Old 03-03-2011, 02:11 PM   #15
dznf0g's Avatar
Oswego , Illinois
Andy, I know about Olympic rivets, head shaver, pop rivets, sealer etc. I only need to know about channel, any internal brackets, stuff I can't see and have never been into before. Thanks, again.
Old 03-03-2011, 05:46 PM   #16
1960 24' Tradewind
Riverside , California
Looks like the kind of buckle that appears when the front end is dropped, of the ball or jack stand, when that 600-800 pounds hits the ground something gives.
Greg
1960 Tradewind
2007 Denali 6.2
2005 ST 1300 ABS
2005 Chevrolet SSR 6.0 LS2
airstreamlosangeles.com
ZoomZoom is offline   Reply With Quote
Old 03-03-2011, 06:16 PM   #17
dznf0g's Avatar
Oswego , Illinois
Greg
Not dropped. No other evidence, ie. interference between tongue and lower belt molding, no jack evidence, no evidence on the curb side, no witness marks on A frame, etc. Definitely a force applied about 3" below the window, I believe prior to the corner guard installed. The sealer is even a thicker bead in the depressed area between the guard hinge and skin.
Old 03-03-2011, 06:35 PM   #18
You can use some 1/8 inch thick aluminum angle to beef up the stiffener, after you straighten it.
You can get that at Home Depot, etc.
Old 03-03-2011, 06:46 PM   #19
dznf0g's Avatar
Oswego , Illinois
What method would you used to straighten it after inner skin is off?
Old 03-03-2011, 06:50 PM   #20
dznf0g's Avatar
Oswego , Illinois
Hey Andy, could you look back at post # 14? I think you missed it due to the page break.
Old 03-04-2011, 08:11 AM   #21
Guessing at "how to" goes no place.
What you see, is what you got, so to speak.
The answer will be obvious once you can see the issue.
Wall coverings are held in place with a good adhesive.
Street-Side Dent Bauxter Ribs, Skins & Rivets 28 03-01-2011 02:38 PM
Dent in water tank galvanized pan safariuser Belly Pans & Banana Wraps 1 02-26-2011 05:37 PM
nic danger - Softball dent in my 2010 FC nic danger Ribs, Skins & Rivets 15 02-03-2011 01:25 PM
Before I remove bath end cap Breadbug Ribs, Skins & Rivets 3 01-27-2011 01:03 PM
