Old 11-26-2013, 06:33 PM   #1
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
U Channel 1/4" Bolt Removal
Can you share the best way to remove the U-channel bolts? Mine look like cheap stove bolts with square nuts with a good inch of very rusty threads. There isn't a lot of side to side or vertical clearance for tools.
I can see this being a royal pain, even with the inner skins removed. I am replacing the back two feet of rotted bathroom subfloor.
David
Name:	1311 Shell Mounting Bolt.jpg
dbj216 is online now   Reply With Quote
Old 11-26-2013, 06:55 PM   #2
Central , Mississippi
Grab the sq nut with a pair of vice grips and wiggle it, it will break off.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 11-26-2013, 06:59 PM   #3
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
Ditto,
We do it that way all the time
Colin
Colin H is offline   Reply With Quote
Old 11-26-2013, 07:40 PM   #4
68 TWind's Avatar
1968 24' Tradewind
Oxford, , Mississippi
I had a few on my 68 that would not break off as Colin and Vernon suggested. I did remove most of the bolts in that way but on a few tough ones a 4in grinder with a cut off wheel worked well.
Bruce & Rachel
68 Trade Wind
2001 Toyota Tundra
Old 11-27-2013, 05:56 AM   #5
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Thank you for the tip. I'll grip the square nut and pry hard to break the fastener. I'm sure the rust has weakened it quite a bit. The rear frame to shell support angle iron is solid and in good shape. It should support my bending forces as I try to break the bolts.
I'll let you know how this all goes.
David
Old 11-27-2013, 06:51 AM   #6
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
If that does not work, you could always drill off the head of the bolt from the other side.
Silverflames is offline   Reply With Quote
Old 11-27-2013, 06:40 PM   #7
dbj216's Avatar
1986 34' Limited
1975 27' Overlander
Conifer , Colorado
Well, I wiggled six of the stinkers until they broke. Great fun! I felt like a dentist, except I didn't get $300 a pop for "extracting" them. I have one that I am going to have to cut or drill the head from underneath. But for the most part, what I need removed is done.
Thanks for the great tip. Wiggle Wiggle.
David
Old 11-27-2013, 06:56 PM   #8
RM66caravel's Avatar
1966 17' Caravel
Newport , North Carolina
With the exception of the end cap channel the rest is easy to replace at any ac fabrication shop and usually it cost 10 to 20 bucks for an 8 foot piece. Nice pictures keep them comming.
Later cliff
Gotta get busy! Have a great day! Now where did I put those revits?
RM66caravel is offline   Reply With Quote
Old 11-28-2013, 05:44 AM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Wiggle till they break, if they don't I use a dremel tool with a grinding wheel, gets into the channel with no problems. Sawzall with a short blade might work too, if the channel is loose enough.
Aaron
WBCCI #XXXX AIR #2495
