Old 10-10-2010, 05:51 PM   #1
Bauxter's Avatar
Columbus , Ohio
Street-Side Dent
I have a 3 foot long X 4 inches tall indented "scratch" that starts about 10 feet back from the tongue, on my 1973 31' Sovereign. It is in the middle of the bottom, almost full-length panel on the street side. One of the ribs may have been bent.
My question to the AS skin gurus out there: Can I cut out the damaged section, and splice in a new panel, avoiding the replacement of the entire panel? I am worried that there was a structural purpose for such a long panel.
I will post pictures tomorrow.
Bauxter is offline   Reply With Quote
Old 10-10-2010, 06:17 PM   #2
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Don't be shy, as well as posting some pics, tell us how you did it so we can avoid the possibility of us doing it.
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 10-10-2010, 06:25 PM   #3
Post a photo showing the damaged area.
Old 10-10-2010, 06:43 PM   #4
BeBop's Avatar
2000 27' Safari
Berkeley , California
Bauxter,
I don't know about any structural aspects of the panel, but I know when my neighbor at the storage yard backed into my trailer (with me inside at the time) leaving a nice transverse scratch (with not apparent deflection/rib damage) in the same street side panel, the estimate from Inland RV was about $3,000 for replacement.
Pricey any way you look at it.
'00 Safari 27' Rear Twin
'03 Ford F-250 7.3TD/CC/LB 4x2 Bio-Diesel
"Hmmm... Smells like French Fries!"
Prodigy/Enkay/Hensley/Solar/LED lighting
AIR 4598 / WBCCI FCU 8579/
EAA 872814
BeBop is offline   Reply With Quote
Old 10-10-2010, 06:48 PM   #5
BeBop's Avatar
2000 27' Safari
Wow, Andy, That was quick!
IRV knows their stuff. Send him a photo and I am sure he can give you the proper response!
EAA 872814
Old 10-11-2010, 07:27 AM   #6
Bauxter's Avatar
Columbus , Ohio
Added Pictures
I attached 3 pictures that show the damage. I placed red lines where the ribs should be, on one of the pictures. I was planning on cutting this portion out, and splicing in a piece of the same length with some overlap.
Some of my follow-up questions would be:
  1. Do I need anything between the new aluminum and the ribs (rubber, Vulcum, etc)
  2. How large of a compressor do I need to run the Buck rivets in?
I have already started a frame-on restoration. The panel replacement task will probably be scheduled for next spring, when the inner panels have been removed.
In case anyone is wondering, you are indeed seeing duct tape holding my awning brackets down. As Red Green used to say, "Its a handy man's secret weapon....for those who know who Red Green is.
ID:	112831   Click image for larger version
Old 10-11-2010, 07:34 AM   #7
Bauxter's Avatar
Columbus , Ohio
BeBop, I am very inexperienced to moving 31' trailers. I transported this behemoth about 60 miles without incident. Once I arrived in the storage facility, I failed to pay attention to the trailer, as I rounded a curve, and scraped up against the bed of a dump truck.
Dump truck beds are very unforgiving things....
Old 10-11-2010, 07:39 AM   #8
Cut away some of the metal that's covering the main bow that's damaged. Straighten the main bow the best you can, and then you can add shims to it so that the outer edge is in alignment with the other main bows.
Then simply overlay the old metal, with the new. No need to remove the old material.
Remove all the rivets from the main bows that will be on the forward and rear edge of the new panel. Riveting over rivets at a seam, is not good, plus it will leave gaps so that the new metal will not be flush with the old metal.
Seal the new metal with Vulkem to make sure it cannot leak. Water between the two panels would not be good.
You can easily use Olympic rivets instead of buck rivets. The new panel will be much more of a detraction than the Olympic rivets.
Old 10-11-2010, 08:50 AM   #9
Ag&Au's Avatar
Port Orchard , Washington
I wonder if you could make the patch the same vertical dimensions as the trim that is visible in the photo behind the damage. Then you could extend the trim forward. That would make the patch much less noticeable.
Regards,
Ken
Old 10-11-2010, 09:08 AM   #10
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
Ouch! Two suggestions... if you're taking the innerskins off already, try rolling out the dent from the inside.. it will still be there, but it might not be so bad after rolling it out.
2) If it's still noticible, make the patch go a bit further forward to the front curve around.. it's only another 3 ft or so.. and it won't look as bad. I'd do as Andy suggested, tuck the new patch under the upper panel, and over the old one. You'll have a bunch of rivets to drill out, but I don't think it would be that noticible. Don't forget about drilling out the side hatch too.
Marc
Old 10-11-2010, 07:44 PM   #11
Bauxter's Avatar
Columbus , Ohio
If I just lay it over the old, then there will be a seam that faces forward. I was planning on overlapping the front panel over the new patch, which would make the seam face rearward. This would keep water from being forced in the seam during transit. Maybe I am over-thinking the problem?
I like the idea of trying to roll out the crease, but I don't think it will look very good, as the crease is fairly deep.
Old 10-11-2010, 08:14 PM   #12
You cannot roill out that crease, period.
Covering it or replacing the entire side sheet, is your two choices.
Old 10-24-2010, 09:53 AM   #13
Bauxter's Avatar
Columbus , Ohio
Since I am am new to the AS world, my tool set does not include anything associated to riveting. I don't want to open up a heated debate regarding Olympic versus Buck, so I was going to buy the tools to do both. Being the cheapskate that I am, I have been searching online auction sites,such as EB@y. I think that I can buy everything I need fairly inexpensively. I know the risks of buying used, and am willing to accept the risk.
If I buy something similar to the item at the end of this link, will it shave the Olympics correctly, or do I need to make sure the bit is correct? I would also ask if the bit is interchangeable?
IR INGERSOLL RAND 7AH AIR PNEUMATIC RIVET SHAVER - eBay (item 300483605360 end time Nov-19-10 13:48:02 PST)
Old 10-24-2010, 11:30 AM   #14
Unless I missed something, the ad for that rivet shaver says it "shaves rivets off".
What you need is a shaver that trims the rivet head to look like the original "brazier head" buck rivet.
dent repair, skin replacement
Street side rear outrigger davidz71 Wheel Wells 11 11-20-2013 10:16 PM
Street Side Gaucho Plans - 1978 Caravanner ColdEspresso 1975 - 1978 Caravanner 3 02-14-2011 12:14 PM
'68 Globetrotter with a street side booth? gypsy man Cabinets, Counter Tops & Furnishings 0 11-08-2007 05:38 PM
Fabrication of Hehr Street Side Window rek Windows & Screens 0 05-04-2007 12:12 PM
What is the small white thing on the street side housebg Exterior Restoration Forum 4 07-26-2006 09:36 PM
