11-29-2006, 07:54 AM
#21
Addicted to Aluminum
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
i think people mix and match the terms. polishing the inside cap looks awesome, but kills my back avter craning around with a 7 poind polisher in my hands for an hour... plus, it is REALLY dirty work! (depending on your polishing method, of course). i start with a buffing wheel for the initial cut, do 2 passes, then switch to the 8" wool pad and Nuvite for the BLING.
jp
there's always room for one more!
11-29-2006, 07:59 AM
#22
1957 30' Sovereign of the Road
Bellevue
, Full-timing
jp
Well, we won't have to worry about that, since there's NO METAL there!
I just have no desire for Zolotone.
b
11-29-2006, 04:07 PM
#23
1959 22' Caravanner
Atlanta
, Georgia
b
That was our original thought as well. Most of the interior of our coach is not 2024 T3 Alcad (the stuff that really polishes up nice like the exterior). It is a lower grade and by hand it has not taken a good polish. I am waiting to see how JP's polish comes out and reevaluate. If it comes out good then we may try to piece in the end caps. I would love the easy clean up of a wax job once a year so I have hope that it comes out good.
1959 22' Caravanner
1988 R20 454 Suburban.
Atlanta, GA
11-29-2006, 04:21 PM
#24
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
i'm only doing the end caps, not the sides... those are gonna be maple. maybe before xmas i can have something together to look at.
jp
11-29-2006, 05:15 PM
#25
1965 20' Globetrotter
1956 22' Caravanner
Mendon
, Massachusetts
Interior finish
So what stripper have folks been using to get off zolatone? I've not started mine, but I plan on taking the zolatone down to bare and then having it re-shot with new zolatone. The polished look is great and I love it, but for the amount of time I spent polishing the outside... I'm not about to double my pleasure.
BTW, my end caps on my 56 are aluminum.
Has any used the Ralph Lauren River Rock finish before? I was in HD a couple weeks ago and noticed this stuff. Looks very similar to zolatone and for someone looking for a quick alternative to zolatone or just less expensive, this stuff might be an option.
Here's a link:
http://rlhome.polo.com/rlhome/produc...ms.asp?haid=75
56' Caravanner 'The Broomstick'
11-29-2006, 05:20 PM
#26
Corona
Here's a link:
The Zolotone that you have is about the best primer you can have.
Don't remove it.
Sand it down very well with 120 to 150 grit sandpaper.
Don't scuff it, but sand it.
Feather sand any missing areas.
Then simply spray the new Zolotone over the old.
If you remove it or even try, because it won't be easy, you will have to prime the walls. It's already done for you.
Make kife simple.
11-29-2006, 07:01 PM
#27
1959 22' Caravanner
Atlanta
, Georgia
Here's a link:
Yeah we had eyed that as well.
If you plan to paint and the zolotone is not already painted over....stick with it like andy said.
Unfortunately our coach had 3-4 coats of very sloppily applied paint. Runs every where. We had not choice but to strip so we could get back to a smooth surface. It was a TON of work.
1959 22' Caravanner
Atlanta, GA
11-29-2006, 07:20 PM
#28
Bellevue
, Full-timing
Diito, plus we had the possibility of toxins absorbed into the paint - better to just go down to bare and start over. The soda-blasting is done BTW, and reportly looks great, we'll go to get it this weekend - considering the time and chemical exposure I'd have had to endure to do it myself, I think it was money well spent.
Sean
11-29-2006, 07:33 PM
#29
1960 24' Tradewind
santa barbara
My trdwnd has the interior painted a funny beigish sorta color,done in the 60s
as the previouse owner had all kinds of documents and even the paint lable
with the color in a drawer.I can open up the overhead bins and see the original zolatone ,its cool ,but I don't want to strip my interior unless i had to do a major rehab ,luckily I did not .Im betting that since the original interiors
were zolatone ,they saved money using the lesser grades of aluminum sheets.
Bet they never figured we would be polishing it up .
Scott of scottanlily
11-30-2006, 05:56 AM
#30
1956 22' Caravanner
Mendon
, Massachusetts
F*&&King latex
They PO painted over the zolatone with latex so I'm pretty sure I'll have to take it to bare.
In terms of soda blasting they did the entire inside? I was considering picking up a portable soda blaster, but I would be curious what the cost was for having the interior done.
The other option is to re-skin the inteior. Use the original parts as a pattern. The only thing would be then end caps would need to be stripped and the entire inside re-coated.
Doug
11-30-2006, 07:00 AM
#31
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
i painted our house hallway withthe sand paint stuff. painting it on is tricky. it gotta all be wet, or you see the line. that has me scared of ever touching it up... it does seem to be really durable, though. i think we painted the hall maybe 4 years ago, and it still looks great. it feels like sand paper when you drag a knuckle across it running to the front door, though.
jp
11-30-2006, 10:55 AM
#32
Bellevue
, Full-timing
jp
You know, the whole scratchy thing is one of the reasons I don't like that kind of paint - and the dust catching ability.
When we finally decide on whatever surface Rosie will have, it will be a smooth one that doesn't "grab" dust and hold it. And it will be something I can easily wipe down. I *really* don't like bumpy surfaces.
b
12-01-2006, 02:43 AM
#33
1959 18' "Footer"
1964 24' Tradewind
1954 29' Liner
Woodstock
, Georgia
i think a smoother finish would be nicer. when i get around to redoing the globe trotter's interior i plan on a nice sage green in semigloss, for easy clean-up, and touch up, should i need to drill out any rivets.
jp
12-01-2006, 12:02 PM
#34
Bellevue
, Full-timing
My sodablasting guy has posted pictures of his work on Rosie on his website:
http://gallery.nutechsodablasting.co...?g2_itemId=952
if the link goes astray, just go to the main site, go to "gallery", and search for "airstream"
Bridget
p.s. the weird looking patch above where the fridge used to be (next to the door) is going to be removed, therefore we didn't have him blast it
