Old 03-06-2012, 09:10 PM   #1
Eric H's Avatar
1974 23' Safari
1947 25' Spartan , Manor
Tool to cut a patch?
Hi to the almightily forum.
I'm nearly finished on the "lower bits" of my lady, and wondering what tool people like to use to cut aluminum patches. I have only cut sheet steel which can bend it odd ways with tin snip cuts...should I use a band saw?
Thanks!
http://www.airforums.com/forums/f421...ml#post1116349
Eric H is offline   Reply With Quote
Old 03-06-2012, 10:31 PM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Aviation snips work pretty well. Leave a little extra and file edges to final profile, drawing the file towards you at right angles to the edge. Hold the patch in the vice with soft (wood or cloth) padding over smooth jaws. Alternatively, you can use a good jigsaw w/ a very fine blade... again, file to finish profile for best results. You can also belt sand the edges, but you'll want to de-burr with a file. Keep in mind that any steel surface will scratch the aluminum; I use tape on the bottom of the jigsaw to prevent this if I use one. Inadvertent scratches can be removed with 200->400->600 wet-dry paper used wet; I've not done this to al-clad, only single alloy sheets so I don't know how much material is removed. Bandsaws work too, but use a fine tooth blade.
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
Old 03-06-2012, 10:37 PM   #3
Eric H's Avatar
1974 23' Safari
You F-in rock barts. thanks...
Old 03-07-2012, 03:41 AM   #4
Baltimore , Maryland
If the patch is to be square you can use a non ferrous metals blade in a table saw.
Old 03-07-2012, 07:01 AM   #5
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
I use my bandsaw all the time for patches, etc. Then I square them up (if needed) on a beltsander. I really stink at the snips! Like Frank said about the tablesaw too. I just have easier access to my bandsaw.
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 03-07-2012, 08:50 AM   #6
1974 25' Tradewind
Saint Joseph , Louisiana
Thanks!
This may not be possible/practical for everyone, but it worked for me. I've got a friend with a machine shop nearby that has a computer- controlled plasma cutter. He placed a sheet of thin Al plate on the machine's cutting table, dialed in the dimensions of the square piece and in a few seconds the machine cut it out to the exact shape/dimensions I needed. The edges were surprisingly smooth and would be fine for most applications with a light sanding with wet paper. He didn't charge me anything, but, this service may not be available to everyone.
bhutch74ly is offline   Reply With Quote
wiring? Univolt to Converter '74 Tradewind batt Batteries, Univolts, Converters & Inverters 31 05-10-2014 11:06 AM
Converting a Classic to CNG t7389sg Classic Motorhomes 9 06-23-2012 11:53 PM
Airstream Overlander 26' ready to customize or restore. No Reserve Auction!!! eBay Watch Airstreams on eBay 0 03-06-2012 06:50 PM
Looking for someone to do Magic Chef stove resoration shermantic Stoves, Ovens & Microwaves 1 03-06-2012 03:27 PM
