Old 11-29-2007, 01:46 PM   #1
The Flintstones's Avatar
1970 27' Overlander
Houston , Texas
Stud Welder
Has anyone used a stud welder and a slide hammer to remove any dents. Is it usable on aluminum? From what I can tell it would be a good solution. No holes to drill or inside gutting to get to the dent? I have a local body shop around the corner and am going to pull over to see what they say. But if able to do myself and save $$ I would rather try myself. Not looking for a factory finish just pleasing to the eye.
Thanks for any info
James
____________
1970 Overlander
The Flintstones is offline   Reply With Quote
Old 11-29-2007, 01:54 PM   #2
Jim Clark's Avatar
2012 28' International
New Orleans , Louisiana
Thanks for any info
James
I would like to hear what they have to say. The skin may be to thin. I looked at a stud-welding site but did not feel like figuring out all the details.
Jim N5TJZ Air# 174
2012 International Serenity 28
2005 Safari 25 SS Traded
1968 Globetrotter Sold
2011 F150 Ecoboost
Jim Clark is offline   Reply With Quote
Old 11-29-2007, 01:58 PM   #3
Mikethefixit's Avatar
1977 27' Overlander
Trotwood , Ohio
Send a message via Yahoo to Mikethefixit
I would NOT try it. Stud welders are made for steel. Alumunium is too soft and melts easily.When U melt a hole in a panel U will have more problems than a dent.
Roger
Mikethefixit is offline   Reply With Quote
Old 11-29-2007, 02:02 PM   #4
1970 27' Overlander
Houston , Texas
Harbor Freight
Harbor Freight has one (stud welder) for 139.00 and it comes with a slide hammer and 100 studs. I know they are on the cheap end but if it works, what the hey.
James
____________
1970 Overlander
Old 11-29-2007, 02:11 PM   #5
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
I agree!
Roger
Unless you are willing to test out the concept with a piece of aluminum scrap first (match thickness and alloy type) you could be putting your whole airstream into worse shape than before you started.
Try finding an aircraft airframe mechanic - these people are experts at just this kind of repair.
Old 11-29-2007, 03:54 PM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
It will not work period. The alloy of the aluminum Airstreams are made of is a non weldable alloy
Kip
Old 11-29-2007, 06:08 PM   #7
1970 27' Overlander
Houston , Texas
Dang!!
Thanks fo the reply's. . . Oh well, that settles that. I am taking our AS to the body shop next week to see what he says, when I talked to him on the phone today he said he has several different options available? I will let yall know what he says. Can the endcap inside be cut to access the dents and re-fiberglassed with any success?
thanks
James
____________
1970 Overlander
Old 11-29-2007, 06:11 PM   #8
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
You can get similar results by using a suction cup dent puller. Unless, of course, you have badly creased metal, in which case the studs won't help much, either.
Uwe
www.area63productions.com
Old 11-29-2007, 06:49 PM   #9
2007 27' Classic FB
Havelock , North Carolina
What about those guys that say they can pull dents from your car without affecting the paint? I think they use some sort of glue to attach a puller. Probably similar to a slide. I think I saw a kit in one of those auto body magazines.
I guess after looking it looks a lot like these Auto Body Toolmart - Glue Pulling Dent Repair
nsteel is offline   Reply With Quote
Old 04-24-2009, 08:53 AM   #10
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Arrow Promises Promises
Originally Posted by The Flintstones View Post
Thanks fo the reply's. . . Oh well, I am taking our AS to the body shop next week to see what he says, when I talked to him on the phone today he said he has several different options available? I will let yall know what he says. Can the endcap inside be cut to access the dents and re-fiberglassed with any success?
thanks
James
Ok Fred er Barney, Wilma, whoever...
Hows about the long-awaited follow-up you promised...?
How'd the dents get in the cap area and did you ever cut a hole inside the inner cap? I would think that could be done but I'm thinking only a fiberglass artist (pro) could patch it back well. I'd never do it that way.
Also the pain, frustration and difficulty of dropping (actually of re-hanging it) the inner cap "aint" no fun either so I've read.
Sure curious about the glue on stud idea. And if it would apply.
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 04-24-2009, 12:59 PM   #11
Happycampers's Avatar
1979 30' Argosy
Havelock , where we park it
I have used stud welders for years doing body repair. As far as I know they only work on steel and then sometimes they will pull off and the metal will come with it leaving a small hole. If you can find one that works on aluminum I would not use it for that reason.
Marvin
Marvin & Annie
Niki (fur baby)
1979 Argosy 30 (Costalotta)
WBCCI 10103
"Happiness is a warm Puppy" Charles Schulz
Happycampers is offline   Reply With Quote
Old 04-24-2009, 04:27 PM   #12
Crusty's Avatar
1992 34' Excella
Find a body shop that's got a suction cup slide hammer - not the cheap Auto Zone type but rather the kind that you hook up to an air compressor to generate the hard vacuum necessary to get a firm grip.
There's even a member of the forums here who has one that he takes to rallies along with a compressor and makes lots of new friends every time he gets it out. I can't remember his forum handle however - so maybe someone else can fill this info in.
Crusty
"If you come to a fork in the road, take it."
Lake Travis, TX
"Rancho Deluxe"
Crusty is offline   Reply With Quote
Which welder do I need? Bob Thompson Ribs, Skins & Rivets 9 04-22-2007 09:25 PM
The welder is coming, the welder is coming... Safari Tim General Interior Topics 13 09-01-2006 10:00 AM
Going to the welder Bobolo Repairing/Replacing Floor &/or Frame 23 07-14-2005 10:57 PM
Broken shock absorber stud jasper2222 Axles 7 01-31-2005 06:34 PM
Wheel stud removal? TomW Axles 13 07-28-2004 04:42 PM
