Old 01-30-2015, 06:22 AM   #1
Portland , Oregon
Vertical Curved Rib Replacement
I am the proud owner of a 1952 Silver Streak Clipper. The last occupant liked windows so much he had 5 on the street side. So, during this "retrofit", they removed or cut up quite a few of the vertical ribs which are curved to follow the body shape. I am attempting to re-create those curved ribs.
I am using 0.30" 5052 T 32 for material. I have a HF 30" brake for bending the C section. So, in the day, how did the factory make all those beautifully curved ribs? Has anyone made a jig for doing this? I tried some ideas but end up totally wrecking the C shape.
bikeukeguy is offline   Reply With Quote
Old 01-30-2015, 07:18 AM   #2
Central , Mississippi
Here is one way to do it.
http://www.airforums.com/forums/f109...ml#post1084035
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-30-2015, 08:47 AM   #3
J. Morgan's Avatar
1972 31' Sovereign
1975 31' Excella 500
Benton , Arkansas
Images: 11
The best way to reproduce curves is by using a shrinker/stretcher.
Ron Covell, the guy who made the video is world renown.
If you go to the 4:55 point in the video you can see how a channel can be bent using this tool.
I used one of these to rebuild the rear c channel in my trailer.
If a person uses one of these for aluminum, aluminum jaws must be purchased.
http://youtu.be/6frSjl1Gf8o
1/2 Ton 4WD Truck, 72 Sovereign Hensley Arrow
2014 international rib and replacement sources for rolled-over damage dnavcrew Ribs, Skins & Rivets 6 11-03-2014 05:54 PM
63 Safari Roof rib replacement airstream4 Ribs, Skins & Rivets 9 04-14-2008 10:04 AM
Vertical slits after jacking for new wheels flamingo-kid1 Jacks, Stabilizers, Lifting and Leveling 1 04-26-2004 07:56 PM
Vertical Lip Seal Inland RV Center, In General Motorhome Topics 0 01-19-2004 02:09 PM
