Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 01-04-2004, 05:51 PM   #1
campcollector
campcollector's Avatar
Profile:  2003 19' Bambi
Lincoln City , Oregon
Images: 21
Question Using a porta power ram
I was considering using a porta power to push out the bent ribs in my roof after removing the interior panels. Any comments or thoughts.
campcollector is offline   Reply With Quote
Old 01-04-2004, 06:09 PM   #2
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
It might work if!...the ribs are not cracked or stretched, which I think you will find that they are, you can replace rib sections using a splice section. IIRC the newer AS use a 3 piece rib to start with, the two sides and the roof section. The ribs are aluminum and it does not like to be bent and straightened much at all!
Aaron
Old 01-04-2004, 06:18 PM   #3
campcollector
Images: 21
The goal
My goal is I would try to push out the worst of the bowed roof with the power ram. Then using some body spoons work out the worst exterior dents. Then replace any poped or loose rivets, and vulkum any seems. For a more involved look go to.......
http://www.airforums.com/forum...?threadid=8290
I am not lookiing for pretty just functional I expect to have a wavy roof.
Old 01-04-2004, 06:45 PM   #4
overlander63
Rivet Masher
overlander63's Avatar
Profile:  1974 31' Sovereign
L.A. , California
Re: The goal
Originally posted by campcollector
My goal is since the trailer was totaled, I would try to push out the worst of the bowed roof with the power ram. Then using some body spoons work out the worst exterior dents. Then replace any poped or loose rivets, and vulkum any seems. For a more involved look go to.......
I have done this with cars and trucks. You would need to use a piece of 1/2" plywood, about 12" square, on top of the portapower. This will help keep your dent from becoming a bump.
Then put in some new ribs, and rivet and Vulkem as needed.
I make it sound sooo easy.
Old 01-04-2004, 06:53 PM   #5
campcollector
Images: 21
Nothing to lose
Well its all worth a shot, Its not like I can hurt it anymore than the tree did.
Old 01-04-2004, 08:40 PM   #6
markdoane
Profile:  , Minnesota
Images: 59
Pushing out dents
You should review some of metal working techniques for aluminum. With tempered aluminum, you may find that proper application of some heat to anneal the ribs and skin would give you a much better result than cold working.
Read some of the info at tinman
Old 01-04-2004, 08:46 PM   #7
campcollector
Images: 21
Heat
Yes I had read this before that a heat gun can make the aluminum more workable. I think it was around 200 degrees or so.
test
