Old 12-04-2011, 10:29 AM   #1
Roadrunner's Avatar
1978 29' Ambassador
1974 25' Tradewind
1974 27' Overlander
Indiana , Pennsylvania
Ugly Rivets!
I have removed many of the rivets on the interior skin of our Airstream's door to make a clean job of stripping the vinyl. I am replacing the rivets with 1/8" aluminum rivets and hand rivet gun from Lowe's. Why is it that some rivets the shank breaks off clean and other times the shanks extend out past the rivet head? Poor technique? Any way to address the ugly rivets? It would be challenging to drill out the rivets without anyway to center the drill bit. Any rivet masters...help!
Roadrunner is offline   Reply With Quote
Old 12-04-2011, 10:48 AM   #2
truckasaurus's Avatar
1960 33' Custom
Athens , Georgia
The variety in how the rivet pulls can be crappy pop rivets, technique, material thickness or hole size . (the door skins are layered and have different thickness depending on where you are riveting; plus the holes are unlikely to be consistently #30 holes still).
Once you've ensured you have the right length rivets and they are of suitable diameter you could decide to just tap the snapped mandrel into the door cavity or you could flush cut it and dress the cut end.
truckasaurus is offline   Reply With Quote
Old 12-04-2011, 11:24 AM   #3
Basically, it has to do with the price of the pop rivets, which is quality as well.
Expensive pop rivets hardly ever give a mandrel problem.
Cheap pop rivets offer many many challenges, including very irregular mandrel breaking points.
Andy Rogozinski
Inland RV Center
Corona, CA
Rear Bed Wall Support Rivets perryg114 General Interior Topics 6 09-22-2011 06:34 AM
Buck Rivets or Olympic Rivets halimer Ribs, Skins & Rivets 5 09-21-2011 03:20 AM
Greasy rivets! tphan Ribs, Skins & Rivets 9 09-04-2011 09:41 AM
Larger Interior Rivets? MDSilverado Ribs, Skins & Rivets 3 01-10-2011 06:54 AM
