Old 08-07-2008, 02:13 PM   #1
Alumanutz's Avatar
1966 22' Safari
Chico , California
What did I buy?
I won this on Ebay. Just bidding on anything starting with Cleco. I was expecting the spring type. The air tool has a hex drive inside the nose that grips the nut and tightens it. I was hoping that Uwe or Aerowood could tell me what this is.
John.
ID:	65254   Click image for larger version
Alumanutz is offline   Reply With Quote
Old 08-07-2008, 02:24 PM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
Did you pay more than $.99?
Is the tool rotary or impact? If impact the springs in the bits suggest some form of concrete drill.
2004 Excursion 4x4
Old 08-07-2008, 03:04 PM   #3
AirsDream's Avatar
1999 23' Safari
Perrysburg , Ann Arbor
Most interesting. Looks like a more "heavy-duty" sort of Cleco that screws tight instead of using the traditional springs and pliers-type installer. What size hole do they fit? Wonder if they're for thicker-skinned aluminum aircraft construction ... I do know that there are Clecos that use hex nuts (and some wing nuts) to draw them tight, as opposed to the traditional spring types.
AirsDream is offline   Reply With Quote
Old 08-07-2008, 04:08 PM   #4
Alumanutz's Avatar
1966 22' Safari
Chico , California
The tool is rotary. There are no springs on the clecos. As you tighten the nut it pull the two fingers back along the center shaft and into the body. Its almost like if you were to place a sheet of al on a piece of thicker metal and needed the extra lenth.
And as a matter of fact, my bid of .99 won but I also had shipping.
Old 08-07-2008, 04:32 PM   #5
RBolton's Avatar
Belington , West Virginia
Look at this catalog http://www.monogramaerospace.com/fil...%20Catalog.pdf
I think it shows and explains the fasteners you have.
Roger
RBolton is offline   Reply With Quote
Old 08-07-2008, 04:47 PM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Those are 5/32 draw clecos. They work on the same principle as the spring type but can clamp a greater thickness with greater clamping pressure. The tool is most likely a cleco driver for the ones with a hex nut on top. I just use an air ratchet for the hex style and an air ratchet that has a modified 7/16 deep socket with notches cut in it for the wing nut style. These are really handy for clamping together things real tight. Be careful though, as to much torque can pull the cleco clean through soft thin material enlarging the hole. This type of cleco is available in a much broader range of sizes and lengths then the manual spring type clecos.
Old 08-07-2008, 11:51 PM   #7
Alumanutz's Avatar
1966 22' Safari
Chico , California
Does anybody have a use for these? I don't think I will be needing them! I like the spring type.
Old 08-08-2008, 09:21 AM   #8
Aerowood's Avatar
Arvada , Colorado
If you feel you have no need for them PM me with price
Old 08-08-2008, 12:08 PM   #9
Alumanutz's Avatar
1966 22' Safari
Chico , California
Aerowood, If you make a contribution to the VAP, I will send it all to you and pay the postage! Let me know.
NUTZ
Old 08-08-2008, 12:14 PM   #10
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Question: What's a cleco?
Family of Disney Fanatics
WBCCI# 4821
Old 08-08-2008, 01:47 PM   #11
AirsDream's Avatar
1999 23' Safari
Cleco is a brand name, now become somewhat generic (like "Kleenex" for "tissue") for a type of temporary fastener used to hold e.g. two pieces of aluminum in place for final assembly by methods such as riveting. Like on an Airstream or aluminum aircraft. Drill a hole through both pieces, insert Cleco. It clamps the two pieces together. Drill another hole, etc. Then as you rivet, you remove a Cleco, insert a rivet, etc. Almost impossible to get good riveted seams without something like Clecos.
Old 08-08-2008, 02:11 PM   #12
2006 30' Safari
Orlando , Florida
I think I have seen them in photos. I always wondered what they were. They looked like a series of brass pegs in the holes.
WBCCI# 4821
Old 08-08-2008, 08:27 PM   #13
Alumanutz's Avatar
1966 22' Safari
Chico , California
I have yet to hear from Aerowood. Anybody else interested at the same terms? I will still give Aerowood first shot but only until tomorrow. Its my way to help out a good program!
NUTZ
Old 08-08-2008, 09:48 PM   #14
Aerowood's Avatar
Arvada , Colorado
If someone else wants them speak up. I already have an obscene amount of clecos. Somebody else that doesn't have any already, speak up.
Kip
Help!? To buy or not to buy? Karebere 1970 - 1973 Sovereign 14 08-06-2008 12:13 PM
To buy or not to buy a HAHA millvalleyca Hitches, Couplers & Balls 9 12-31-2007 10:50 AM
What a buy! Pahaska Off Topic Forum 7 03-29-2007 11:02 AM
To buy or not to buy, is that the question? ob1coby Our Community 1 06-24-2004 03:34 PM
Anyone here buy....... Silvertwinkie Our Community 0 03-13-2004 01:17 PM
