Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 05-01-2015, 12:24 PM   #21
1987 Avion 34W owner
PaulnGina's Avatar
Good Ol' , USA
Originally Posted by Silverflames View Post
Did you put thread lock on them?
No, but that's a good idea. I'll keep that in mind for the next time I crawl under the trailer.
I this great country!!!!
1987 Avion 34W
1995 Ford F250 7.3L PowerStroke
PaulnGina is offline   Reply With Quote
Old 05-07-2015, 04:45 PM   #22
2003 25' Safari
Kissimmee , Florida
I had the same problem. The insulation above the belly pan has just enough weight to aggravate the problem. I re-installed the belly pan using large outside diameter washers and pop rivets. I also supported the center of the sheet by installing an "L" shaped aluminum extrusion from frame rail to frame rail.
Dan
dmac is offline   Reply With Quote
Old 05-08-2015, 11:59 AM   #23
1981 31' Excella II
New Market , Alabama
Best thing you can do is pull out all the stinky pink stuff. Most frame rot is caused by that stuff staying wet and laying against the frame. Also the wood can dry better without that stuff in there. Unless you live in Maine or Canada, you won't miss it.
Perry
Old 05-08-2015, 12:35 PM   #24
2019 27' Globetrotter
Missouri Valley , Iowa
I had the same problem on my '89 Excella. I made small plates instead of using washers. I bought some thin aluminum strap from HD. It was 1" or 1.5" wide. I just used a hacksaw and cut the strap into squares. Drill the appropriate size rivet hole in the center of each piece and rivet in place.
Dan
Farmer Dan is offline   Reply With Quote
Old 05-08-2015, 12:44 PM   #25
SteveH's Avatar
Common Sense , Texas
Someone asked previously in the thread if there was some other material than aluminum that could be used underbelly, and last weekend I was helping my brother with his SOB fifth wheel trailer, and noticed it used black plastic sign material.
Not recommending this mind you, just reporting another material that is used for the purpose.
Regards,
Steve
Old 05-08-2015, 04:45 PM   #26
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I used zinc plated fender washers with a fiberglass washer sandwiched between the skin and the zinc washer. Used 3/16" rivets.
Old 05-08-2015, 05:55 PM   #27
1979 23' Safari
Wayland , New York
Glad I saw this, i'll be putting my new belly pan back on soon. I bought a bunch of 3/16" large flange rivets from VTS. I just looked in the McMAster-Carr washer section and found some zinc plated steel blind river washers for 3/16" rivets. Think i'll get some of those, 250 of them for $9.40. Seems like a inexpensive safe bet. They have round ones and square ones, probably just stick with the round ones, even though the square ones would have a little more surface area. Then i'll shoot them with a little cold galvanizing paint.
Old 05-08-2015, 06:34 PM   #28
1979 23' Safari
Wayland , New York
Oh I'm using 5052-H32 .032" thick. I do remember finding quite a few rivets that were like the pictures when I took off the old aluminum.
Thunder rattle from underbelly skin exallen General Repair Forum 6 07-11-2014 07:50 PM
Removing Underbelly Skin, Insullation kneal Belly Pans & Banana Wraps 1 12-04-2006 05:02 AM
A question on underbelly skin and its gas lines. soldiermedic Belly Pans & Banana Wraps 12 11-23-2006 03:34 PM
Sealing exterior skin panels with Lizard Skin BB 55 Bubble Leaks - Weatherstrips, Gaskets, Caulks & Sealants 15 11-21-2006 04:50 PM
Underbelly Skin Replacement Morning Dew Belly Pans & Banana Wraps 5 08-21-2003 09:12 AM
