Old 02-09-2003, 07:08 AM   #15
LOST , Hawaii
Aluminum comes in different grades. If you get the same as the skin on the trailer it shouldn't matter if it is from Airstream or a warehouse. If the coating you refer to is plasticoat, don't try to work the panel too much or you will end up stripping and resealing. If you get a formed punched panel as a replacement that would be ok, but I would go with bare metal for anything else. Think about auto body shops, they don't install painted parts, assemble and then paint.
John
74Argosy24MH is offline   Reply With Quote
Skin replacement Ken J Ribs, Skins & Rivets 292 05-29-2015 09:47 PM
holes in the skin bhsl8 Ribs, Skins & Rivets 7 01-06-2004 05:52 PM
Odd skin dents in front and behind axles Mprecure Axles 3 09-23-2003 08:35 PM
Remove belly skin -- all or nothing? pilgrim_still Belly Pans & Banana Wraps 1 06-21-2003 06:50 PM
Belly skin removal Pat McSween Belly Pans & Banana Wraps 1 05-17-2003 07:23 AM
