll try a few suggestions here on different methods to see what works for me. I'll be posting many pics and keeping it going.
I bought last year and did many tow related upgrades, new axle (Dexter Torflex) electric brakes, breakaway box, brake controller, anti sway / weight distribution (Reese), tires, wheels etc...
After stripping it down inside, the floor was gonzo..soft like a wet rag, rot, stink. I had to commit or sell at a major loss so I'll spend more and time, time, time. Been there before on houses, cars, bikes, etc...
Old 09-22-2015, 11:22 PM   #10
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
Rivet Removal Tool
David
Sounds like a reasonable solution and welcome addition to my tool collection.
Old 09-23-2015, 11:03 AM   #11
Alphonse's Avatar
2010 28' Flying Cloud
Lower Alabama , USA
drill guide is the way to go
Rivet Removal Tool
David
I also have and use this tool. Fast and efficient along with minimizing the chances of a miss. Highly recommend it and order some extra drill bits with it.
Alan
"If you must choose between two evils, pick the one you never tried before!"
Air #64439
Southeastern Camping Unit WBCCI #5033
TAC AL-8
2018 Canopenian
Alphonse is offline   Reply With Quote
Old 09-23-2015, 01:38 PM   #12
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
just ordered, thanks for the suggestion on xtra bits.
#30 is 1/8" right? Anyway yes many more things to get.
I like to research best I can before pulling the trigger. I hate buying wrong things and then deal with returning.
Just recently I purchased a Reese weight dist /sway control system.
Fortunately for me I didn't wait until the last minute to try and install.
I got everything together and the last thing was these brackets that sandwich between the trailer frame. Bolts wouldn't line up so laid them side buside and lo and behold they were not same length.
I call Etrailer and they called Reese. Reese said they didn't just have brackets so they'd send me a complete new (85 lb.) box and I could take it out of there....really? sounds crazy expensive way to do cust. svc. as well as I had to unpackage all the stuff to get to bracket....then re-box everything which was no simple task...Oy!
Old 09-23-2015, 03:40 PM   #13
Chillitom's Avatar
1963 24' Tradewind
Chillicothe , Illinois
Putty Knife method
I used a stiff putty knife with a hammer. Running it between the panels with a sharp hit severs the rivet in two and they then fall out of the holes on either side. Unhooked my 24 Tradewind in less then a half hour with this method.
Chillitom is offline   Reply With Quote
Old 09-23-2015, 04:30 PM   #14
59' Globester
twolanehwy's Avatar
1959 18' "Footer"
1957 26' Overlander
You are referring to the lower rivets? Going up under the overlapping skin?
I did that with a few. Guess I should have tried to pursue that further. I was afraid in would rip the underlying holes.
Now I'm looking at the side panels I'll be replacing. Since they underlap the upper skin that might work since I'm replacing the lower.
Buck Rivets or Olympic Rivets halimer Ribs, Skins & Rivets 5 09-21-2011 03:20 AM
Buck rivets or Olympic rivets? Sparkygus Ribs, Skins & Rivets 20 02-28-2009 08:33 AM
Olympic Shaved Rivets vs. Buck Rivets with Dimple msjaarda Ribs, Skins & Rivets 8 03-16-2007 10:00 PM
