Old 12-05-2016, 04:07 PM   #1
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Trouble removing front banana wraps
Yesterday I spent several hours trying to remove the street side wrap on my 65 overlander. All outside rivets drilled, I also removed the inside skin to shear off hidden rivets, still not budging! I only removed the lower skin on inside that stops just passed the couch.. I really don't want to take off anymore inside skin! Can't believe how many rivets hold this damn thing on!
Cochese is offline   Reply With Quote
Old 12-05-2016, 04:25 PM   #2
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Banana wrap trim
Did you get all the rivets behind the belt trim, I found out the hard way that I had missed two after going cross eyed from drilling out all the rivets.
cole3444 is offline   Reply With Quote
Old 12-05-2016, 04:37 PM   #3
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
Yes, I even sheared all where it attaches to C channel with a putty knife. I think there are some behind the long outer skin, but it's difficult to see without drilling more buck rivets, then I'm into that whole side panel!
Old 12-05-2016, 04:39 PM   #4
Cochese's Avatar
1965 26' Overlander
Tulsa , Oklahoma
My whole point of this is to have them English wheeled while I have that inside wrap around skin off!
Old 12-31-2016, 08:31 PM   #5
Slats's Avatar
1966 24' Tradewind
Kansas City , Missouri
Are your banana wraps riveted to the C channel with pop rivets?
Slats is offline   Reply With Quote
Will plastic banana wraps fit on a 1961 Ambassador? RoverOwner Belly Pans & Banana Wraps 3 09-15-2008 09:49 PM
Painted banana wraps LI Pets Belly Pans & Banana Wraps 0 01-14-2007 05:02 PM
Reattaching banana wraps? Mike B Belly Pans & Banana Wraps 2 05-10-2004 05:44 AM
"New" banana wraps j54mark Belly Pans & Banana Wraps 10 10-28-2003 09:36 AM
