Old 05-15-2005, 12:50 PM   #1
Ferroequine's Avatar
1975 23' Safari
Calgary , Alberta
Weird aluminum on endcaps?
While stripping our '75 Safari (the project is being posted in this thread), I came across an odd observation.
After stripping, the curved aluminum on the rear end cap appears to have a different "mill" finish on it than the straight sections of the sides (and for that matter the flat piece in the back below the window).
As you can see in the picture, it didn't even come out as shiny right after stripping. Both sides had their plasticoat mostly intact, so there was no oxidization. Even when I tried to polish it, I can't get a good mirror finish on it like I can with the flat pieces. I haven't managed to get a good picture of it yet, but it reminds you a little bit of a tiny "orange peel" effect.
Has anyone seen this before? Does stretching the aluminum change the physical properties somewhat?
1975 Safari 23'
2004 Ford Expedition Eddie Bauer 4x4
Ferroequine is offline   Reply With Quote
Old 05-15-2005, 01:21 PM   #2
till's Avatar
Lisle , Illinois
Images: 108
I wonder if it has anything to do with the strech forming process that is used to make the end cap segments???
Tedd Ill
AIR#3788 TAC IL-10
1967/8 Overlander International Twin w/ bunk/s.
Yes, four kids and two adults in the thing.
Happy wife, happy life.
till is offline   Reply With Quote
Old 05-15-2005, 07:29 PM   #3
Aluminut
Silvertwinkie's Avatar
2004 25' Safari
. , Illinois
Till hit it right on...when they form the skins on the end caps, it does this. Your Airstream is 110% normal.
Old 05-15-2005, 07:32 PM   #4
You are lucky if Eric is right! You are 10% more normal!
Anon is offline   Reply With Quote
Old 05-16-2005, 01:41 AM   #5
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Ha
I must be 120% normal. Our Argosy, after stripping, I found 3-4 different mill works. The stretch panels also seem to be of heavier aluminum vs. the sides.
Looking good!
Marc
Aluminum Trim Source? melprice Cabinets, Counter Tops & Furnishings 6 09-08-2009 07:19 PM
Stripping paint off aluminum tin can luv General Interior Topics 4 04-18-2004 10:32 PM
Sheet Aluminum repair lee_jachter Ribs, Skins & Rivets 8 11-23-2002 09:48 AM
believer in aluminum tanks! JohnGalt48 On The Road... 7 08-15-2002 06:49 PM
