Old 09-30-2004, 03:11 PM   #1
Question Thickness of interior panels?
I've started the repair of my '58 22' Custom. I noticed that the interior aluminum is thinner than the outer skin. What is the thickness? Is it the same alloy as the exterior?
crgintx is offline   Reply With Quote
Old 09-30-2004, 03:51 PM   #2
Images: 59
I just measured several of the interior sheets on my '59 Tradewind, and they're all .032". No mill stamps, but they feel like the same 2024-T3 as the outside. The Zolatone is 5 mils thick, for a total of .037"
Maybe someone switched yours? Or maybe the Custom was made different?
Old 09-30-2004, 04:04 PM   #3
Red face
Don, it's definitely a thinner gage of aluminum than the exterior on the lowest interior panel. I've had no luck with the bow either. Although I think that aircraft spruce might have some of the c-channel for the girts.
Old 09-30-2004, 04:38 PM   #4
Images: 59
Carlos,
I'm puzzled. The ribs/frames on my Tradewind are C-channel 1 1/2" x 3/4" x 1/16" extruded. I think you could buy that locally, not from Home Depot, but from a metal fabricator. Freight would be a killer if you ordered from Aircraft Spruce.
The girts/longitudinals on my Tradewind are C-channel 1 1/2" x 5/8" x .032", bent on a press brake. You could get these made by a local sheet metal shop, but you may need to supply the sheet metal if you want it made from 2024-T3.
A metal fabricator could also roll the curves in the ribs. Best to cut a pattern out of cardboard and they can duplicate it.
The fabricators I deal with appreciate a bag of donuts about 9AM.
Old 10-17-2004, 07:06 PM   #5
Red face OOOPs
I got busy and didn't read your reply till tonight. I've made a rib/bow out of kerfed 3/4" x .05 ell channel sandwiched between two layers of .032 alclad. I'm going to use the same channel to make a complete window style frame for the 5'x6' opening. I also plan on adding some diagonal braces as well. Sometimes overkill is good thing.
Plywood - How thick is the original? Marlboro Mafia Repairing/Replacing Floor &/or Frame 11 04-08-2004 10:09 AM
Help >> '04 22' CCD Mattress Thickness Xray 2002 - 2005 International 1 04-07-2004 11:44 AM
Holding tank thickness? Sneakinup Waste Systems, Tanks & Totes 4 11-10-2003 09:38 PM
Skin thickness Steve St. J Ribs, Skins & Rivets 1 09-23-2003 10:57 AM
vent cover repair.... Chuck Windows & Screens 10 11-13-2002 12:05 PM
