Old 02-07-2004, 12:14 PM   #1
Lanny
lwebb's Avatar
1954 15' Byam Holiday
1955 15' Byam Holiday
Athens , Georgia
Send a message via AIM to lwebb Send a message via Yahoo to lwebb
Tighten old vs all new rivets
I think I have read every rivet post here at least twice but then again I'm likely to have missed some. So if there's one that covers this let me know.
I' m about to begin a total renovation of my old Holiday. a great many of the rivets are loose enough to wiggle to the point I can slide shirt cardboard under the head.
I will have the interior completely stripped so I don't think getting to the back side of the rivet will be a problem. Is there a way to tighten these effectively or should I remove them all and start anew
lanny
lwebb is offline   Reply With Quote
Old 02-07-2004, 12:35 PM   #2
Images: 59
A what?
Love the picture of your '53 Holiday. What type of rivets and what size?
I'm afraid if they are regular bucked rivets, the holes will be so oversized you will need to drill them out and use oversized rivets. With the age of your unit, I'm pretty sure you would want to do all of them at once so they look consistent and really pretty.
Old 02-07-2004, 12:53 PM   #3
Lanny
lwebb's Avatar
Athens , Georgia
Mark, They look to be the same size as what I've seen on most Airstreams. I'd guess since it was made in the Jackson Center Ohio Airstream pant, they would be the same?
Here is a pict of the ele inlet:
Lanny
Old 02-07-2004, 12:57 PM   #4
Lanny
lwebb's Avatar
Athens , Georgia
Sorry new to this. let's see if the picture comes through now?
Old 02-07-2004, 01:16 PM   #5
Images: 59
Rivets
Yeah, those look like the standard rivets. Those are supposed to be 1/8". I found when I drilled out the rivets on my '59 that quite a few were oversized, even though they were all tight.
I think I am going to use 5/32" 'modified Brazier head" rivets when I put mine back together. They have a larger stem (5/32") but have the same head size as the original 1/8" rivets.
Be sure to use hardened rivets. You can order from Byler rivet company. Talk to Jimmy Johnson. They're $11/100, and you need a rivet set also ($16). Let me know if you are going this direction and we can order at the same time as they are not a stock item.
Or you could go with the Universal head rivets which I think is what most people use. Not much difference except the head is higher and dish shaped. Depends on how original you want to be.
Or you could use Olympics.
Old 02-07-2004, 02:02 PM   #6
Lanny
lwebb's Avatar
Athens , Georgia
Wow Mark, That's to many choices. After reading all the posts I thought the majority opinion was to use Olympics. I'll have to go back and do more homework. I had priced the 300 pack of Olympic Bulb-tite rivets from Airstream dreams. A $56 per 30 they are a good bit mr expensive than the modified Brazier head rivets you mentioned at $11 pr 100.I don't really remember if they offered different sizes. I think they are 5/32. OK what is a rivet set. I was going to bite the bullet and split the cost of a shaver tool with a friend. He has a 66 20' Avion he's redoing.
lanny
Old 02-07-2004, 02:28 PM   #7
Images: 59
Rivets
Sorry, thot you were taking the interior panels off,which make regular bucked rivets a lot cheaper and easier.
However, you would need to buy a rivet gun, bucking tools, and rivet set (the nosepiece that goes into the rivet gun). Would be about $300 unless you buy from ebay. You also need a friend to work on the other side of the panel.
On the other hand, the olympic rivets take longer to put in, and you need the rivet shaver. And they cost more for each unit.
I guess it depends on how many you plan to do and what you want the final product to look like. I'm doing a frame off restoration so I have at least 500 rivets to put in.
Old 02-07-2004, 02:59 PM   #8
Lanny
lwebb's Avatar
Athens , Georgia
Yeah Mark, 99.9% of my restoration will be solo. I'm planing to do a frame of restoration n mine as well. It's only 16' long tongue to tail so it shouldn't be too bad. I did a 16' Casita from ground up replacing or refurbishing everything down to the bare fiberglas. It's what got me excited about the Holiday.
Lanny
Old 02-07-2004, 11:17 PM   #9
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
I would LOVE to see pictures of your Holiday...both interior & exterior! Post some to your gallery when you get a chance...
Shari
Old 02-08-2004, 06:40 PM   #10
Lanny
lwebb's Avatar
Athens , Georgia
Shari, If I could figure out how to do that, I'd be happy to. I read "Attaching Photo Gallery Photos"... in 10 easy steps." but where it says "In the top right hand corner, click on "Upload Photos" I sure can't find the "Upload Photos" button.? Her are a couple of pictures.
lanny
Old 02-08-2004, 06:42 PM   #11
Lanny
lwebb's Avatar
Athens , Georgia
Inside front, Sorry really bad photo
Old 02-08-2004, 06:42 PM   #12
Lanny
lwebb's Avatar
Athens , Georgia
Inside Back
Old 02-09-2004, 10:26 AM   #13
InsideOut's Avatar
1956 22' Safari
Images: 108
Thumbs up Fun!
Very nice...I love it! Especially the "yellow dingle-balls", although they probably aren't original.
Are you logged in? Sometimes I find I can view the photos but can't leave a ny comments or upload only to find I haven't actually logged in. Oppps! Double check & see if that could be your problem...if not, PM me & we'll see if we can figure it out.
Old 02-09-2004, 11:05 AM   #14
Images: 59
Rivets
WOW! Lots of ground clearance. Did you replace the axle? Love the white walls.
