05-28-2015, 09:09 AM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
TheSignLadys tips for finding and repairing leaky rivets + Fixing with Olympic Rivets
OK, I've been meaning to post this one for a while...
Here's a simple but amazing way to find and repair leaky rivets
First I had already visually gone over my trailer and replaced any obviously failing rivets. Then I went over every one of my rivets a few times with Captain Tolley's creeping crack cure, Captain Tolleys is nice because it wicks in under the rivet and seals it, but only if the gap is not too big.
Capt. Tolley's Creeping Crack Cure
Now for the cool part...
Everyone know the concept of how a suction cup works right, apply a suction cup to a smooth surface and it will seal, if you place it on incorrectly and air gets under, there is no seal...so based on that concept I went out to my trailer and went over each rivet one by one. If I tested a rivet with my suction cup and it didn't stay stuck on I knew that air was coming through from under the rivet itself and if air is getting through so can water.
Here is my video showing the process we used to find and repair leaky rivets
https://youtu.be/lYmQsn6DlE4
The suction cups can be found at pretty much any auto repair place
This is the Olympic rivet kit I bought from vintage trailer supply
Olympic Riveting Kit
The rivet remover tool I also bought from VTS
05-28-2015, 09:22 AM
1962 28' Ambassador
1961 19' Globetrotter
Mesa
Signlady, Nice job on the video.
Hittenstiehl
05-28-2015, 09:51 AM
1981 31' Excella II
New Market
, Alabama
Good job.
Perry
05-28-2015, 10:59 AM
1964 17' Bambi II
Schererville
, Indiana
Nice,
Becky
1964 Bambi II
1988 Avion 32S
05-28-2015, 06:42 PM
2012 27' Flying Cloud
W
, New England
Great tip to find the leakers and repair them! Thanks for sharing!
05-28-2015, 08:39 PM
Remember, Safety Third
Catfish Corners
, Georgia
very clever!
05-28-2015, 10:10 PM
1999 34' Excella
Hillsboro
Nyce job! could really see how the aluminum was deflected inward after you installed the new rivet...
Thanks!
Peace and Blessings..
Channing
WBCCI# 30676
05-29-2015, 12:16 PM
2007 22' International CCD
Corona
I'm gobsmacked at the simplicity of using a suction cup to find leaky rivets! Never though of that one...
And the rest of the video is super useful for understanding how to fix it....
Many thanks for posting this!
05-29-2015, 09:40 PM
Watertown
, Massachusetts
Brilliant!
Brilliant idea to use a suction cup! I happened to have one of these so just for giggles I checked out some of my rivets. I found several that don't let the suction cup stick, but I don't see any evidence of a leak. So, am I suffering from wishful thinking, or could they be OK? My AS is practically brand new, so I can't imagine that several could already be leaking. And I only checked the reachable ones on one side - heaven knows how many I'd find if I checked all of them.
SallyE
05-29-2015, 10:40 PM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
I used the Captain Tolley's creeping crack cure before the suction cup test as I figure it will help seal the really minor air gaps that may be too small to be letting water in. It may not be foolproof test but as I have all the tools to do the repairs quick and easy and it helped me nail down my mystery leaks
05-30-2015, 04:40 AM
W
, New England
Thesignlady - I was wondering about something - did you find any places on your Airstream where the curve of the shell or the indent of the rivet would have prevented a good seal on the suction cup even if the rivet itself would have been fine?
We had ours pressure tested at the factory last year and they found no leaks but I think your process once or twice a season is very good preventative maintenance!
05-30-2015, 06:16 AM
Beaufort
, South Carolina
Great info and video. Thank you.
05-30-2015, 08:49 AM
1967 22' Safari
MILAN
Great Job!
So glad you are willing to share this with the Airstream Community here! I cannot believe that none of us here have ever thought of this! We are in your debt on this one. It works for all leaky rivets on any age riveted travel trailer not just Airstream! As to the question of if it indicates leaks on new trailers my answer would be that yes it is very likely showing air leakage around even newer rivets. Every time you move the trailer it will flex the panels and therefore loosen the rivets. Perhaps only a minor amount of gap occurs but worth a treatment with Capt. Tolleys. This is a great preventative method of stopping leaks before they happen. Again, thanks so much. Ed
1967 Safari Twin "Landshark" w/International trim package
2014 GMC Sierra 1500 Double Cab SLE
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
05-30-2015, 08:58 AM
houston
clever!!
'15 27fb Signature
'12 Chevy 2500HD Gasser
05-30-2015, 09:02 AM
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria
, British Columbia
Hi SteveSueMac, yes definitely I had areas where getting the suction cup to play was an obvious issue. Here's where I noticed issues, in some areas I had minor tree branch scratches that affected the seal, some it was mottled clearcoat, and then some areas of the big compound curves in the end caps pretty much matched the profile of the suction cup so it was easy to pull it off as not enough suction was gained. But the most problematic area was the rivets along the overlap seams, It was hard to get the cup placed in between the boundaries of the neighbouring rivets and the cut aluminium edge..the style of suction cup I show in the video is flat in its dormant state and kind of wide for that area. I found it tedious and sometimes impossible to get the cup to work along these edges so I am keeping my eye out for a dent puller my mom had when I was a kid for these areas. Moms kind of looked like a little bathroom plunger with a 2 foot long wood handle and a deep welled suction cup that was only one inch wide, no fancy release lever on that baby, just a good old fasioned suction cup on a stick :-) I'll let you know if I ever find one like it.
05-30-2015, 11:27 AM
1967 17' Caravel
Oak Creek
Great idea!
Thank you!
09-04-2016, 12:08 PM
1968 22' Safari
Edmonton
, Alberta
This video should be utilized in some sort of vintage airstream owners manual! Well done!!!
10-17-2017, 06:32 PM
2016 26' Flying Cloud
Southlake
Following your advice, I went over all the rivets that are not on a seam with a small suction cup. To my surprise, I found one that was leaking. Right on the front, below the window. I applied Capt. Tolley's for two days and then checked the rivet again. The suction cup held!
Thanks for the tip.
2016 Flying Cloud 26u
2017 Silverado Duramax 4x4
Equalizer Hitch
