Old 08-13-2014, 10:53 PM   #1
1962 22' Safari
Castle Rock , Washington
Under Taillight Rust on '62 Safari
After removing the tail light and license plate bracket assemblies on my '62 Safari, I was unpleasantly surprised with a fair amount of rust. I'm sure that with all of the collected wisdom contained within this site, some of you AS gurus have a method to get rid of this rust prior to polishing. I have already used PPG PR-5044 to remove any sealant and/or clearcoat. Good stuff by the way, put it on in the evening, come back in the morning and scrape off with a plastic scraper, neutralize with lacquer thinner - done!
ID:	219006   Click image for larger version
Tlam is offline   Reply With Quote
Old 09-17-2014, 06:20 PM   #2
1964 22' Safari
1962 28' Ambassador
enosburg , Vermont
By now I'm guessing you're way beyond this. Common problem of steel against aluminum. It will happen faster and worse the next time without a barrier between them. You will find other places with the same problem. Ice tech roofing membrane makes a nice gasket for steel on exterior aluminum surfaces. Common rattle can auto undercoating works well for places like the small angle iron pieces that connect the aluminum body bows to the floor and the front hold down plate to the shell.
putback is offline   Reply With Quote
Rust Under Dashboard Charlee Argosy Motorhomes 1 07-21-2013 02:44 PM
Rust and Frames Por 15 Zero Rust Tony S Repairing/Replacing Floor &/or Frame 10 02-20-2013 03:45 PM
Water Trapped Under Rear Taillight Assy. Snaken49 Leaks - Weatherstrips, Gaskets, Caulks & Sealants 1 08-20-2012 04:26 PM
Rust under clearance lights saburkha All Argosy Trailers 4 09-13-2011 10:16 AM
Frame Damage (Rust under water Tank klanke Repairing/Replacing Floor &/or Frame 3 04-06-2003 08:34 AM
