Old 07-05-2003, 02:19 PM   #1
top-front skin replacement
I need to replace the front skin above the front windshield-section caved in at spotlight. It is not that bad but it would also allow me to get rid of some previous owner bad spot sealing of windshield gasket. Are there any outlets for skins or must all replacements come from AS thru local AS service/sales?
mlmarch is offline   Reply With Quote
Old 07-05-2003, 02:23 PM   #2
wb13798's Avatar
2004 28' Classic
huntsville , Alabama
if i was going to replace a piece of skin i would use a new piece. you could get replacement skin from a slavage yard. new skin is available from all airstream dealers. lol
al
wb13798 is offline   Reply With Quote
Old 07-05-2003, 02:24 PM   #3
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
This will need to be ordered from an airstream dealer due to the compound curves of the stamping.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 07-05-2003, 08:52 PM   #4
I received an estimate to replace the skin with the skin cost at approx 700 and the total with labor was about $4,000. I just would like to know if this is in the ballpark. Is there a way to get a list of the AS service providers so that I can check around?
Old 07-06-2003, 06:04 AM   #5
Airstream Driver
PeterH-Airstreamer's Avatar
1997 30' Excella
Images: 51
Call the airstream factory and get a quote.
$4k seems to be on the very high end of the spectrum, even with R&R of the windshields and the front inside headliner.
1996 Airstream B190
1987 29' Sovereign Trailer
1997 30' Excella Trailer
AIR #13
PeterH-Airstreamer is offline   Reply With Quote
Old 07-06-2003, 10:28 AM   #6
It is not necessary to remove the windshields when replacing the front cap. If the windshield gasket "lock" is removed from the top of the windshields, the gasket will fold down enough to allow removal of the rivets.
The labor time depends on the method you wish to use.
If you add another seam in front of the roof and above the driver and passenger window, the "overlay" time is in the order of about 8 hours.
If you wish to make the replacement look "exactly" as built, then the cap must be removed. You will then also have to remove the driver and passenger windows. The time now will be 20 to 25 hours. Getting the new cap under the roof and window sheets, is no easy task, and must be done very carefully.
Skin replacement Ken J Ribs, Skins & Rivets 292 05-29-2015 09:47 PM
Leaky Windows & Skin Replacement PizzaChop Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 03-08-2004 11:13 PM
Odd skin dents in front and behind axles Mprecure Axles 3 09-23-2003 08:35 PM
Underbelly Skin Replacement Morning Dew Belly Pans & Banana Wraps 5 08-21-2003 09:12 AM
Z71 or Z85? River Rat Tow Vehicles 7 05-09-2003 04:40 PM
