Old 03-03-2011, 11:34 AM   #1
dznf0g's Avatar
Oswego , Illinois
This dent really bugs me
While cleaning my, new to me, AS last summer I noticed this dent. It is under the corner protector (mostly). At first I thought the PO must have cut the corner too sharp during backing, but I quickly decided not. The protector seems to not have ever been replaced. All rivets look original, and all sealer in the entire front looks the same and appears to have been applied by the same hand.
Upon closer inspection I see that the vertical rib which has the protector hinge attached to it is slightly bowed in. There is no impact damage or witness marks. This throws off the battery compartment frame a little and, of course, "binds" the skin, giving the appearance of a dent.
So my question is: how can I adjust the rib w/o removing all the interior and /or exterior skin?
Just leave it alone? I'm inclined toward the latter....but it really bugs me!
ID:	123519   Click image for larger version
ID:	123521   Click image for larger version
Old 03-03-2011, 11:45 AM   #2
A.K.A "THE STREAM"
THEPILL's Avatar
2010 25' FB International
Arlington , Texas
I'm clueless on how to fix it,..
Chalk it up as "Character"
Unless of course it impedes the functionality of something.
Shane
http://i52.photobucket.com/albums/g2...h_postcard.jpg
"Stay Thirsty My Friends"
Tow Vehicle" 2011 Superduty Diesel!!"
TAC ID TX-1432
THEPILL is offline   Reply With Quote
Old 03-03-2011, 11:48 AM   #3
dznf0g's Avatar
Oswego , Illinois
Shane
...just the functionality of my anal-retentive nature.
Old 03-03-2011, 11:51 AM   #4
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
Im still waiting on my first dent....eeek!
But I did drive off with my step down and bent the tar out of it!!
I hammered it back,,it's crooked and gives when we step on it,,but it's used now and I hopefully have christined the vessel.
Shane
TAC ID TX-1432
Old 03-03-2011, 11:54 AM   #5
The dent, is one thing. What caused it, is the big question.
Your photo shows a metal box on the front end.
What is that box, and what did you have in it when the dent happened?
Fixing that dent is easy and super cheap. I can help you with instructions for that issue, but please answer the box question.
Old 03-03-2011, 12:01 PM   #6
A.K.A "THE STREAM"
THEPILL's Avatar
Arlington , Texas
Andy, I believe the "box" is the storage under his bed, like mine..right next to the curbside protectors.
I might be wrong.
Shane
TAC ID TX-1432
Old 03-03-2011, 12:03 PM   #7
I might be wrong.
Shane
His box is in front of the shell, for some reason.
Look at the trees in the background.
Old 03-03-2011, 12:05 PM   #8
dznf0g's Avatar
Oswego , Illinois
Andy, I don't know what you mean. Pic #1 shows the battery compartment door; #3 just shows the protector swung open. There is nothing non-stock about the front end. I have come to believe the AS was "born this way". I believe the rib was bowed during construction and they just slapped on the protector over it. Nothing else is at all unusual about the front end.
Old 03-03-2011, 12:13 PM   #9
OK, that answers the box question.
It appears that the vertical stiffener, is bent a few inches below the window.
That will put the "dent" in the quarter panel.
If you remove the metal, below the window, on the inside of the trailer, where that dent is located, you should find a bent stiffener.
How you can correct that bend, depends on what the stiffener damage looks like.
The dent in the quarter panel, from your photo, appears to be an "oil can" type dent. If that's the case, then correcting the stiffener, will remove that "oil can" dent.
Old 03-03-2011, 12:29 PM   #10
dznf0g's Avatar
Oswego , Illinois
Yes, you are correct on both accounts: bent about 3" below the window and it is an oil can "dent". I believe the stiffener just has a shallow smooth deflection, no evidence of anything else. What is the methodology, step by step to reshape the rib in that location? Some sort of hydraulic jacking force or a rubber mallet? That is where I am afraid to experiment.
Old 03-03-2011, 12:49 PM   #11
The fix depends on what the stiffener looks like.
The only way you can tell, is to see it.
Therefore you must remove the inside panel below the front window and the one behind the dent.
Then and only then, will it become obvious as to what the fix will be.
To replace that vertical stiffener is not a big deal.
Repairing that stiffener could be a problem.
Old 03-03-2011, 12:59 PM   #12
1988 25' Excella
1987 32' Excella
Knoxville , Tennessee
It does not leak?
Be a heck of a lot simple to "get over it" than to fix it.
Old 03-03-2011, 02:57 PM   #13
Liberator
klattu's Avatar
1972 Argosy 24
1989 34.5' Airstream 345
Heart of Dixie , Alabama
Images: 834
Just horrible...how can you sleep at night?
Your opinion is valued, please not your opinion of someones else's opinion.
Click To See Me Wet
1989 Airstream 345 Liberator...
1972 Argosy 24'...
1954 Feathercraft Vagabond
klattu is offline   Reply With Quote
Old 03-03-2011, 03:04 PM   #14
dznf0g's Avatar
Oswego , Illinois
Bill: Nope!
Klattu: Not very well!
Andy, thanks. Is this a u-shaped stiffener that begins at the c-channel (duh) and ends at the window frame? Not a "full length" to the roof bow? What all materials will I need....including....what do you use to re-adhere the mouse fur to the wall?
I'll probably wait till I need to get into the wall for something else...or get real bored.
STILL BUGS ME THOUGH!!!!
Old 03-03-2011, 03:11 PM   #15
dznf0g's Avatar
Oswego , Illinois
Andy, I know about Olympic rivets, head shaver, pop rivets, sealer etc. I only need to know about channel, any internal brackets, stuff I can't see and have never been into before. Thanks, again.
Old 03-03-2011, 06:46 PM   #16
1960 24' Tradewind
Riverside , California
Looks like the kind of buckle that appears when the front end is dropped, of the ball or jack stand, when that 600-800 pounds hits the ground something gives.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 03-03-2011, 07:16 PM   #17
dznf0g's Avatar
Oswego , Illinois
Greg
Not dropped. No other evidence, ie. interference between tongue and lower belt molding, no jack evidence, no evidence on the curb side, no witness marks on A frame, etc. Definitely a force applied about 3" below the window, I believe prior to the corner guard installed. The sealer is even a thicker bead in the depressed area between the guard hinge and skin.
Old 03-03-2011, 07:35 PM   #18
You can use some 1/8 inch thick aluminum angle to beef up the stiffener, after you straighten it.
You can get that at Home Depot, etc.
Old 03-03-2011, 07:46 PM   #19
dznf0g's Avatar
Oswego , Illinois
What method would you used to straighten it after inner skin is off?
Old 03-03-2011, 07:50 PM   #20
dznf0g's Avatar
Oswego , Illinois
Hey Andy, could you look back at post # 14? I think you missed it due to the page break.
Street-Side Dent Bauxter Ribs, Skins & Rivets 28 03-01-2011 03:38 PM
Dent in water tank galvanized pan safariuser Belly Pans & Banana Wraps 1 02-26-2011 06:37 PM
nic danger - Softball dent in my 2010 FC nic carter Ribs, Skins & Rivets 15 02-03-2011 02:25 PM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 02:03 PM
