Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Exterior Restoration Forum > Ribs, Skins & Rivets
Old 10-17-2006, 05:27 PM   #1
48_liner
48_liner's Avatar
Profile:  1948 22' Liner
Squaw Valley , California
steel plate at front
Anyone know what the steel plate is for at the front of the trailer?
I'm having problems posting and hope this doesn't go through mulitple times.
48_liner is offline   Reply With Quote
Old 10-17-2006, 05:30 PM   #2
wkerfoot
wkerfoot's Avatar
Profile:  1979 23' Safari
1954 29' Liner
Orange , California
Bob,
It is to secure the trailer body to the frame. My 1954 Liner did not have one, but I have included one in the rebuild. I have seen reported that other early 1950's trailers did not have one either, does your 1948 Liner has a plate?
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
Old 10-17-2006, 05:49 PM   #3
TomW
TomW's Avatar
Profile:  1967 26' Overlander
Normal , Alabama
Images: 77
Originally Posted by wkerfoot
...It is to secure the trailer body to the frame...
I agree that is does that, but I believe its primary purpose is to combat the twist that is developed when transitioning from the coupler to the body through the A-frame.
Sheared rivets on the skin in front of the plate indicate a problem. Member rluhr posted about one such situation with his '68 Airstream. I do not know if it was ever resolved.
Tom
Old 10-17-2006, 06:53 PM   #4
48_liner
48_liner's Avatar
Ours had the plate. I'll try to add a picture. It was very rusty and the skin had turned to powder where the steel reacted with the aluminum. I don't see a reason for it as the skin attaches all the way around to the U channel.
Name:	Inside Front Opt.jpg
Old 10-17-2006, 07:00 PM   #5
wkerfoot
wkerfoot's Avatar
1954 29' Liner
Orange , California
Additional security, I painted mine with POR 15 to stop dis-similiar metal contact. RJ Dial used an aluminum angle in his rebuild of the Flying Cloud on VintageAirstream.com. On the GSM Vehicle site you can see the plate on the Caravel Colin just finished when they repaired/rebuilt the frame (this was featured on TheVAP.com).
Bill
Old 10-17-2006, 09:34 PM   #6
Aerowood
Aerowood's Avatar
Profile:  1971 21' Globetrotter
Arvada , Colorado
rust
I have the same problem with my 71 globetrotter. I plan on removing it ,sandblasting to remove all rust, prime with epoxy primer ( both the steel and the aluminum skin then reinstall it wet with sealent. This will give me 2 barriers of protection against dissimular metal contact and making another battery.
Old 10-18-2006, 03:37 AM   #7
wahoonc
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
On the 70's models it is a pretty substantial plate. I am not an engineer but I would think it is to help keep the shell in place on the frame and to transfer the load from the a-frame. The front of the trailer takes a lot of load because of the A-frame and the wind when towing. On my 1975 the plate is welded to the main frame, then riveted to the body. The sheared rivets are apparently caused by out of balance running gear and/or a overly rough tow vehicle suspension.
Aaron
WBCCI #2449 AIR #2495
Old 10-18-2006, 09:41 AM   #8
Chuck
Chuck's Avatar
Profile:  1973 23' Safari
Images: 99
Originally Posted by wahoonc
... The sheared rivets are apparently caused by out of balance running gear and/or a overly rough tow vehicle suspension.
Aaron
...or a rotted-out floor, which was Rich's problem. the lack of a solid floor allowed for too much movement, which is what caused the rivets to shear repeatedly.
Air:291
Wbcci: 3752
'73 Safari 23'
'00 Dodge Ram 1500 4x4 QC
WANTED: Front Dinette Photos InsideOut General Interior Topics 21 01-12-2007 03:09 PM
1974 excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Stainless steel wool and mice barbwire All Argosy Trailers 14 12-02-2002 10:01 PM
Front floor area and rebuilding dresser jeanarlene 1969 - 1973 Safari 10 09-05-2002 11:11 AM
TV Connection Plate winner Audio, Video & TV 10 06-16-2002 06:00 PM
