Old 11-17-2012, 08:33 AM   #15
mimiandrews's Avatar
1966 22' Safari
Weatherford , Texas
Check Aircraft Spruce for some genuine RivNuts. They have a rib built into the outer diameter that grips the aluminum in the hole and prevents the threaded nut from spinning. They're also unlikely to cause galvanic corrosion.
They do require a special tool to install.
I've used them on aircraft and Airstream, and they work great.
Old 12-17-2012, 10:31 AM   #16
Denis4x4's Avatar
Durango , Colorado
Here's the stuff I bought at West Marine that prevents corrosion when using fasteners other than aluminum on an AS. I do not think that it's in the catalog. However, there's a website and phone number on the packaging.
ID:	174813   Click image for larger version
Denis4x4 is offline   Reply With Quote
Interesting Tongue Jack electrical problem Wingeezer Jacks, Stabilizers, Lifting and Leveling 15 10-12-2012 10:08 PM
Ugly Rivets! Roadrunner Ribs, Skins & Rivets 2 12-04-2011 11:24 AM
Jack & Lug nut wrench Tim_S Tires 41 10-31-2011 08:27 AM
Vintage Tongue Jack - Reese IndyAnne Jacks, Stabilizers, Lifting and Leveling 11 10-19-2011 01:32 PM
